Old Nov 30, 2005, 12:44 PM
Tumbler is offline
Find More Posts by Tumbler
Tumbler's Avatar
United States, NJ, Vineland
Joined Feb 2003
Fastest Set up for 36" Wing??
What is the fastest setup for this size plane. Motor, batt, and prop?
Brian
Tumbler is offline Find More Posts by Tumbler
Old Nov 30, 2005, 02:23 PM
Rizza is offline
Find More Posts by Rizza
High Flyer
Northern, NJ
Joined Nov 2004
Not enough info
Your question is very open ended. It's kind of the same as asking what is the fastest compact car, with what motor, tires, gears, exhaust.
Your going to get back all kinds of answer.
One important things to keep in mind, however is:
How much equipment you could fit in the airfoil. I say this because with a thinner airfoil, you'll be limited to the amount of batteries you can possible put in the wing. Since this will limit or "not-limit" what kind of Motor / ESC combo you can use due to Amp draw.
If you dont really have a limitation on this than the more LiPo battery voltage you can send to the motor along with Battery Mah the faster you might be able to go.
If you do some searching around this forum you'll find that when it comes to whats the fastest setup, you cant really go wrong trying to speak to Klique(Rc Group Username). The man has been there done that, with just about every kind of flying wing setup.
Hope this helps you get started...
Rizza
Rizza is offline Find More Posts by Rizza
Old Nov 30, 2005, 03:32 PM
RobinBennett is offline
Find More Posts by RobinBennett
Sussex, UK
RobinBennett's Avatar
Crawley, West Sussex, UK
Joined Jun 2004
I know almost nothing about wings, but I'd guess that you work out the highest stall speed you are comfortable flying (or launching and landing), say 20mph (9m/s), then calculate the weight that will give you this for your wing area (say 0.2m^2).
There's a useful calculator here
http://www.flyingsites.co.uk/downloads/
that gives a max weight of 1kg
In theory:
lift=weight= max lift co-efficient * density of air * wing area * speed ^2
'max lift co-efficient' and 'density of air' are both about 1, but I must have got something wrong because it doesn't work out...
Anyway, subtract the weight of the airframe, plus a bit for the radio gear, giving about 700g
Allow about 75% of that for the lipos, say 500g
If you don't want to use a BEC, you will probably be using a 4s battery. That's about a 4s 5000mAh,
If you believe the 20c ratings, that's capable of 100A. At 14v that's well over 1000W,which is way out of my experience of motors but it tells you what size ESC you need.
Of course, 20mph is a pretty high stall speed, if you go to 15mph you have to halve the AUW, and your battery weight drops by even more.
So, how did I do? Are any of those numbers even in the right ball-park?
RobinBennett is offline Find More Posts by RobinBennett
Old Nov 30, 2005, 03:49 PM
Tumbler is offline
Tumbler's Avatar
Joined Feb 2003
Wow, you guys are getting way too technical for me..haha. All I wanted to see is waht motor and prop would be best and would find a way to make it work from there. It seems the 16/25/3 is a pretty good motor for what I want from searching around and see on a 4.75x4.75 prop on 6s a guy got a 150mph prop speed and a 7x5 prop on 5s I think it was was another option. Might try that motor.
Brian
Old Nov 30, 2005, 04:02 PM
Sussex, UK
Joined Jun 2004
It's a technical subject - but you can always just copy someone else who had good results. Personally I like to understand what's going on.
However, remember that it's the battery that powers the plane.
The motor is just part of the transmission, it has to be capable of handling the power from the battery, and 'geared' to turn at the right speed, but it isn't where the power comes from.
Question What set-up for a DPM 1:4 scale Clipped Wing Super Cub? JimJams Scale Kit/Scratch Built 0 Apr 03, 2006 02:39 AM
My low pilot load 6 wing servo set up for EVO stephen.s1 Radios 3 May 19, 2004 03:14 PM
best bl set up for a wing torcgolf Power Systems 3 Jan 12, 2004 10:56 AM
fastest set up for N. Hawes tucano? kartman24 Electric Plane Talk 4 Sep 21, 2003 02:11 PM
