View Poll Results: Which one in a WemoTec MiniFan???
Mega 15/25/2 - NOT 16/15/2 !! 6 46.15%
HET-RC 2W-20 7 53.85%
Voters: 13. You may not vote on this poll
Old Nov 23, 2005, 01:22 AM
punkindrublik is online now
Find More Posts by punkindrublik
multirotormania.com
punkindrublik's Avatar
United States, CA, North Highlands
Joined Sep 2004
Question
WemoTec MiniFan - 16/25/2 vs 2W-20
Well, I've got an EAM F-15 with 2 minifans that's goin together SOON
Here's my dilemma.
There's 2 HET 2W - 20's mounted in the fans right now.
I've got 2 Mega 16/25/2's sitting NEXT to the fans.
Which pair do I use?? I haven't bought lipos or ESC's yet as I want the best performance and figured I better decide on motors first.
ANY input appreciated.
Thanks!
Brian
punkindrublik is online now Find More Posts by punkindrublik
Site Sponsor
Latest blog entry: NEW MRM 130mm FRAMES!
Old Nov 23, 2005, 01:47 AM
like2fly! is offline
Find More Posts by like2fly!
who dares wins
like2fly!'s Avatar
London,England
Joined Apr 2005
Hi Brian, you've probably seen it but just in case you haven't, netmechanic just finishing details of his new eam F15 with 2W-20's http://www.rcgroups.com/forums/showthread.php?t=429056
'Paul DF jet man' is building a twin with the 16/25/2's on 5s in minifans, can't rem which bird though
alex
like2fly! is offline Find More Posts by like2fly!
Old Nov 23, 2005, 02:02 AM
multirotormania.com
Joined Sep 2004
Yeah, I've been following the F-15 thread. I'll look for the other.
Thanks Alex!
Brian
Site Sponsor
Old Nov 23, 2005, 02:26 AM
who dares wins
like2fly!'s Avatar
London,England
Joined Apr 2005
i do remember the cells. using the 16/25/2 going for a lightweight set up he was using 5s 2500 PQ XP packs which weigh 320g.
and now using http://www.flightpower.co.uk/proddet...p?prod=4200015 which are very similar performance cells. I spoke to flightpower they said there sonic welded, and that they are made for them by the same people in korea who make the PQ XP's
Alex
Old Nov 23, 2005, 02:49 AM
multirotormania.com
Joined Sep 2004
Holy C-Rating Batman!
Site Sponsor
Old Nov 23, 2005, 03:09 AM
who dares wins
like2fly!'s Avatar
London,England
Joined Apr 2005
at 20C i'd guess they'd need a Serious amount of cooling! but for example with the 16/25/2 on 5s you'd be running 14C static at full throttle as the motor is ~35amps in a minifan on 5s. so comfortable and according to Paul whose started using them performance is good http://www.rcgroups.com/forums/showp...&postcount=115
Alex
back to topic
Old Nov 23, 2005, 07:13 AM
Paul DF jet man is offline
Find More Posts by Paul DF jet man
MORE POWER IS THE KEY
Paul DF jet man's Avatar
South Australia
Joined Jun 2004
Thanks Alex
yes the 16/25/2 is the way to go for sure.
Im using two of them in an A-10 on two 5s PQ 2500 XP packs draws about 34 amps per motor which is nothing really. But im getting 1.2 kg of thrust per fan. REALLY good intakes help as well.
I am also nearly ready to fire up my 1.8 meter long SR-71 black bird using two 16/25/2's but im going to run them on 6s 1p 3700 flight power li-pos. They are rated at 74 amps continuous and i think i will be drawing about 75-76 amps with the voltage drop. this will boost power and reduce the weight however throttle management will be needed.
I have some of the FP li-pos and they have impressed me 100% im running a 1200 3s at 24 amps thatís 20C and the 9v cut will only come in after I have used 1150 mlh. thatís awesome performance.
So to answer your question go the 16/25/2ís and either on 5s 34 amps or 6s 40-42 maybe (havenít tried 6s yet) but will soon.
Paul DF jet man is offline Find More Posts by Paul DF jet man
Old Nov 23, 2005, 12:56 PM
multirotormania.com
Joined Sep 2004
Suuweet, good info
Thanks Paul!
Brian
Site Sponsor
Old Nov 29, 2005, 02:57 PM
Chrigi is offline
Find More Posts by Chrigi
Switzerland, St. Gallen
I search a powersetup for my Savage Su-27, so how much thrust did the mega gives with 6s?
Is that a problem for the Motor? too much amps?
Chrigi
Chrigi is offline Find More Posts by Chrigi
Old Nov 29, 2005, 04:10 PM
netmechanic is offline
Find More Posts by netmechanic
Watts the Point
netmechanic's Avatar
KY,USA
Joined Jul 2004
Another viable option would be the 16/20/2 on 4S. That will give you roughly 625 watts in the minifan and save a little weight on batteries. My F-15 flies fine @ 1/2 - 2/3 power on my 1400 watt 2W-20 setup. The main difference is the price of the motors. Since the Mega is a more efficient motor the actual output power is probably about the same for both.
netmechanic is offline Find More Posts by netmechanic
Old Nov 29, 2005, 04:39 PM
multirotormania.com
Joined Sep 2004
Yeah, I saw those. Their supposed to be the "perfect" motor for the MiniFan.
BUT, I gotta use the 2 16/25/2's in front of me
Thanks!
Site Sponsor
Old Nov 29, 2005, 06:35 PM
South Australia
Joined Jun 2004
Chrigi
OK that 75 amps is an estimate for both motors !!!
The mega should be fine on 6s and if its on its own li-po it could draw about 40- 42 amps. You would obviously have to use throttle management ect and definitely let the motor run on 10% throttle for 1 minute after every landing to let the motor cool down.
As for thrust I havenít measured it yet im sorry but when I do I will let you know.
Old Nov 29, 2005, 06:36 PM
South Australia
Joined Jun 2004
thanks for that mate but i alreay have 4 of the mega 16/25/2's her so i better use them LOL.
Help! EDF-2W-25 vs Mega 16/25/2 magnito High Performance 1 May 13, 2007 11:19 AM
Help! EDF-2W-25 vs Mega 16/25/2 magnito Power Systems 1 May 13, 2007 10:55 AM
For Sale WemoTec MiniFan w/ NEW MEGA 16/25/2 punkindrublik Aircraft - Electric - Power Systems (FS/W) 8 Feb 23, 2006 02:42 AM
Looking for Hacker C40-15T, Mega 22/20/2TDS or 16/25/2. j911brick Aircraft - Electric - Helis (FS/W) 0 Oct 24, 2004 12:03 PM
New Mega's 16/20/2 and 16/25/2 for ducted fan Jones Boy Electric Ducted Fan Jet Talk 3 Mar 09, 2004 04:40 PM
