WAG-
If it has a mechanical engine-driven fuel pump, then a leak there could let fuel enter the crankcase. My brothers 69 Chevelle ( he had it in the early 80s) did exactly the opposite. A bad diaphragm was letting oil get into the fuel. Tons of blue smoke. Probably gas was going the other way as well, but it burned about a quart of oil every other day, so there would be no time for it to accumulate. Pat Mackenzie |
Latest blog entry: er9x heli 450 heli set up (flybar)
California
Joined Feb 2005
Most likely , it is excessive blow by passed the piston rings. How many hours do you suppose is on that engine?
with any type of reliability.Tram did not mention how or if the thing runs. Also. This can only be true if its an overhead valve engine, or maybe a horzontial lying down on its side engine. |
This is most likely if your engine is gravity feed for the fuel.. If the fuel is delivered via a mechanical fuel pump where the pump is attached to the engine, it is likely that the pump diaphram is leaking gasoline which runs out of the pump and down to the oil sump. |
California
Joined Feb 2005
| Thread Tools | |
| Discussion What would cause this weird shake on my heli? | BowerR64 | Micro Helis | 15 | Jun 23, 2007 10:50 PM |
| Discussion What would cause this in a LensRC 22 | Valid8r | Power Systems | 4 | Sep 09, 2006 10:33 PM |
| Discussion What would cause this on the Blade CP? I'll try anything.. | jmdombr | Micro Helis | 13 | Mar 17, 2006 11:56 PM |
