Awsome, what gyro are you going to use?
For fiago screws, here you go http://www.allerc.com/product_info.php?products_id=1442 |
hi dacaur
thanks for the link and thanks Vario3 , those are tiny little screws and i think the feigao motors would be interesting to try , i found GWS P-03's on sale for $32.00 a pop at http://www.edogfight.com/ i think when a coaxial is setup right there isn't much problem with yaw as both rotors cancel each other out and since the are the same size it's a 1 to 1 ratio , unlike a conventional heli with a small rotor at the end of the tail boom , i know a HH would do a better job , but i have a real cheap streak in me , thanks again , dana
Pittsburgh PA
Joined Dec 2004
questions questions questions
How do you make the motors counter rotate?
Do the stock pinions fit the motors? What exactly will the advantage be? What is the estimated finished price excluding radio? BTW the Hirobo paddles make all the difference in the smoothness of flight on the stock unit, but the BX flybar doesn't line the up "flat". After a bit of twisting they fit pretty good. Bert PS: hurry up!!! |
Brendin |
Miami Mike suggested to me that an elevon mixer might work...
http://www2.towerhobbies.com/cgi-bin...?&I=LXELT4&P=7 http://www.bill-tek.com/Elevon.htm I think it would probably work well. It has two inputs one for aileron and one for elevator and has two outputs for the two elevon servos. I see the connection as follows Receiver Rudder output > Gyro > Mixer (aileron input) Receiver Throttle output > Mixer (elevator input) The mixer outputs would be connected to the two speed controls. I am going to head to the hobby shops tomorrow to see if I can find an elevon mixer. Brendin |
| Thread Tools | |
| New Product E-flite Blade CX Coaxial Heli | vrex | Coaxial Helicopters | 2306 | Apr 12, 2009 07:43 PM |
| For Sale New E-flite Blade CX - In Stock | Vintauri | Aircraft - Electric - Helis (FS/W) | 3 | Dec 05, 2005 01:42 PM |
| E-Flite Blade CX | Rampage | Micro Helis | 6 | Nov 25, 2005 09:03 AM |
| Alert Orderig the E-Flite Blade CX | X190 | Coaxial Helicopters | 3 | Nov 22, 2005 08:57 AM |
| E-Flite Blade CX | Rod Carson | Micro Helis | 2 | Nov 11, 2005 03:43 PM |
