Old May 03, 2006, 09:40 AM
AmpAce is offline
Find More Posts by AmpAce
AmpAce's Avatar
North by Northwest
Joined Nov 2003
Stuart, Wow, that is very light! Good job!
I don't know how many amps your motor draws, but I would think 2 cells should fly her handsomely, no more than she weighs. If it were me, I'd probably like a little more than the 800 MAh capacity, for longer flight times, and a little less stress on the battery. Since you have the 800 MAh, I would just go ahead and try it, as long as the discharge rate is within the acceptable range for the pack. I've found that lipos last much better if you can keep the average draw well below their upper stated limit. For instance, if the cells are rated for 10C I would try to keep the draw below 8C, and 6C is even better.
Best of luck with that first flight!
AmpAce
AmpAce is offline Find More Posts by AmpAce
Old Nov 21, 2006, 09:40 AM
Stuart Warne is online now
Find More Posts by Stuart Warne
Durafly/Avios Brand Manager
Stuart Warne's Avatar
Australia, NSW, Sydney
Joined May 2001
Ok, restaring finishing my Cub but
Stuart Warne is online now Find More Posts by Stuart Warne
Site Sponsor
Old Nov 21, 2006, 09:47 AM
Joined May 2001
Ok, restaring finishing my Cub but I'm still stuck at the point of trying to find a good acrylic match for Olive Drab. I've tried all of the Tamiya paints and serveral others besides all claiming to be O/D or close to it or featuring the word 'Olive' or 'Drab Green'. And yet none of these look right when tested on the model. I best example of the colour I've seen is testor/models masters OD paint, but as far as I've been able to find out, you carn't get it in the UK. I would even consider buying from the state's if I could find a place that sold the correct colour in acrylic.
I realise there's a 'grey area when it comes to finding a true match for OD, but I'm hoping anyone here may be able to point me in the right direction because until I've spray the model and can progress no more.
Any info helpful as always guys.
Stuart
Site Sponsor
Old Nov 21, 2006, 10:07 AM
Work in Progress is offline
Find More Posts by Work in Progress
Light and floaty does it
Work in Progress's Avatar
Cambridge, Great Britain (UK)
Joined Sep 2004
It faded like mad, so could be almost any colour from greenish brown to almost tan. A lot of OD in the field was made by mixing a little lamp black into yellow zinc chromate primer, so you could try that if you fancy a little DIY.
Otherwise I'd recommend the Xtracrylics range from www.hannants.co.uk they have the current FS OD and the ANA one. One or the other they also do in a 'faded' tone.
Work in Progress is offline Find More Posts by Work in Progress
Old Dec 30, 2008, 07:00 PM
Joined May 2001
Just adding to my 'to-do' list as I now have a workshop again..... I will get this finished for the summer.
Stuart
Site Sponsor
Help! New Power System for my Piper Cub J-3! Pipercub18 Power Systems 0 May 16, 2006 09:14 AM
More room for the fuel tank in my Piper Cub...!!! JoeVen Fuel Plane Talk 15 Aug 05, 2005 10:38 PM
Sold Guillow Piper Cub RC conversion Ready to Fly RTF shschon Aircraft - Electric - Airplanes (FS/W) 2 Jul 19, 2005 01:50 PM
Herr Piper Cub Electric conversion help johnbob Parkflyers 7 Nov 05, 2001 11:21 AM
