Old Nov 18, 2005, 11:49 PM
Argyle is offline
Find More Posts by Argyle
Wind is the devil.
Argyle's Avatar
Joined Aug 2005
Decent setup for first 3D foamie?
Sport Flyers Wild Fly 3D Kit - Without Motor - $25
BP 8Y Outrunner Brushless Motor & Castle Creations Thunderbird-18 Brushless
Speed Controller (TB-18) Combo - $51.22
Blue Bird Micro $20 (dont know much about receivers tbh, more range would be nice)
Dymond 2000mah 11.1v 3C Lipo $35 (might upgrade to TP as I have been impressed with their quality and performance so far)
3x HS-55 Servos - $50
BP 8Y:
Direct Drive 1047
11.1V
10.9A
Thrust: 21.5 oz / 602 grams
Flying Weight: 12-15 ounces (very rough guestimate...)
Right under $200
Argyle is offline Find More Posts by Argyle
Old Nov 19, 2005, 10:50 AM
Argyle is offline
Wind is the devil.
Argyle's Avatar
Joined Aug 2005
Any advice would be appreciated, even if you only tell me that I havent a clue to what I am talking about...
Old Nov 19, 2005, 11:31 AM
MustangAce17 is offline
Find More Posts by MustangAce17
EDF Addicted
MustangAce17's Avatar
United States, FL, High Springs
Joined Sep 2005
your battery choice is way to big to start with. You only need a most likely a 1050maH at tops and thats all. A 2000 is heavy for this type of plane, ill give you an example of a very nice set-up currently flying a Multiplex Microjet and the weight is only 12.38 ounces! it pushesd through the sky at around 70 or 75 i believe pretty quick for the retention pond i fly it in. Heres my setup--- battery, TANIC 1050 mah(holds voltage better than older thunder power 15c coming soon i believe) bl-8(Flatouts) esc, and Electrifly Rimfire motor had this setup on a hell raiser one time and performance was awesome also have a few TP 730's but dont give to much flight time and the tanic is better. IMO
MustangAce17 is offline Find More Posts by MustangAce17
Discussion recommendations for first 3d setup snowcrash75 3D Flying 3 Feb 11, 2006 06:50 AM
Good setup for a first time 3D'er Mr Associated 3D Flying 1 Mar 18, 2004 09:07 PM
Question What is the best setup for pigi 3D RickNick Foamies (Kits) 4 Mar 09, 2004 04:15 PM
Good setup for a first time GWS flyer saitrix GWS (Grand Wing Servo) 0 Jan 19, 2004 11:02 AM
Best Brushless for T-3D Foamie?? Flying Low Parkflyers 7 Oct 12, 2003 12:30 PM
