Old Nov 25, 2005, 02:38 AM
rawy is offline
Find More Posts by rawy
e-powered foam
rawy's Avatar
swiss watch makers area
Joined Dec 2002
BBCC2 Guillows Super Cub 24" - 2 or 3 servos ??
Was searching this forum for a while now, came back with this Guillows 24" Piper Super Cub the other day, started the build largely inspired by some experiences described here.
As the pic shows I would be ready to start with the RC setup, LPS motor, Etec 2S1P 450mah, counting 3 servos (ail/rud/elev.) all the elements come to 110 g (Exc. covering, windshield, wheels, finish.)
Covering will be made with Graupner Ecospan, wheels incl. tailwheel are planned in bluefoam (3-4 grs incl. wires)
Found some Guillows Cubs in progress but not finished.... flying ?
Maybe some advice ??
Rawy
This dusty project is kindly accepted in the BBCC2 Contest
http://www.rcgroups.com/forums/showthread.php?t=1842080
rawy
rawy is offline Find More Posts by rawy
Last edited by rawy; Mar 29, 2013 at 09:24 AM. Reason: new title - Second Balsa Builders Conversion Contest
Old Nov 25, 2005, 10:03 AM
rawy is offline
e-powered foam
rawy's Avatar
Joined Dec 2002
2 Servos are in there !
The question was if it would not dramatically influence the flight abilities adding the weight of a 3rd servo, I was a post fm Warren Jones where he describes a mixing of ailerons with rudder but i'm dreaming of "glissade finals" like on the fullscale cub owned by a buddy
I could save the job and weight if an experienced Guillows builder & flyer out there could tell me more about the flying & approx. AUW !
read in one thread that a 24" Guillows should be below 180 grs. which seems
haevy to me already ?
Old Nov 25, 2005, 03:00 PM
willfly is offline
Find More Posts by willfly
Will fly some day
willfly's Avatar
Brampton, ON
Joined Dec 2003
nice build.
willfly is offline Find More Posts by willfly
Old Nov 25, 2005, 04:03 PM
jamesgood72 is offline
Find More Posts by jamesgood72
jamesgood72's Avatar
United States, CA, Nevada City
Joined Aug 2003
Hi Rawy,
Looks like a very nice cub you have there!
I would personally keep it with 2 servos, and maybe even drop down to a 250mAh pack. I did my Guillows Fairchild 24 like that.
http://www.rcgroups.com/forums/showt...8&page=9&pp=10
http://www.virtualaerodrome.com/hang...32&p_user_id=1
Flies very nicely, but keeping that weight down is the #1 thing it seemed to me. I think mine came out at 96g. Control authority is still very good with rudder, but no ailerons.
Cheers, good luck with your cub.
-James.
jamesgood72 is offline Find More Posts by jamesgood72
Old Nov 25, 2005, 09:23 PM
Matt D. is offline
Find More Posts by Matt D.
Matt D.'s Avatar
Greensboro, NC
Joined Jul 2002
Nice Job Rawy,
Keep the pictures coming. I agree with James, go with the 250mah pack, you will save about 12 grams, a lot for this plane. Of course if you are using that motor direct drive then it will fly with the 450mah and the 3rd servo, it will just be fast.
Matt
Matt D. is offline Find More Posts by Matt D.
Old Nov 25, 2005, 10:43 PM
sgtdirt is offline
Find More Posts by sgtdirt
Mentor, OH
Joined Dec 2004
i built this plane for free flight rubber band. i had all intentions to convert it to Eflight. if i was to do it over i would :
1. remove every other wing rib.
2. renenforce the cowel area.
3. make laminated tail feathers (it's going to be tail heavy if i don't)
i covered mine with coverlite. it added less than nothing to the AUW.
sgtdirt is offline Find More Posts by sgtdirt
Reply With Quote  (Disabled)
Old Nov 26, 2005, 01:13 AM
lrsudog is offline
Find More Posts by lrsudog
Go get them Meg!
lrsudog's Avatar
Cabin 21...
Joined Jan 2001
If you can squeeze the extra servo in without too much weight, why not?
Cubs don't have a lot of dihedral (None), so unless you add some in a la freeflight like Sgt Dirt did, rudder only may be a problem.
That kit is a great one, BTW. I've lost two of them thermaling OOS in freeflight. Nice build.
lrsudog is offline Find More Posts by lrsudog
Old Nov 26, 2005, 01:55 AM
rawy is offline
e-powered foam
rawy's Avatar
Joined Dec 2002
James & Matt, I agree with the 250mah Lipo(9 grs), there's other 10-12 grs I should be able to remove cutting all the excess lenths in wires...removing the receivers case !
It always seemed easyer for me to gain weight on the hardware than slicing balsa, anyway I decided to remove every fraction excess weight.
Sgtdirt, the tailfeathers are very light already, 1gr for the rudder, 2.6 grs the stab before covering.
Irsudog, it's exactly what I was thinking at, if there is a way to fly it with scale dihedral (none?), keeping the weight in a range that allows correct flying abilities, I go for the ailerons solution.
Ideas for a light aileron linkage ??
Will post some pics tonight, made a weight check last night 114 grs before the above mentionned mods, could end up under 100grs...!
Old Nov 26, 2005, 08:08 AM
rawy is offline
e-powered foam
rawy's Avatar
Joined Dec 2002
2 hours for 1,1g
but I must agree it is nice to build with balsa !
Started carving the wings out between the ribs, long job but gained 1 gr.
the small slots on the rudder 0,1 gr.
Still could not decide the ailerons linkage, would like to go for carb torque rods
(or should I say: I do no want to go for the metal wire ?)
the other aspect is that the cockpit is empty now & I wouldn't like to have this visible servo atop of it
Pull-pull ? what hinges ? how do you hinge with torque rods ' other systems ??
rawy
Old Nov 26, 2005, 09:02 AM
sgtdirt is offline
Mentor, OH
Joined Dec 2004
very nice sanding job. how about tape hinges.
you may be able to cram the servo above the window and into the wing and make your linkage go from there.
Old Nov 26, 2005, 11:18 AM
AmpAce is offline
Find More Posts by AmpAce
AmpAce's Avatar
North by Northwest
Joined Nov 2003
Rawy,
Great build, very nice airframe!
You could probably hide the aileron servo in the wing center above the cabin. There are some really small, light servos available nowadays, so the weight penalty shouldn't be that great. It would be a shame to fly a beautiful Cub like that without ailerons. You can just do so much more with them, as you well know by your mention of the "glissade finals".
I agree with you about using cf torque rods, although I would use some very small cf tubing, it's lighter and stiffer in torsion than the rods.
As for hinges, I would either use small ca hinges or preferably cut down the smallest plastic hinges you can find.
AmpAce
AmpAce is offline Find More Posts by AmpAce
Old Nov 27, 2005, 04:54 PM
rawy is offline
e-powered foam
rawy's Avatar
Joined Dec 2002
aileron hinges & linkage
Hi all,
thanks SgtDirt & Ampace, photos do not show everything & the so often mentioned quality of guillows balsa reveals with nice cracks when sanding the fuselage...
Did the aileron cutout, the cut or hinge line is not strait mmmhhh !!!
Will go this way http://www.rcgroups.com/forums/showp...&postcount=230
Concerning the linkage I'm almost convinced to go...pull-pull...
Was thinking about a linkage going thru the wings with a wooden spring returning to neutral or slightly down in case of trouble, a secondary loop arranged in the cockpit in order to place the 3rd sevro in the lower quart of cabin under pilots seat...theres plenty of ideas coming sanding balsa...
The servo placement under the wing in the upper back of the cabin does not attract me because in flight you always have this servo in sight mmmhh !!
the reason why I do not like the piano wire/plastic tube system is because of the short cord will result in a very short radius in the wing which in my opinion is too much energy & weight for an ugly result (steep angle toward horn)
Fullscale has pull-pull - lets study pull-pull
will have to study my geometry books once more,
Sadly have to put this little bird away for two weeks due to work, the photos of the actual progress are not so good, will post some more early next week.
Would enjoy to have some posts about "wired" aileron experience & I wish all of you a good start into December !
rawy
Old Nov 27, 2005, 05:23 PM
lrsudog is offline
Go get them Meg!
lrsudog's Avatar
Cabin 21...
Joined Jan 2001
The lightest and most trouble free aileron linkage would be the Dubro (catalog #850) micro torque rod aileron system. You might have to substitute a bit longer wire instead of the supplied torque rods (Because the Cub's ailerons are pretty far out on the span) but it comes with everything you need for around 4 bucks. For a light plane, this is perfectly adequate.
The aileron servo would be mounted upside down between the wings, with the linkage inside the cabin. Might be a little tricky since you cabin is already built, but it would only add maybe 3-5 grams to the plane, plus the servo of course.
*edit* After looking again at you structure pix, the aileron servo could easily be mounted behind the wing, and would be hidden once the Cub is covered.
Old Nov 28, 2005, 12:59 PM
rawy is offline
e-powered foam
rawy's Avatar
Joined Dec 2002
pull - pull
There's some sanding to do again, will have time to think about where to hide that servo...
A lower servo position would allow to gain weight again, reducing the cable lenght..,I plan to solder the cables on the receiver, remove the case etc.
Was watching James video again and got haevily motivated to go
l i g h t
Basically I love the pull-pull complications...all my builds have p-p tailfeather linkage mostly modified from the plan, sometimes hidden in the fuselage (Beaver), or double rudder (K+WC36) on pull-pull thru center of fuse with cf rods to rudders.
But never made pull-pull ailerons & the aspect of ailerons trouble in flight makes one allergic to fuzzy systems
there's some sanding to do again...
rawy
Old Nov 28, 2005, 01:31 PM
Joined Aug 2003
Gasp, MY video? I'm honoured!
Looking forwards to seeing yours take to the air.
-James.
Wanted Need 2 or 3 HS-50/55 Servos teddtech Aircraft - General - Radio Equipment (FS/W) 1 Jun 25, 2005 02:42 PM
WTB 2 or 3 hs-55 micro servos Kyle G. Aircraft - Electric - Airplanes (FS/W) 0 Mar 18, 2004 07:24 AM
WTB - hitec 2 or 3 ch. AM rx and servos mikebarg Aircraft - Electric - Airplanes (FS/W) 3 Dec 14, 2003 11:41 PM
ESC question 2 or 3 servos? bcripe1 Power Systems 6 Jul 22, 2003 04:38 PM
GWS Tiger Moth Xmas sale get 1,2 or 3 Capt. Dave Aircraft - Electric - Airplanes (FS/W) 21 Dec 22, 2001 08:35 AM
