Old Dec 02, 2005, 02:50 PM
rskdev is offline
Find More Posts by rskdev
Joined Nov 2005
New way to route Antenna?
Has anyone tried this way? Works good and alot cleaner looking. Have'nt range tested yet. Still building. 36'' piece of Nyrod bent in half and zip tied to skids. Links to pics below.
http://img.photobucket.com/albums/v1...v/DSCF0854.jpg
http://img.photobucket.com/albums/v1...v/DSCF0853.jpg
rskdev is offline Find More Posts by rskdev
Old Dec 02, 2005, 04:01 PM
heli_newbie is offline
Find More Posts by heli_newbie
crash. rebuild. repeat
Fairfield CA, USA
Joined Mar 2005
ever tried one of these(Deans One-Piece Antenna 72 & 75MHz)?
http://www2.towerhobbies.com/cgi-bin...?&I=LXKX47&P=7
Probably cuts down on range a bit, but with a micro it will still most likely be out of sight before you get out of range. They look clean and work well.
heli_newbie is offline Find More Posts by heli_newbie
Old Dec 02, 2005, 04:15 PM
Tintin is offline
Find More Posts by Tintin
Tintin's Avatar
Akershus, Norway
Joined Mar 2005
Tried similar. Forward thru 1 tube around and back thru another on the other skid then stretched back to the tail.
Changed it to wound round the tube....
Tintin is offline Find More Posts by Tintin
Old Dec 02, 2005, 04:50 PM
Wynn1427 is offline
Find More Posts by Wynn1427
Lesson Learned = $$ Saved
Wynn1427's Avatar
United States, CA
Joined Jul 2005
I have also been looking rounting my antenna a certain way and have came across this micro antenna (http://parts.rctoys.com/rc-toys-hobbies/Items/335868?) Best price so far and free shipping.
Has anyone purchased this antenna? Any feedback would be helpful.
Wynn
Wynn1427 is offline Find More Posts by Wynn1427
Old Dec 02, 2005, 05:22 PM
gwong is offline
Find More Posts by gwong
gwong's Avatar
Vancouver, B.C., Canada
Joined Sep 2003
Gents,
My antenna came out of the stock black plastic tube, than thru the carbon bin than back to the skid on the opposite side. The carbon fin caused a bit of interference during a range test so, I used an elastic to attach the antenna to the carbon fin. This work better with no range check issues. Having said this I didn't like the way it looked, so I am now using the Dean's Whip Antenna. A range check did show a hint of glitching but I think it was caused by the environment in my garge, moved the heli outside and the glitching went away. The Dean's micro antenna is mounted with servo tape and secured with 1 tie wrap underneatch the rear skid.
Hope this helps,
Gord.
gwong is offline Find More Posts by gwong
Old Dec 02, 2005, 05:29 PM
jameotron is offline
Find More Posts by jameotron
kids ate my heli budget
jameotron's Avatar
Auckland, New Zealand
Joined Feb 2005
If you double-back the antenna then you effectively reduce it's sensitivity by the amount you double it back.
If you fold it in half like in the photos at the top of the thread then you will have half the sensitivity that you are supposed to have.
jameotron is offline Find More Posts by jameotron
Old Dec 02, 2005, 07:56 PM
lowflyer101 is offline
Find More Posts by lowflyer101
Joined Sep 2005
ur gyro look dangerous man...i could mount it on the side intead,,,
lowflyer101 is offline Find More Posts by lowflyer101
Old Dec 02, 2005, 08:09 PM
rskdev is offline
Joined Nov 2005
Well I guess this guy must be losing about a 1/3 of his antenna sensitivity.
http://www.trextuning.com/IMG_6037_filtered2.jpg
Is'nt this the way most people run it?
Old Dec 02, 2005, 08:21 PM
Soupisgoodfood is offline
Find More Posts by Soupisgoodfood
Wellington, New Zealand
Joined Sep 2005
I saw this method in a photo. I can't remember where.
Anyway, you don't need any tubes for this, it looks nice and tidy, less likely to damage the antenna in a crash because it's elastic, and easy to remove if it gets in the way when working on the heli.
The base and end of the antenna are tied to opposite legs of the skids. Then the antenna pulled straight to form a "V" by a rubberband and hook assembly that attaches to the tail.
Hopefully the photos are self explainitory.
Soupisgoodfood is offline Find More Posts by Soupisgoodfood
Old Dec 02, 2005, 08:57 PM
joe@tech-mp is offline
Find More Posts by joe@tech-mp
This stuff is so cool !
joe@tech-mp's Avatar
Guilford, CT
Joined Mar 2004
Here is how I routed mine. It's neat, glitch free and has great range.
The built in connector allows easy removal of the Rx.
Joe
joe@tech-mp is offline Find More Posts by joe@tech-mp
Old Dec 03, 2005, 01:15 AM
gwong is offline
gwong's Avatar
Joined Sep 2003
Here is a pic of my Trex with a Dean's Whip Antenna mounted on the bottom rear skid. Sorry if the pic is blurry...need to invest in a tripod.
Old Dec 03, 2005, 03:59 AM
contact303 is offline
Find More Posts by contact303
Joined Mar 2005
contact303 is offline Find More Posts by contact303
Lady demonstrates new way of parking car. Vonbaron Life, The Universe, and Politics 19 Jan 28, 2004 04:21 PM
A new way for things to go wrong Neil Morse Parkflyers 1 Jun 24, 2002 09:00 AM
a new way to build foamcore wings? sportwin Foamies (Kits) 8 Apr 19, 2002 11:40 AM
Easy way to calculate antenna legth Skysailor Parkflyers 2 Dec 10, 2001 06:10 PM
Easy Way to Route Cutie Antenna AirVenture Electric Plane Talk 4 Dec 08, 2001 02:31 PM
