Old May 28, 2002, 05:20 PM
Timmy is offline
Find More Posts by Timmy
Timmy's Avatar
Ogden Ut
Joined May 2002
DJ aerotech Roadkill
I was thinking of getting one of the roadkill series planes but I was going to ask if any one has had any problems with them? Are they good fliers? Also I fly in my street and was wondering if they are pretty durable or do they break pretty easy?
Timmy is offline Find More Posts by Timmy
Old May 28, 2002, 06:03 PM
Achim Stegmeier is offline
Find More Posts by Achim Stegmeier
Joined Dec 2000
They are extremely fragile! A hard touch or a litle push breaks the plane. Especially the wings are fragile. Most damage happened to mine during transport and on the workbench.
But, it's a very nice design and a good flyer, although not especially slow. Depending on the size on the gymnasium it's a rather exciting experience. My Zero weighs RTF 70g. YMMV
Achim
Achim Stegmeier is offline Find More Posts by Achim Stegmeier
Old May 29, 2002, 07:07 AM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
I'd agree with Achim. I built the Spitfire and it is fragile. Some people have used CF rod down the side of the fuselage to stiffen it. If I had it to do again, I would use the laser cut fuselage sheet as a template to cut out a 1/2 inch thick bead foam slab. Sand it to a taper at the tail, and then skin it with two 1/32 contest grade balsa skins and and plank the top and bottom perimeter with the same. I used this technique for my Fokker Dr1 fuselage (still under construction, see my site below). After sanding to smooth everything out and reduce weight a bit more this results in a very light semi-profile fuselage that is not all flexible like a Road Kill fuselage. Paul Bradley, noted builder of profile planes, wrote in this month's AMA magazine that a friend of his has been using this foam core technique as well. One other advantage is the servo that is placed in the middle of the fuselage can now be recessed in with only the servo arms protruding, which looks nicer (best to do this before skinning).
In general from what I've read, and my own experience with the Spitfire, the WWII road kill planes tend to fly somewhat fast with wing loadings that are not exactly low. I think this is not as much of a problem with their new WWI planes (which I think would still lend themselves to the foam core fuselage technique). I'm thinking about bringing my Spitfire out of semi-retirement and fitting it with two of the 135mAh LiPoly cells. The voltage of two of these cells should be similar to a 7-cell pack of 120 NiMH, but should dramatically reduce the wing loading since two of them would weigh about 19g less. I haven't calculated what the wing loading will be yet, but it would have to be better.
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old May 29, 2002, 07:28 AM
Dave Wulff is offline
Find More Posts by Dave Wulff
Dave Wulff's Avatar
USA, FL, Fort Lauderdale
Joined Feb 2002
Gordon,
I have also been thinking about thick profiles, just enough to hide the gear. Hadn't thought about foam though, could you give a better description of the type of foam you used?
Dave W.
Dave Wulff is offline Find More Posts by Dave Wulff
Old May 29, 2002, 08:52 AM
Boston, Mass
Joined May 2001
Dave,
It's just some slabs of that expanded bead white foam that came with something I bought and I saved it. I don't know if it is heavier or lighter than, say, blue foam because it's the only foam I have. A hot wire would cut it cleaner than my knife. Sanding it tapers it at the tail pretty good. It's not perfectly smooth when shaped, but I've found it doesn't matter because when skinned that's all covered up. I wrote down weights for my Dr1 as I made it. I'll look them up and post them. Also, to glue the balsa on I use 3M Photo Mount spray which is either lighter or comes out in a finer mist than 3M77. I mist it on from about 3 feet above the foam in just the lightest dusting. It's heavy and doesn't take much at all (the hardest part is to make yourself use very little glue). One other thing, start to finish on the fuselage took less than 30 minutes. A couple of pictures of the fuselage are on my Dr1 page.
Technically, there is some foam in this plane, just not Depron, and not where it can be seen.
Old May 29, 2002, 09:26 AM
Dave Wulff's Avatar
Joined Feb 2002
Gordon,
Thanks for the info. Until I get a better idea of what size & weight limits are, I would rather not spend alot of time on a built up fuse.. 30 minutes sounds good to me. I guess as long as the foam can't be seen it really isn't harmful.
Dave W.
Old May 30, 2002, 07:46 AM
Boston, Mass
Joined May 2001
Dave,
See my Dr1 thread. I've put weights there (not complete yet)
FS:DJ Aerotech RoadKill Fokker Dr1 Tim Wolff Aircraft - Electric - Airplanes (FS/W) 9 Aug 22, 2003 03:50 PM
DJ Aerotech roadkill kits???? raythomas Scratchbuilt Indoor and Micro Models 4 Oct 25, 2002 11:01 AM
DJ AeroTech Roadkill P-38 rc capo Parkflyers 0 Aug 04, 2002 03:46 PM
DJ aerotech Roadkill flight reports? cheapflyr Parkflyers 0 Jul 01, 2001 09:12 PM
DJ aerotech roadkill indoor WW2 planes? CheetDawg Parkflyers 33 Jun 29, 2001 11:43 AM
