Old Nov 29, 2005, 01:34 AM
Slope Lift is offline
Find More Posts by Slope Lift
Slope Lift's Avatar
Long Beach
Joined Nov 2005
Question
Hot Wire Foam Cutter Power Supply?
Has anyone built or tried this? It's a schematic for a hot wire foam cutter.
Click on URL to see:
http://www.uoguelph.ca/~antoon/gadge...e/hotwire.html
Would like your opinions?
Robert
Slope Lift is offline Find More Posts by Slope Lift
Old Nov 29, 2005, 02:06 PM
lockheed martin is offline
Find More Posts by lockheed martin
Hello Moto
lockheed martin's Avatar
Auckland, New Zealand
Joined Mar 2005
the um link isnt working anymore? it was and now it isnt...
Aside from that small problem.
Looks like it will work just fine. You might want to put a trasistor in conjunction with a thermistor in the circut or a variable resistor in so you can control the heat that the wire is. As the link isnt working anymore I forgot the exact layout of where you could put it but I would say if you where to put them in, do so on the right side of the bread board. Sorry for the vagueness...
lockheed martin is offline Find More Posts by lockheed martin
Old Nov 29, 2005, 03:04 PM
MtnGoat is offline
Find More Posts by MtnGoat
Tu ne cede malis
MtnGoat's Avatar
United States, WA, Lyle
Joined Dec 2000
if you do choose to put in a resistor, you'll need to make sure it can dissipate the amount of energy you are putting through it, or you'll just smoke it.
MtnGoat is offline Find More Posts by MtnGoat
Old Nov 29, 2005, 06:12 PM
Hello Moto
Joined Mar 2005
lol yer make sure very much! I have a 12V hot wire cutter but hotwire cutters of the mains is a different story so as MtnGoat said be careful!
Old Nov 29, 2005, 11:39 PM
prplgoat is offline
Find More Posts by prplgoat
gas tires and oil
prplgoat's Avatar
malad, idaho
Joined Dec 2004
i've got a buddy that just hooked up a 110v dimmer switch,a 100watt bulb for a load and his cutting wire in a circuit,and it cut great!
set his temp with the dimmer.
cheapest way i guess!
marty
prplgoat is offline Find More Posts by prplgoat
Old Nov 29, 2005, 11:55 PM
Slope Lift's Avatar
Long Beach
Joined Nov 2005
A person with bare hands will get a good zap on that setup. You would probably need some type of insulating gloves to handle the cutter.
Old Nov 30, 2005, 12:23 AM
prplgoat is offline
gas tires and oil
prplgoat's Avatar
malad, idaho
Joined Dec 2004
i like a good zap on occasion!
ya, you'd have to insulate and be careful.
marty
Old Nov 30, 2005, 08:35 PM
ThermalSeeker is offline
Find More Posts by ThermalSeeker
United States, CO, Denver
Joined Sep 2005
If it's the do-it-yourselfer trying to get out..then go for it. I'm the same way and it looks like a fun project.
If just cutting a couple wings as cheaply is possible is the goal there's a much simpler way. Many moon ago when Burt Rutan and his company Scaled were still selling homebuilt airplane plans they had a little "How to" booklet to give confidence to the would be builder that he could actually do composites. The hot wire power supply in that manual consisted of two 12 v batteries in series to give a maximum of 24v available. (I used a 12v battery and a 12v battery charger..also Nick is right that you'll need to have a means to vary the heat that the bow creates for the length of foam you're going to cut.) To vary the heat on this set up you just need to add about five feet of safety wire (variable resistor) to one of the the battery connections that's going to connect to the bow. Run the safety wire in a zig zag fashion across a bunch of nails in a board left to right. Use an alligator clip to connect your bow to the battery on one end and one of the safety wire nails on the other. The further away from the battery you connect on the safety wire the cooler your bow will be.
I used this when I first started hot wiring long ago. Currently I use 13 to 15 volts on a 30 inch long core. I've used Nichrome wire but didn't like it, .030 stainless steel safety wire for many years with great success, but now like .020 Inconel even better. You might try something close to that for a starter.
I hope that helps,
MikeN
ThermalSeeker is offline Find More Posts by ThermalSeeker
Old Dec 01, 2005, 02:41 AM
Slope Lift's Avatar
Long Beach
Joined Nov 2005
Mike,
Which Inconel wire do you use or is best? The Black-Oxide or Silver?
Rob
Old Dec 01, 2005, 11:45 AM
Joined Sep 2005
Rob,
It's the silver..no black oxide coating. The reason I like it is because you can get the bow tension outrageously tight and it stays there even after the heat is on. This is the same stuff they use to make little fingers that go into jet exhausts to pull out the thrust reversers...thus can maintain it's mechanical properties when hot
MikeN
Old Dec 29, 2005, 11:20 PM
DoonRaker is offline
Find More Posts by DoonRaker
Flight Instructor
DoonRaker's Avatar
Aptos, CA
Joined Jan 2003
ThermalSeeker,
What power supply setup do you use with that .020 Inconel wire? And where do you purchase the Inconel wire?
DoonRaker is offline Find More Posts by DoonRaker
Old Dec 29, 2005, 11:37 PM
the_canuck is offline
Find More Posts by the_canuck
Where's the wind?
the_canuck's Avatar
Joined Jun 2004
You can pick up a bench supply from Ebay for around 100 bucks that is variable voltage and has a current limit. Mine goes up to 35Vdc at 5amps and cost me a $130 shipping included. It's digital display as well. Very easy to use and good for lots of other things like charging lead acids etc.
Andrew
the_canuck is offline Find More Posts by the_canuck
Old Dec 30, 2005, 12:40 AM
Flight Instructor
DoonRaker's Avatar
Aptos, CA
Joined Jan 2003
Will this work?
http://www.audio-warehouse.com/web/m...LAB/detail.asp
Old Dec 30, 2005, 10:01 AM
SkyKing RC is offline
Find More Posts by SkyKing RC
Minneapolis
Joined Feb 2004
Wire and power supplies
Hey guys no need to spend so much for a power supply. All you really need is a Variac which you can find on e-bay for between $20 and $60 and a transformer that is capable of 30 volts/5 amps or 42 volts/2.5 amps. These should cost no more than $20.
As for wire I sell Rene in .014 for $25 for a 50' spool which should last the average modeler a few years unless they are producing hundreds of wings. Rene is the best wire we've found and we've been using it for production for several years.
You can find it on our web site: http://skykingrcproducts.com/accesso.../renewire.html
Ed
SkyKing RC is offline Find More Posts by SkyKing RC
Old Dec 30, 2005, 11:53 AM
Flight Instructor
DoonRaker's Avatar
Aptos, CA
Joined Jan 2003
Moved to own thread... sorry to hijack.
http://www.rcgroups.com/forums/showthread.php?t=458482
Discussion will this work as a power suppy for a hot wire foam cutter NEWBIEHELI Foamies (Kits) 7 Jul 14, 2006 01:22 AM
Hot wire foam cutter power supply - Electrician needed!!! CactusJackSlade Foamies (Kits) 3 Jan 19, 2003 01:53 PM
Foam Cutter Power Supply Help Tim H. Electric Ducted Fan Jet Talk 23 Aug 14, 2002 07:56 PM
Versa pulse charger=foam cutter power supply Mikey-flies Foamies (Kits) 7 Feb 14, 2002 03:25 PM
Foam cutter power supply ronnath Foamies (Kits) 5 Nov 18, 2001 11:50 PM
