May 28, 2002, 04:06 PM
Norfolk, England
Joined Sep 2001
Darren,
Use one ESC and one battery pack. The effect on the current drain will depend on how you wire the motors. Wired in series, that's two + leads from the ESC to the two motor + teminals, and two - leads from the ESC to the motor - teminals, you will, in theory double the curent draw, but get much more power than from a single motor. Each motor 'sees' all the cells in the pack.
Parallel wired motors are totally different. Run the ESC + to the + of one motor. run the - of that motor to the + of the other motor, and the motor - to the ESC -. Think of it as a complete loop. This leaves current draw at roughly what it would be for just one motor, but reduce the power of both motors since each is only 'seeing' half the pack.
How you wire them all depends on the amount of power your model will need, compared to what duration you need. A faster model, with less duration gets wired in series, whereas a slower, more floaty model can often be wired in parallel for longer flights.
This is a very basic description, only trial and error will determine your individual needs. That, or a good computer program to work it all out.
Pete
