Sundsvall Midlanda, Sweden
Joined Aug 2002
cmulder,
If you want a certain amount of watts to power you plane, and use higher voltage instead of more current. You will see longer batterylife. Of course itīs possible to use xSxP packs, but only how much current a single cell se is important in this matter. /Wheaz |
Olympia, WA
Joined May 2005
Danny |
No, because typically you would use a smaller cell capacity to get the same weight. Fiddilng with volatges and turns will not achieve greater effeicincy or pack life if the same wieght of pack and size of motor are employed. You do not get something for nothing. |
are you assuming he is using an efficient motor vintage1? With cheaper built motors the increased amp draw of low wind motors could cause sagging effeciency from heat buildup.
I do see your point about keeping pack weight and can design constant though. What about the fact that lower turn motors pass more amperage? Isnt heat caused by amperage? Quote:
220 watts on 6 cells is still 220 watts no matter how you hook them up. in both cases each cell will be pushing 10 amps. In case one it is obvious, but in case two the parallel packs will share the load and split the amperage. Even if you wired all six in parallel, they would still see 10 amps apeice. |
Typically, low turn motors can draw a higher current than high turn motors but this is because they use thicker wire. Because there are fewer turns, there is enough room in the motor to use a thicker gauge of wire. The thicker wire means that the resistance will be lower. You are right that the effieciency decreases as the motor heats up. The heat comes from two types of losses: Copper losses are I x I x R and Iron losses are Io x V where Io is the no load current. A low turn motor has a low resistance, R but a high no load current, Io. A high turn motor has a higher resistance but a lower no load current. If you run both motors at the same rpmand the same load they will have about the same efficiency and consequently will get just as hot as each other. What will be different will be that the low turn motor will use low voltage and high current while the high turn motor will use higher voltage and lower current. One more thing. For a given voltage, motors have a maximum efficiency current. Maximum efficiency occurs when copper losses equal iron losses. Sometimes, there are situations where you have chosen the load very specifically such as a scale sized prop or a particular ducted fan unit. In these cases, there may be a benefit in selecting a particular combination of motor and cells that will be operating closer to its maximum efficiency point than some other combination. Also, you may want to keep voltage and current within particular ranges because of the speed controller that you have or the actual cell capacities that are available. In a perfect world, we would be able to select the voltage to exactly what we wanted. But we can't because cells come in multiples of either 1.2(ish) volts or 3.7(ish) volts. So, it is more important to get the right setup that is operating efficiently but this could be either a low voltage/ high current solution or a high voltage/low curtrent solution (or anywhere in between). |
I have always understood that higher voltage setups have less heat losses because the current flow causes excess heat build up. The reason that power transmission lines can be so thin is because they carry high voltage low current power that is converted to low voltage high current at the transformers. If they carried high current there would be much higher power losses. This has been my understanding up to now but perhaps I am about to be educated.
Milwaukee Wisconsin, United States
Joined Feb 2001
The really big gains from going low amps/high volts come when using cheap can motors.
These motors were designed for other uses than flying model planes, and their amps of best efficiency are so low that they'de be almost unusable as powerplants for airplanes when used at lower voltages unless we push way higher amps through them, and that pushes their efficiency very low, into the 40-50% range. On these motors, big motor eff. gains can be had by using the same total watts through them by going much higher on voltage while holding amps much lower, ie: instead of using 12 amps at 7 volts, try 11 volts at 7.5 amps. Both have about 83 watts, but the low volt one will likely be at 40% eff. while the high volts one will be perhaps 60%, so low volts: 83 watts x .40% = 33.2 watts output high volts 83 watts x .60%= 49.8 watts output So by going the same exact input wattage but at higher volts you have a full 50% more power at the prop, all done through better efficiency. All this becomes moot however with purpose built motors as they can set their amps of best eff. at almost any level they want, neatly bypassing the need to keep motor amps down to get good efficiency from them. |
Batman,
If the losses just came from the winding resistance you would be right. But the other component of the losses is what is termed iron losses and is calculated from Io x V. Io is sometimes said to be a constant but if you measure it you will find that it actually increases with voltage. Anyway, the iron losses increase with voltage and maximum efficiency is where iron losses equal copper losses. So Io x V == I x I x R for maximum efficiency. So this means that if you take a low turn motor with Io of 5 amps and put 10 volts on it with no prop, it will lose 50 watts (5 x 10) in heat! And it is not even doing any useful work yet! The way to figure out how to best run a motor is to make an estimate of the heat losses that it can withstand. This can be tricky but with some experience can be estimated. Let's say a motor can withstand losing 100 watts without overheating. Divide that in two to get the iron losses and copper losses at maximum efficiency. So, Io x V = 50 and I x I x R = 50. If you know Io and R, you can work out the ideal voltage and current to run at. You can then use that to choose the appropriate number of cells and prop. Just in case you think that Io does not get very large, a Hacker B50 4L has an Io of 8.75 amps! The kV is over 6000 so you don't need many volts. |
Ireland
Joined Apr 2001
setup i have in mind
I have a robbe eolo heli with a kontronic 3700 kv twist and a jazz controller.
Curently i am flying with a old 8 cell sanyo 2200 mah pack wich gives about 6 to 7 min duration. Since i already have updated my robbe infinety charger to be lipo compatable i am considering replacing the old pack with a lipo pack. Its verry eazy to change gear ratio so i was thinking if i put a small pinion on the motor , and go with the highest cellcount the motor/ esc can handle (6) i will get a good duration with a decent headspeed for hovering while not stressing the pack / esc to mutch |
Heli what? Sorry, I am not at all familiar with helis
.Messing around with Motocalc to do the calculations, it would seem that the maximum efficiency current on 8 NiCd cells is 30-35 amps giving about 250 watts. Are you running your pack this hard? At this level (250 watts) the motor appears to be around 90% efficient with losses of about 23-25 watts. Looking at other voltages to provide that same power, 3s lipo would draw 24 amps at 10.6 volts for a similar efficiency and 24 watts in losses. So a good setup but no more efficient than what you have. 2s, 4s, 5s and 6s solutions for the same power appear to be slightly less efficient with losses of 27-38 watts. If you let me know what power level you are actually using (what current are you drawing at the moment? I guess it is hard to measure?) or would actually like to use I can run the numbers again. One word of caution. Motocalc is not 100% accurate and I have input the motor parameters from the Kontronik web site for this motor. However, we should be in the ballpark. |
| Thread Tools | |
| Servo alternative for the MaxIr and 4s High Voltage setup. | Hoverup | Micro Helis | 21 | Jul 15, 2005 01:07 AM |
| High voltage lower amps? | DavidN | Power Systems | 4 | Jul 14, 2005 03:24 AM |
| Question Outrunners - more efficient at high or low RPM? | hilgert | Power Systems | 3 | May 15, 2005 07:40 AM |
| High Voltage and Low Amp Setup? | sailmike | Power Systems | 1 | Nov 24, 2004 03:49 AM |
| MGM TMM controller for high voltage setup? | jetkkman | Electric Heli Talk | 1 | Dec 04, 2003 05:21 PM |
