Old May 27, 2002, 10:46 PM
JoeR is offline
Find More Posts by JoeR
USA, NY, Jamestown
Joined Jun 2000
Dremel bit or other for cutting CF plate?
Any idea which one will cut CF and last of a significant period of time? I would like to be able to route out a part in .030 " CF plate. Other ways to make small parts from flat stock? Thanks
JoeR is offline Find More Posts by JoeR
Old May 27, 2002, 10:54 PM
davidfee is offline
Find More Posts by davidfee
davidfee's Avatar
San Diego, CA, USA
Joined Mar 2001
For limited use, the cut-off wheels are ok. If you want it to last, or especially if you need to cut complex shapes, then a diamond cutter is what you need. You can get them cheap at a place like Harbor-Freight. http://www.harborfreight.com/
Have fun!
-David
davidfee is offline Find More Posts by davidfee
Old May 28, 2002, 07:27 AM
DaveSawers is offline
Find More Posts by DaveSawers
Canada, NS, Lunenburg
Joined Oct 1999
But watch out for that carbon dust. NASTY STUFF!
DaveSawers is offline Find More Posts by DaveSawers
Old May 28, 2002, 09:20 AM
Stregone is offline
Find More Posts by Stregone
Stregone's Avatar
Manassas, VA, USA
Joined Feb 2002
Yup, definitly do it outside or something and wear a dust mask! A good idea if you have to do it inside would be to strap down a shopvac hose right next to where you are cutting. It should suck up most of the dust, especialy the dust in the air. But still wear a mask!
Stregone is offline Find More Posts by Stregone
Question Axi (or other for that matter) motor advice for several models, please. WarrrEagle! Foamies (Kits) 2 Mar 20, 2006 01:58 PM
Question Best Dremel Bit For Cutting CF??? Minimole Composites Fabrication 24 Aug 02, 2005 12:41 AM
Source for Premade CF Plate n0jvt Electric Heli Talk 2 Nov 02, 2002 11:54 PM
Ant tips or tricks for cutting a foam P-47 wing? kit basher Power Systems 0 Oct 28, 2001 09:23 AM
Best place to find replacement coroplast or other for Zagi winglets? 177ichael Electric Plane Talk 5 Jul 08, 2001 10:24 PM
