Old Dec 30, 2005, 12:08 PM
SkyKing RC is offline
Find More Posts by SkyKing RC
Minneapolis
Joined Feb 2004
The specs look good
The simple answer is I don't know for certain, however, the specs look right as far as output is concerned. At $50 this looks like a steal.
Ed
SkyKing RC is offline Find More Posts by SkyKing RC
Old Jan 09, 2006, 01:48 PM
BUCIbuc is offline
Find More Posts by BUCIbuc
Joined Mar 2005
Hi, i just have one question. I would rather buy some transformer than make one by myself so i need your opinion. Would this work for a 30 inch bow and some ni-chrome wire or quitar string (don't know the width yet):
Here is the transformer that i want to buy
Or should i go for 10-12 AMP transformer (its a little more expensive, so i'm asking for the 5-7 AMPS first)
Hope you will help
David
BUCIbuc is offline Find More Posts by BUCIbuc
Old Jan 10, 2006, 09:38 AM
dayhead is offline
Find More Posts by dayhead
SlingWinger
San Bernardino, California, United States
I still like using a car battery charger plugged into a fan speed controller or light dimmer. Cheap and relatively safe.
dayhead is offline Find More Posts by dayhead
Old Jan 15, 2006, 07:29 PM
ThermalSeeker is online now
Find More Posts by ThermalSeeker
United States, CO, Denver
Joined Sep 2005
Sorry DoonRaker,
My internet access is sporadic, so I haven't been online for awhile.
The power supply I have is a dimmer switch attached to a transformer which gives me anything from 0 up to about 40 volts, purchased what seems like eons ago. I never cut below 13 volts or above 18 volts with a 30 inch bow.
The inconel wire I'm using was bought a long time ago from a model supply that no longer exists. That's unfortunate because it works really well and in fact I've never broken a wire yet after better than a decade of using it. It was expensive but now it's obvious that it was worth it.
1/32 stainless steel safety wire is widely available, cheap, and worked very well for me, I just like the inconel better.
Originally Posted by DoonRaker
ThermalSeeker,
What power supply setup do you use with that .020 Inconel wire? And where do you purchase the Inconel wire?
ThermalSeeker is online now Find More Posts by ThermalSeeker
Discussion will this work as a power suppy for a hot wire foam cutter NEWBIEHELI Foamies (Kits) 7 Jul 14, 2006 01:22 AM
Hot wire foam cutter power supply - Electrician needed!!! CactusJackSlade Foamies (Kits) 3 Jan 19, 2003 01:53 PM
Foam Cutter Power Supply Help Tim H. Electric Ducted Fan Jet Talk 23 Aug 14, 2002 07:56 PM
Versa pulse charger=foam cutter power supply Mikey-flies Foamies (Kits) 7 Feb 14, 2002 03:25 PM
Foam cutter power supply ronnath Foamies (Kits) 5 Nov 18, 2001 11:50 PM
