Old Nov 30, 2005, 12:18 AM
timocharis is offline
Find More Posts by timocharis
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
Mini-HowTo
CD Motor Winding For Thumbies -- The Classic 17 Turn
A couple of days ago I put up some pictures of a 20-turn wind session in the hopes it would help out some struggling beginners:
http://www.rcgroups.com/forums/showthread.php?t=445750
Then I started thinking, sheesh, no way a beginner should be doing a 3-level wind. Out and back is plenty to start with.
For some time now the 26awg 17-turn has been a standard in the CDROM motor universe. It has only one purpose in life: to fly a 7oz or less 3D plane 2s with a GWS 8040 prop. Okay, you can run a 7060 for a bit more speed on some little pooch plane, or float a bigger "sport" model, or even go 3s with a 7x35. But that's all a bunch of hooie. It's an 8040 3D motor.
Still with me? Begin by marking your 'starter' teeth. I only mark two, since I'm going to cover the first position (to the left of the black dot) immediately. That will both start and end phase 1. Phase two will start on the black dot, and phase three on the red mess.
Start and end?
timocharis is offline Find More Posts by timocharis
Last edited by timocharis; Mar 02, 2008 at 12:22 PM. Reason: added a cool link and found a particularly nasty grammar error
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
Wrap A Little Wire On Your Starting Tooth
The idea here is to waste a little wire making your first tooth easier to start. Note I sort of wrap it backwards so it will be easy to unwrap. So make a few turns on the tooth you marked, count over three (which will be just to the right of the red mess on my stator) and start your actual wind. When you finish your first tooth, you can come back and unwrap this.
But we'll get to that.
Old Nov 30, 2005, 12:19 AM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
First Tooth, First Layer
Neatly wind your first layer on the first tooth. You should be able to get 8 winds completely on both front and back (back is the direction the bearing tube faces). Wind firmly, but don't pull hard or yank.
When you get around to the front at turn 8-1/2 you should basically run out of space and be forced to the second level. Stop at this point and smoosh the wires in flat to the stator with your favorite tool -- toothpick, carbon fiber flat stock, whatever.
Old Nov 30, 2005, 12:20 AM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
Turn Nine
When you go around to the back again, loop the wire outside your eighth turn so it kind of overhangs the hammerhead. This will buy you enough space to get that 17th turn on when you get back down to the bottom of the tooth.
Note that the wires have been smooshed flat against the stator at this point.
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
Turn 9-1/2
Do the same thing when you get back to the front. This one is a little bit trickier, but also just a little bit more important. You'll need the space on the front. So hook it on there and snug it down a little. It really will stay.
After you manage this, just keep on winding. Don't pull very snug at all -- you want a slightly (very slightly) loose wind so you can pop and snick the wires back toward the outside when they slip inward. Trust me, they will.
Old Nov 30, 2005, 12:21 AM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
Finish The Tooth
Once you get back to the middle, the wire should just barely fit on the back side after your 17th turn. It's a good idea to do another smoosh at this point, getting the wires nice and flat against the sides of the stator.
Note that you never care what happens on the "back" of the stator. There's always plenty of room. While you're winding, you care what goes on between the teeth, but only while you're winding. Once the wire is in there, it just doesn't matter any more. But I like to keep all the mess on the rear of the stator, because the one place you do have to worry about in the end is the front. The wires will have to stay clear of the can.
But don't worry about that yet. I'm getting ahead of myself. At this point, you should see something like this:
Old Nov 30, 2005, 12:22 AM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
Finish The Phase By Doing Two More Teeth
Once I've finished the first tooth, I go back and unwind my starter. Then I take the wire and jam it into the rear bearing hole to keep it out of the way.
Later, after I finish the entire phase (three teeth, the last being the tooth I originally used to anchor my wire), I tape the end to the bearing tube. This keeps all the floppy stuff out of the way while winding the next phase.
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
The Next Phase Smoosh
When you start the next phase, you'll be confronted with winding a tooth next to one that's already full. You should find there's plenty of room to get the first layer on. When you get to turn 8-1/2 (as above) you'll want to do a little bit different smoosh.
Up until today, I used carbon flat stock to work this trick, but Jeff (galloping_gimp) turned me on to this slick move: use an old prop blade to get your center spacing. The entire problem is in the middle -- we'll have tons of room out at the hammerhead, but it's going to be a bit crowded near the hub. To open that up, cut off the end of a prop blade and slide it through the gap. It should go easily, and you should see plenty of room to slip the second layer on.
Old Nov 30, 2005, 12:23 AM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
Just Keep Going
After that, you just keep going. You might be worried that the third phase will be harder than the second, but I actually find it easier. During both of the first two phases, I'm concerned with making sure I leave enough room for the work I have to do later.
On the third phase, there is no work later. If you get the wire on, you're good to go.
When I get to the last half wind of the last tooth, I like to thread the wire under its own start. Otherwise it's just kind of dangling loose and doesn't necessarily even finish the 17th turn. This may sound odd, but the pictures will help explain, and I guarantee when you get to that point you'll see what I mean.
First, I leave a lot of wire to make this operation easy:
Old Nov 30, 2005, 12:24 AM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
Lace It Through
Then slip the wire under that same wire's start (on that tooth; not its original start...)
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
Tighten and Turn Out
Take it easy tightening the wire into place -- it's possible to kink it if you're not careful. When you're done, turn it out toward the edge. And that's about all there is to it.
Old Nov 30, 2005, 12:25 AM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
The Front
Here's about how it should look. You will want to smoosh down what you're looking at in this picture. These wires are trying very hard to make contact with the spinning can. Your job is to flatten them in to make sure they don't get the chance.
Now stick it on your shockie or slofly mini or whatever. It will do the job just fine, and you can start thinking about doing that 20-turn so you can go 3s with the 8040.
Just look at all the space between those teeth! The real motor guys will sniff at your first effort -- "not enough copper" and "use a bigger gauge wire" and etc. But heck, you built it, it will work, and it will fly your plane.
Gotta start somewhere!
Dave North
November 2005
Old Nov 30, 2005, 01:45 AM
johnrobholmes is offline
Find More Posts by johnrobholmes
Engineer in training
johnrobholmes's Avatar
Columbia, Missouri
Joined Jun 2004
Great tutorial! How about some tricks to slide the magnets in next?
johnrobholmes is offline Find More Posts by johnrobholmes
Old Nov 30, 2005, 07:31 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Great job, Dave.
Gene Bond is offline Find More Posts by Gene Bond
Old Nov 30, 2005, 07:59 AM
bass3587 is offline
Find More Posts by bass3587
bass3587's Avatar
Arlington,Texas
Joined Jan 2005
Yeah do a tutorial on magnets. I hate magnets and I have a spacer
bass3587 is offline Find More Posts by bass3587
Help! motor winding for a small prop wedge98 Electric Motor Design and Construction 9 Dec 15, 2006 05:39 PM
FS: new 17 turn motor & front & rear wheels & Proline tires for RC10B4 ozvena Cars - Cars and Parts (FS/W) 10 Apr 13, 2005 08:21 PM
Building a double CD motor, winding ?'s DsWright Power Systems 24 Mar 01, 2005 11:57 AM
Anyone try'd this for cd motor winding? nickrage Power Systems 10 Feb 19, 2005 11:38 AM
Need help timing 17 turn Atomic Force motor jhearn Electric Heli Talk 2 Mar 25, 2003 03:29 PM
