Go Back   RC Groups > Boats > Scale Boats
Old Dec 02, 2005, 03:25 PM   #1
My Graupner Jules Verne RC-Motor yacht
Hello Everyone,
I must share with you some pictures from assembly to finish of this fine Motor yacht by Graupner Germany.
You will see things in these pictures which I’ve now changed to improve the model.
The Kit comes complete with prop shafts, rudders, propellers and all the necessary finishing touches.
I used everything accept for the propellers and the recommmebed motors.
The motors you see in the pictures are 777's they are very strong construction. Twin roller bearings 6-12v 7pole low current drain, 5000+ RPM.
I purchased these motors from (A.J.Graham) MODEL MOTORS DIRECT UK. Unfortunately this motor specialist can only be contact by mail or phone. (No email or web site). Pity
I choose these motors because they are cool running (no need for water cooling) and above all, consume very little current. Infect duration on a 12v 4Ah gel battery at full throttle gives me 1hr cruising. I use 3 bladed 40mm brass counter rotating props. They perform better than the plastic ones.
The speed is excellent (scale speed as it should be for this classy motor yacht.)
I hope that sooner or later I will post some good images for my boat on water.
The model is quite straight forward, so building was quite easy.
Should you have any questions please feel free to ask.
Enjoy it
  • Name: 10.01 (196).jpg
  • Name: 10.01 (197).jpg
  • Name: 10.01 (198).jpg
  • Name: 44j (1).jpg
  • Name: 44j (2).jpg
  • Name: 44j (3).jpg
  • Name: 44j (4).jpg
  • Name: 44j (5).jpg
  • Name: 44j (6).jpg
  • Name: 44j.jpg
  • Name: 45 (2).jpg
  • Name: 45 (3).jpg
  • Name: 45 (4).jpg
  • Name: 45 (5).jpg
  • Name: 45 (6).jpg
  • Name: 45(1).jpg
shipcollector5 is offline Find More Posts by shipcollector5   Reply With Quote
Old Dec 02, 2005, 05:04 PM   #2
Grumpa Tom
Kmot's Avatar
I am really glad you posted these pictures!
I have the Jules Verne kit. I plan to start it next year. So I am very interested in your build of this model. Do you have more photos taken during construction? If so, please do post them!
I have not even taken my kit out of the box, so maybe my questions are premature but I will ask anyway.
How do you glue the deck to the hull? I see you have taped in may places. Do you add glue then from inside the hull at the seam?
Is the smoke plastic top jigged for the window frames? Or do you just take your best guess at where to glue them on?
Are the motor mounts included in the kit or do you custom build them?
How do you access the inside for maintenance once the model is completed?
Thanks!
Kmot is offline Find More Posts by Kmot   Reply With Quote
Old Dec 02, 2005, 05:33 PM   #3
Go Nuclear, You'll love it
Ghost 2501's Avatar
K, its a good boat, and has a touch of class that the salina model does not. Ship Collector, how long did it take to build?
Ghost 2501 is offline Find More Posts by Ghost 2501   Reply With Quote
Old Dec 02, 2005, 06:12 PM   #4
interesting construction details on the Jules Verne- Looks like the flying bridge, windows, cabin top and foredeck are a single, vacuformed sheet of plastic?
Aerominded is offline Find More Posts by Aerominded   Reply With Quote
Old Dec 03, 2005, 05:59 AM   #5
Reply Kmot
Hello Kmot,
I only have these images on construction. Unfortunately I didn’t document the full process. (Next time I will) Here is my reply to your questions.
A) I glued the deck to the hull, using medium super glue. I used masking tape to bind the deck and the hull in a way, that when I left the super glue to run in the gap it didn’t fall out from the seam. It is important that you do this. When the gap was completely full of super glue. I sprayed activator on it. It will instantly settle rock solid.
B) All the moulded parts are jigged.
C) The motor mounts are custom made. They are not supplied with the kit.
D) The whole cabin structure comes off for inspection. It’s very practical
Hope my reply is of help to you.
Thanks!
Old Dec 03, 2005, 10:44 AM   #6
Ghost 2501's Avatar
yep, it does look that way, means it would be a pig to mask as well
Old Dec 03, 2005, 12:24 PM   #7
Grumpa Tom
Kmot's Avatar
shipcollector: thank you for the reply!
Old Apr 11, 2007, 01:32 PM   #8
Testing my camera video clip jules verne
Hi
Just testing, hope you enjoy
My graupner jules verne (1 min 23 sec)
Stephen
  • Name: Picture 013.jpg
  • Name: Picture 018.jpg
  • Name: graupner05 (13).jpg
  • Name: graupner05 (16).jpg
  • Name: graupner05 (14).jpg
  • Name: graupner05 (17).jpg
  • Name: graupner05 (15).jpg
  • Name: graupner05 (18).jpg
Old Apr 11, 2007, 01:59 PM   #9
3 Blades to the Wind
Shaun Hendricks's Avatar
Nice yacht. I'd love to have one! Looks like it almost reaches full plane at speed.
Shaun Hendricks is offline Find More Posts by Shaun Hendricks   Reply With Quote
Old Apr 11, 2007, 03:12 PM   #10
dash8man's Avatar
Hi,
Just finished my Jules Verne with working Bow Thruster. Cheers.
Bill.
  • Name: Verne 001.jpg
  • Name: Verne 002.jpg
  • Name: Verne 003.jpg
  • Name: Verne 004.jpg
  • Name: Jules 005.jpg
dash8man is offline Find More Posts by dash8man   Reply With Quote
Old Apr 11, 2007, 03:42 PM   #11
Beautiful job. I love your work. Bill
Stephen
Old Apr 11, 2007, 03:49 PM   #12
dash8man's Avatar
Thanks Stephen. My pics are a bit milky looking so they don't do the boat justice. This was a great kit from Graupner, one of their best I'd have to say. Relatively easy build although the wood railings rerquired several ales in order to get them correctly into place!
Bill.
Old Apr 13, 2007, 01:31 AM   #13
Grumpa Tom
Kmot's Avatar
Both of you have built magnificent renditions of the Jules Verne yacht. I hope mine turns out as well when I build it.
Old Apr 13, 2007, 01:34 PM   #14
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
That kit sure looks fantastic.
All three builds. Great work guys.
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki   Reply With Quote
Question Brushless Motor for my Graupner Nemesis NewToRCguy Foamies (Kits) 2 Jul 12, 2005 10:24 AM
Question Graupner Jules Verne yacht dds7197 Scale Boats 4 Mar 04, 2005 05:21 PM
Yippee! Motor Problem With My Graupner Gee Bee Urgent agapornis Foamies (Kits) 2 Dec 23, 2004 02:59 AM
Graupner Jules Verne robster94gt Scale Boats 0 Nov 30, 2003 06:31 AM
Help! How do I retime my 6327 Graupner Speed 480 race motor for a gearbox. Joe Elston Electric Plane Talk 6 Apr 20, 2001 12:56 PM
Congratulations SimpleM!
