Old Nov 27, 2005, 04:33 PM
Twinboom is offline
Find More Posts by Twinboom
Semper Fidelis...........
Twinboom's Avatar
Madagascar, Toamasina, Atsinanana
Joined Dec 2003
Wetlap Fuse Layup
Well folks, here we go. Most of you do not know me. I have been with the ISR since it's second year. Due to many personal issues, I have not built anything in about three years. Things are changing, and I am getting back into building finally after a much overdue lay off. Dan Sampson and I have been working on the clubs latest project, and I will show you very briefly some shots of the process. I am no expert, but thought it would be a good thing to capture for those who know nothing about it. Like DutchyDawg, I have always done the two halve, tape method of joining. This was my first association with this type of layup, so keep that in mind as I share the process. I have never attached anything, or commentary on same before, so bare with me as I learn.
Twinboom aka. Doogie
Twinboom is offline Find More Posts by Twinboom
Old Nov 27, 2005, 04:35 PM
timmig is offline
Find More Posts by timmig
timmig's Avatar
Southern California
Joined Sep 2003
Cool Dougie!! It'll be good to follow ya through the process!! GOod to see ya back at it!!
Timmig
timmig is offline Find More Posts by timmig
Old Nov 27, 2005, 04:44 PM
Twinboom is offline
Twinboom's Avatar
Joined Dec 2003
more of the same
The next two pictures are the fuse with the glass all brushed down. One of the flush edges will be at the top, and the other at the bottom when the two halves are joined.
Doogie
Old Nov 27, 2005, 04:56 PM
Twinboom is offline
Twinboom's Avatar
Joined Dec 2003
Wetlapping
A batch of cavosil is made up, and then placed in a baggie. You twist it down tight to get rid of the air, and then cut the corner of the baggie off, just as if you were writing with frosting on a cake. You squeese it out in a thin line along the short side of the joint. It acts as bonding agent so to speak for the joints during the final assembly of the two halves, and pretty much fills any voids caused by newbies like me trimming the glass to short, or too long for that matter. The flap on the long side will lay down on top of the bead of cavosil.
Kind of getting the hang of this attaching process. The below three pictures show the bead of cavosil placed on the short side of the joint on each half. This enables a much cleaner, tighter joint, and pretty much visually removes the parting line from an outside view when the fuse is pulled out of the mold.
Old Nov 27, 2005, 05:11 PM
dutchydawg1 is online now
Find More Posts by dutchydawg1
dutchydawg1's Avatar
Nor. Cal.
Joined Jan 2004
Cool, I'm off the hook ! show us how it's done Dougie !!!
dutchydawg1 is online now Find More Posts by dutchydawg1
Old Nov 27, 2005, 05:22 PM
Twinboom is offline
Twinboom's Avatar
Joined Dec 2003
Wetlapping
The next set of pictures will be joing the two halves of the mold. This the most important step, as the last two hours of layup effort can be tossed if it is not done properly. Note the short side, and the overlap on both sides of the mold. It is self explanatory, but I will narrate a bit on the pictures.
The overlap side was trimmed down to between 1/4' - 1/2", but in my case more like 3/4". This is to allow the "lap" portion to lay across the short side once both sides are joined. This gives the appearance from the finished fuse after it is pulled out of the mold, as being one continuous piece of glass. Picture someone not familiar with the process scratching his head, or in TFLG's case, backside, wondering..how'd they do that?
Doogie
Old Nov 27, 2005, 05:25 PM
Twinboom is offline
Twinboom's Avatar
Joined Dec 2003
Wetlapping
Hey dutchy, I made a call to one MR. TAWG, he gave me the lowdown. Thanks for being on Standby though.
Doogie
Old Nov 27, 2005, 05:45 PM
Twinboom is offline
Twinboom's Avatar
Joined Dec 2003
Wetlapping
The following three pictures are of the two halves properly joined. Note the lap portion on each side sticking up a bit. They have not yet been " rolled or brushed " down at this point.
Also note the bolts holding everything together. After mate-ing the two halves, ALL of these attach points must be T I G H T so you can achieve a good seal. If this step is overlooked or fudged on, the parting joint will look more like a gully caused by rain run-off.
Doogie
Old Nov 27, 2005, 05:59 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Awesome, Doug.
Thanks for showing us this technique; I actually get it now!
And thanks again for Dutchy's fine documentation on the mold making process...
With the two of you guy doing this we common modelers stand a chance of making our own creations.
Thanks!
Target
target is offline Find More Posts by target
Old Nov 27, 2005, 06:03 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
One question-
How well cure is the glass in the molds when it's trimmed, and when its joined together in the molds?
Target
Twinboom is offline
Twinboom's Avatar
Joined Dec 2003
Wetlapping
These two are the rolling process. It is easier than you think. All you need is an opening at one end or the other. It can be done through the hatch only, but is much more difficult. Having a rear exhaust fuse/plane/subject, allows one to roll it from the back end. With a light shining down into the hatch, it is very easy to see thw whole joint line from the inside of this particular layup.
Doogie
Old Nov 27, 2005, 06:06 PM
Nor. Cal.
Joined Jan 2004
Nice !....
Old Nov 27, 2005, 06:09 PM
Twinboom is offline
Twinboom's Avatar
Joined Dec 2003
Wetlapping
Originally Posted by target
One question-
Target
It is not cured. You need to do it all in the same evening. The edges are trimmed whilst still wet, right after you have layed them in the halves. Use a good pair of scissors. You can dip them in some mineral spririts, or just wipe them off and hope they acn be used again next time.
Old Nov 27, 2005, 06:11 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
That's what I thought, thanks. Better to ask, not assume!
T
Old Nov 27, 2005, 06:20 PM
Twinboom is offline
Twinboom's Avatar
Joined Dec 2003
Wetlapping Epilog ( remember Hawaii Five-O )
So, that is it in a nutshell. I'm sure a more exhaustive thread could be done, but I think this covers it pretty good. The last picture is of your's truly on the buisness end of the roller. I hope this answers some of your questions. It has been a learning experience for me, not only in the actuall process, but in learning how this server works with attachments ect. If anyone needs any assistance over the net, or if you are close enough mile wise, just drop me a PM, or ask online for the benefit of all. If I do not know the answer, I will find it and get back to you.
Doogie
P.S. The most important part, I need to get a couple of JPG's of the final fuse out of the mold. My fuse is still at dan's place. As soon as I can get one of the ISR dudes to send me a couple shots of their fuse, I will post them. Dan does not have a digital camera. Be paitient, I will work this out. Thanks again for the space................
Question Guidelines for first fiberglass fuse layup (and some other molding questions)... Picoflyer Composites Fabrication 17 Dec 21, 2006 03:37 PM
