Old Dec 02, 2005, 10:44 AM
powerditto is offline
Find More Posts by powerditto
Former User
Cool
A list of things that can go wrong
powerditto is offline Find More Posts by powerditto
Old Dec 02, 2005, 03:26 PM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
Nice job I only found 2 errors but they dont alter the intent
item 9 for sailing read ''flying.''
item 15 the saying is '' life is tough.''
another nice reference to the list.
olmod is offline Find More Posts by olmod
Old Dec 02, 2005, 03:38 PM
fly_boy99 is offline
Find More Posts by fly_boy99
Flying motor mount master
fly_boy99's Avatar
San Jose, California, United States
I'd say in number 19)
Do the noload test with a 2S to start with. No need to smoke the motor right away if you don't have to... remember this is the first time you start the motor!!!
One other one you can add to winding:
After winding each phase take a continuity tester and check to see if there are no shorts. If there is one, start over, if not move on to winding the next phase!!
Keep up the good work!
fb
fly_boy99 is offline Find More Posts by fly_boy99
Old Dec 03, 2005, 06:51 AM
Former User
Old Dec 03, 2005, 09:41 AM
David T is offline
Find More Posts by David T
UK
Joined Aug 2000
Ralph,
Looks very helpful. Here are a bunch of suggestions:
4: Is it worth mentioning that 100% is slightly greater than what is optimum? It is good to have gaps between magnets and this should be greater than the gap to the stator to help prevent flux leakage (ie: flux simply flowing between magnets instead of interacting with the stator).
5: Are you sure about 9T/6P motors being noisy? Mine have never been. I find that the AAABBBCCC winding is noisy (8 and 10P).
7a: I'm not sure the I agree with (or perhaps misunderstand) this section. Magnets only repel when in side-by-side cascade (NN). They attract when cascaded to increase thickness. I can suggest new wording if you wish.
14. Most of my shorts occur where the wire goes around the corners of the head of the tooth (because they are pointed and sharp). Its easy to press these wires away from the head with a fingernail and usually saves a rewind.
15. Another implication of untidy winding is that 'inside' head can foul the rotor. It is good to apply epoxy to the wires on this head so they cannot drift. Press and hold it flat while the epoxy cures.
I would add to 25:
Do not grind down the tooth heads (or skim in a lathe) to reduce the stator diameter. This creates short circuits between the stator laminates at a critical position (where the flux is flowing between the stator and the magnets).
8. It can be inevitable that you have to file down a tooth but perhaps point out the negative implications (25 above).
Do you cover mounting the motor anywhere? With outrunners it is easy for the rotor to cut the 3 wires coming out of it. Also, nothing must touch the rotor while it is running (eg the side of the fuz or loose things in the fuz).
David T is offline Find More Posts by David T
Old Dec 03, 2005, 12:33 PM
Former User
For Sale A few more Lipos that can go L_Castle Aircraft - Electric - Batteries & Chargers (FS/W) 5 May 11, 2006 12:35 AM
Rave Murphy's Law-If anything can go wrong, it will Happymcc Micro Helis 7 Oct 18, 2005 08:05 PM
Yippee! I want a on road car that can go on grass just_starting On-road Cars 7 Oct 30, 2004 07:24 PM
Yet another thing that can go wrong on a Slow Stick bradm Aerial Photography 31 Oct 14, 2004 10:26 AM
Wife ticked said,"But a motor that can go on any plane" thor4944 Power Systems 10 May 15, 2003 03:51 PM
