Old May 28, 2002, 07:12 AM
die fleidermaus is offline
Find More Posts by die fleidermaus
die fleidermaus's Avatar
Newton, Ks., USA
Joined May 2001
What's going on with this battery?
I use four different battery packs when I go out to fly.
Three of them work great, but one pack never seems to work right.
When I use the bad pack, the motor will run about 5 seconds and then it stops completely. After about one second it comes back on again. If I manage to keep it in the air it will continue this routine many times. When it is squirting out electrical snot it has plenty of power.
What is likely wrong here? Is there a way to test this battery? What do I check? Can I check individual cells without unsoldering them? About the only tool I have is a digital vom.
The pack gets evenly warm during charging and the voltage never checks very low, although I know that can be misleading.
1,000 mah nicd, 8 cells
sp 400 motor
Zagi (Aveox) esc
Feather receiver
die fleidermaus is offline Find More Posts by die fleidermaus
Old May 28, 2002, 08:06 AM
tekochip is offline
Find More Posts by tekochip
tekochip's Avatar
West Dundee, IL, USA
Joined Jul 2001
The best test is to put the pack under load with a small resistor, if you have one, and then measure the voltage on each cell. You'll probably find one or two that are low, or even reversed (polarity in wrong direction).
If you don't have a high power resistor you can use a bunch of small onew in parallel, or just leave the resistor in a cup of water to keep it cool
tekochip is offline Find More Posts by tekochip
Old May 28, 2002, 10:37 AM
jeddy11 is offline
Find More Posts by jeddy11
England
Joined Apr 2002
My thought is to check the conector on the battery,i had a battery the same with a bad connector and that done the same,the battery sounds allright as when it works it works...i think my battery didn't charge properly with the bad connector either so i cut it off and soldered a new one on and it is now fine.
jeddy11 is offline Find More Posts by jeddy11
Old Jun 30, 2002, 12:36 AM
DaveW is offline
Find More Posts by DaveW
Folsom,Ca,USA
Joined Apr 2001
I would guess it has a bad cell.
Measureing each cell individually with your VOM, under load, should isolate the flaky cell.
Also check connector for bad continuity etc.
It isn't magic, if it doesn't work, either a cell is bad or the connector is.
From symptoms, I'd bet on one bad cell. Remember, the other 3 work fine. Maybe comparing readings between good pack and bad one whould help find problem.
You aren't using Tamiya connectors are you?
They're not suitable for E flight, bad continuity.
Dave
DaveW is offline Find More Posts by DaveW
What's going on with Berg receivers & ESCs? electroman7 Power Systems 4 Jun 27, 2005 04:21 PM
what's going on with my electronics? AkshunJebus Foamies (Kits) 11 May 15, 2005 08:11 PM
What's going on with ESCs? Tinfoil Parkflyers 5 Oct 15, 2004 05:26 PM
Rant What's Going on with my Microjet?? Helicool Foamies (Kits) 4 Oct 13, 2003 04:08 PM
What's Going On With The Canadian Postal Service dr.E Life, The Universe, and Politics 10 Nov 14, 2002 10:18 PM
