| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#31 |
V-tail swallow
Here are the bones for my Gym Swallow v-tail project. I next have to cut the stab in half and set the 110 degree vee. Then I'll cut the "elevator" portion and trim so I can get both up without bumping together. Next will be the arrow shaft fuse and its pylons and servo mounts. Slow but sure progress...
I'm also trying to hack the snap connections off an 8 cell battery box so I can put some decent batteries in the Optic 6. WARNING to Optic 6 users: even if this works I understand from the Hitec forum that the battery use counter only goes to 199 minutes and then rolls over to 0. Not a major deal but another minor aggravation. I'd be happy to get enough battery capacity to encounter that problem. 80-90 minutes the absolute best I can get on the stock NiCd pack. Rob |
#32 |
Honey, I got more planes!
Rob, I used a dremel tool and ground the posts down on mine. Then I soldered the leads to it. It's a booger to get it plugged in with that big pack though.
#33 |
Gary,
You are way ahead of me. I was just reaching for my Dremel to get the small contact down. The other was easy to remove. Maybe the end result will be worth the trouble. I couldn't find a pack with wires on the internet. Rob |
#34 |
Slow Is Sweet
Jon,
I've been spending a considerable amount of time lately on the RC Groups "DiddleBugs Scale Style" thread. It is easy to get bitten by the Diddle bug. Go to http://www.rcgroups.com/forums/showt...&page=44&pp=15 and check out the ingenuity of those guys. My post with pictures of my Mini Diddle MAX is on page 44. Find the Diddle Champ on page 29 along with .pdf plans. But don't overlook page one so you can see how all this got started. A bit of a warning may be in order. Once you start reading this thread, it is hard to stop. Frank |
#35 |
I guess it's too late, but Radio shack sells connectors like these. I have extras, if you want any.
#36 |
Frank,
Thanks for the details and the link. I'll be reading. Beautiful Mini Diddle MAX. Wow! Jon |
#37 |
Beware Rob! When the friction warms things up, the plastic starts to melt. Make sure you position them right, before the plastic sets.
#38 |
When's the next fly-in?
Rob, I'm no aeronautical engineer, but I do remember reading something about v-tails in a magazine a while back. There is some complicated ratio to getting the right tail surface area from just two surfaces as opposed to three. It looks like your new stab is just a copy of the original horizontal stab that you plan to cut in half. It might be too small. Granted on little bitty models like this, it probably doesn't make much of a difference...just thought I'd put the bug in your ear.
![]() afterthought: (rusty gears turning a little more) I think it had something to do with "projections" of the conventional tail surfaces to make the new v-tail surfaces. OK, I'll quit before I hurt myself. Last edited by dee-grose; Nov 28, 2005 at 11:41 PM. Reason: added more ramblings |
#39 |
Jon, I think the issue is that there isn't room for such a connector on the end of the little battery holder. I haven't tried it, but I think that is what Gary said.
#40 |
Andy,
The v-tail is not an exact copy. I scaled it up so the total surface area is the same as the stock tail feathers - about a factor of 1.3 scale factor. I'm sure there is a fancy equation somewhere but I think this will be pretty close. The Swallow is extremely stable and seems pretty forgiving. Frank and I have fiddled the wing design pretty significantly and they still fly. The proof is in the flyin'. We'll see how she does. Rob |
#41 | |
The Flash radios take the Radio Shack box perfectly but not the Optic.
#42 |
Thanks for the battery clarification. Sorry about that.
About the v-tail sizing, here's an article my Mark Drela, and aero prof at MIT. The article assumes you have a conventional tail you want to convert to an equivalent v-tail. Quick V-Tail Sizing |
#43 |
Slow Is Sweet
Jon,
Thanks. There are some good build reports, flight reports, and great pictures posted. They are a cheap, simple, relatively quick and easy build. Flight is confined areas is easier with a small plane. Frank |
#44 |
Jon,
Thanks for the link. I guess my instincts were correct since " A_vtail = A_vertical + A_horizontal " is exactly what I used. No rocket science in that I even checked to make sure that the control surface areas added up to the same. I'll have to check the relative areas of the tail feathers to calculate the angle. I have already glued up the canonical 110 degree angle but it will be interesting to see how close this comes. " angle = arctan[ sqrt( A_vertical / A_horizontal ) ] " Thanks again. Rob |
#45 |
Frank,
Can these Diddle planes be landed at places like NG or the tall grass where I've seen you guys fly? Do they require a parking lot to land? Jon |
| Thread Tools | |
| What's on your building board this winter? | Steve85 | Scale Electric Planes | 40 | Feb 11, 2007 11:28 AM |
| Discussion What's on your workbench? | himszy | Submarines | 21 | Jan 01, 2006 01:25 PM |
| What's on your backburner? | Raymund Reyes | Slope | 31 | May 21, 2004 02:34 AM |
| What's on your garage floor | SPEED-E-FLYER | Electric Plane Talk | 32 | Feb 08, 2004 09:06 PM |
| WHat's on your building table? | Tram | Parkflyers | 62 | May 30, 2003 12:32 AM |
