Old Nov 18, 2005, 10:36 PM
Cincinnati Cin N.Knty, Ohio, United States
Joined Sep 2004
Throttle servo moves when elevator servo is moved
Like the title says, my throttle servo moves when I move the elevator stick on my radio. It just started doing this tonight. At first I thought it was just one plane, but tried my other one and it does the same thing. My radio is a Futaba 7chp. When the elevator stick is moved, the throttle servo moves about a quarter of an inch, and moves a different direction depending on which way you move the stick. Any suggestions will be appreciated.
Chris
chris8105 is offline Find More Posts by chris8105
Old Nov 18, 2005, 10:59 PM
Cho Oi! Hay Qua!
tomi's Avatar
Here
Joined May 2003
have u tried reseting the Parameter to Aerobatics?
It sounds like theres a MIX that is enabled..
-Tomi
tomi is offline Find More Posts by tomi
Old Nov 18, 2005, 11:35 PM
Joined Sep 2004
I checked all the mixes, they are all inhibited.
Old Nov 18, 2005, 11:39 PM
Deletedfor proving Nauga wrong
Joined Mar 2005
there's also a strange inter-relation in some computer radios such that when one pot starts going bad it affects other channels.
Life expectancy of a pot in a TX is anywhere from 5 min to 20 years... MTBF (mean time between failures... look at it as the time before the FIRST pot should fail) appx 9 years. You can be the unlucky guy and have it fail while first testing a TX... (but then it would be replaced under warrantee)
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Nov 18, 2005, 11:55 PM
Cho Oi! Hay Qua!
tomi's Avatar
Here
Joined May 2003
Did you try a different model number? If it's still doing that, I'd send it in
Old Nov 19, 2005, 12:06 AM
Joined Sep 2004
Yea I tried it on different model numbers, looks like I will be sending it to Futaba to have it checked out.
Old Nov 19, 2005, 09:59 AM
Joined Sep 2004
Anybody know what the turn around times is from when they recieve my tx and I get it back?
Old Nov 19, 2005, 12:37 PM
God's gift to mankind for flying anything.
Joined Aug 2004
Sent my series 8 back for some dumb thing. Got it back within one (1) week.
If it is not warrantee, there is a cost involved. Go to their site and get all the info first, like a return policy etc.
HTH.
indoruwet is offline Find More Posts by indoruwet
Old Nov 19, 2005, 02:56 PM
Joined Sep 2004
Dpending on what Futaba tells me after they recieve my Tx, if it can be fixed and if buying a brand new one will be about the same price as if they fix my old one, what is the difference between PCM and FM? I seen on Towers website that a FM radio is a little bit cheaper than a PCM. All I fly is planes, no heli's, just wondering what the difference is and which one is better.
Old Nov 20, 2005, 02:21 AM
Cho Oi! Hay Qua!
tomi's Avatar
Here
Joined May 2003
Most of the high end radios are equipped with selectable PCM. In order to use PCM you need to have a PCM RX. They cost a bit more.. But they clean out any RF noises and keeps the signal clean. I own one on my heli, but I feel that I dont need any for my planes. Unless my plane is like $1500 or more..
-Tomi
Old Nov 20, 2005, 06:47 AM
N1EDM's Avatar
Brockton, MA
Joined Nov 2003
Do you happen to have an 'open' spot on your tx for another plane? Just as a test, try loading your plane into that spot after you make sure that that spot has been reset. I agree that the fault seems to lie in the tx.
Also, swap the throttle with, say, the elevator servo lead. I'm assuming that the problem will move to the elevator servo.
Yeah, I agree with Tomi, that it seems like the tx is acting as if it's in heli mode on power-up, or something like that...
I'd be interested in finding out what your test and/or Futaba says.
Bob
N1EDM is offline Find More Posts by N1EDM
Old Nov 20, 2005, 09:04 AM
Joined Mar 2005
PCM doesn't really clean out rf noise... It uses a digital "encryption" instead of a pulse proportional signal. the digital signal is easier for the RX to check if interference has made a "frame" invalid or not. There's a small computer chip in the RX which stores "failsafe" and "last valid" servo position information. the computer compares the new frame with the last valid and with a check of the digital encoding. If the checks fail in just one frame, then the RX does nothing (servos stay at the last valid positions). If the checks fail for a programmed numer of times within a programmed length of time it sends the servos to the failsafe positions.
A PPM (FM) RX has no logic check and a bad frame goes straight to the servos. a single fram can only move the servos so far due to servo travel speed, so the controls "jump" and buzz. many bad frames in a short time wil send the servos to whatever positions the RX interprets as correct.
actually both PPM and PCM signal encoding can be AM or FM. ANd you can have single conversion or dual conversion signal processing for noise filtering in either RX type.
PCM does not really filter out interference... it rejects bad data. In a way its like the dofference between someone randomly marking all the "T" boxes on a true-false test and someone that actually reads the questions, and sees that a few should be "F" instead of "T" (but the rest are all True...). The one that reads the questions is going to get more answers right. (with right answers being seen as good servo response)
Old Nov 20, 2005, 11:31 AM
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
I send stuff to Futaba, with an explanation of what I think is the problem, my VISA number, and tell them to fix it.
It seldom take long, and any replacements are usually billed at 50% of market value which is much lower than buying a replacement.
There's no need to have snail mail or phone messages involved this way.
It's cheaper to send it back and get it fixed than to buy new.
Sometimes the fixes are free.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Nov 20, 2005, 12:45 PM
Joined Sep 2004
N1EDM, tried all that, tried with two different planes, and tried with a reciever that wasnt in a plane, tried different model numbers on the Tx, reset a model number and tried it and it did the same thing. I would say its definitely the Tx. Futaba support is emailing of things to try with the Tx. I will let you guys know what the problem was when it is fixed.
Old Nov 20, 2005, 08:23 PM
N1EDM's Avatar
Brockton, MA
Joined Nov 2003
Good luck with it, Chris. We'll be interested in finding out what is causing this.
Bob
Badnit elevator servo Bill Franke Electric Sailplanes 18 Feb 14, 2002 11:52 PM
Where did you mount the elevator servo in the Twister Al P High Performance 12 Jan 02, 2002 07:28 AM
Falcon elevator servo ramhornrctjd Electric Sailplanes 12 Aug 02, 2001 01:02 PM
MiG 15 Elevator Servo wtghost1 Electric Ducted Fan Jet Talk 2 Jun 20, 2001 07:03 PM
F5B Elevator Servo ? LJH Electric Sailplanes 10 May 23, 2001 08:51 PM
