Hmm well either I can follow your plane with mine or if you wanna make a second canopy with space for a camera, I can stick something small fhere
Latest blog entry: SS FPV Maiden
Hey did you get a chance to try the batteries?
Adam, here's the pictures of my launcher. The servo operates a holdback latch which releases the pin that holds the ring on the bungee. This means that the servo sees absolutely none of the 15lbs load that the bungee exerts on the launcher. It's also very reliable as there's nothing for anything to catch on during release. Servo is hooked up to the plane using a connector. This is pulled loose the second the plane begins moving forward. A switch on my tx activates the servo. I also use two ropes to hold down and stabilize the launcher.
here's my latest video, went out to 4 miles and did some tree top flying on the way back.
Thanks! Thats Sandwich, IL. Nothing but cornfields for as far as the eye can see. Next flight will be to 5-6 miles.
Oh Adam, this last video, I included a lot of clips from my FPV camera with the 6mm lens so you can see the resolution. I would never have flown that close to the tree with a 3.6mm lens. I could make out every branch, even no leaves. |
| Thread Tools | |
| Chicagoland Parkflying F.I.B. Part 11 | ashdec87 | Chicagoland ParkFlyers | 5285 | Nov 21, 2005 03:27 PM |
| Chicagoland Parkflying F.I.B. Part 10 | Kyle G. | Club Talk | 503 | Dec 26, 2004 11:44 AM |
| New Forum Suggestion: Chicagoland Parkflying F.I.B. | Kyle G. | New Forum Requests | 1 | Dec 19, 2004 04:35 AM |
| Chicagoland Parkflying F.I.B. part 9!!! | Joe Ford | Club Talk | 514 | Dec 15, 2004 09:45 PM |
| Chicagoland Parkflying F.I.B. part 8! | Kyle G. | Club Talk | 521 | Dec 02, 2004 12:10 AM |
