Old Nov 23, 2005, 12:47 PM
seidstep is offline
Find More Posts by seidstep
Joined Aug 2004
Lead Acid (Pb) Charger Needed to Charge Pb
I'm into RC planes, but have an RV with a 12 volt battery which needs to be charged during the winter. I have another spare 12v deep cycle to charge from which I can take home and charge back up. I have a generator, but it takes hours of running to perform the charging task, meanwhile I'm sitting at a storage shed waiting for eternity. I'm pretty sure that the Schulze and Orbit could do the job. Are there any other chargers that would charge a 12v lead acid from a 12 v lead acid?
seidstep is offline Find More Posts by seidstep
Old Nov 23, 2005, 01:12 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Triton
Charles
Old Nov 23, 2005, 01:18 PM
seidstep is offline
Joined Aug 2004
I had forgotten that one. Was hoping the ICE did, but can't find it in their specs.
Old Nov 23, 2005, 04:52 PM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Orbit Microlader will do it.
Gene Bond is offline Find More Posts by Gene Bond
Old Nov 28, 2005, 12:33 PM
seidstep is offline
Joined Aug 2004
Any Other Way?
I suppose I could do this with an inverter and a regular battery charger. Any idea of what size I would need for say a 2 amp charge?
Old Nov 28, 2005, 04:54 PM
TMorita is offline
Find More Posts by TMorita
San Carlos, California, United States
Joined May 2002
Maybe I'm missing something, but why not just swap the two batteries instead of charging one from the other?
Toshi
TMorita is offline Find More Posts by TMorita
Old Nov 28, 2005, 07:03 PM
Southern Pride
For some reason he wants / needs to charge an RV battery without AC without running a power plant or the RV. Jumper cables from a car, truck SUV etc. should do the trick if the battery is toped off regualrly. If it were mine I would just remove it for the winter and keep it on a battery minder.
Charles
Old Nov 29, 2005, 09:27 AM
seidstep is offline
Joined Aug 2004
Reasons
If I don't leave it in I can't start the generator which most places will tell you should be run once a month and put under a load even then. I suppose I could have taken it out and then used jumper cables from the battery up to the supply cables, but didn't. No way to get the battery out now. The storage wall is right on the battery door, so I can't get it all the way open.
I wouldn't consider this option if I weren't going to use the charger for my hobby as well.
Discussion can the astro charger charge lead acid batts? rmasu Batteries and Chargers 7 Apr 10, 2007 09:31 PM
For Sale Accusense lead acid battery charger ptxman Aircraft - Electric - Batteries & Chargers (FS/W) 1 Sep 13, 2006 10:26 PM
Is a Pb battery a Lead Acid battery? Nik-rc Batteries and Chargers 1 Jul 21, 2004 09:35 AM
Need Lead-Acid battery charger recommendation ElectriFan Batteries and Chargers 19 Nov 20, 2002 08:43 PM
Running charger on mains with 'car charger' and 12V lead acid battery? Ben C Power Systems 7 Jun 08, 2001 08:56 PM
