Small FPs need brushless (power) and lower pitch stiff blades to fly in wind. This means more head speed to fly (better stability) and improved responsiveness. Shortening the flybar a little helps - and using 2mm piano wire instead of CF.
Like90 blades work well in wind up to 10 mph in my experience... more experienced pilots fly in more wind than this. Biggest challenges is getting the heli back down - banked turns are the only real option as backing off the throttle just kills HS and makes the rig unresponsive. ... and then you move to a small CP. Trex in my case. Generally I check the weather and I don't go to the field if its more than 12- 14 mph, but I've flown in 20mph with gusts. Flies fine but landing can be interesting. |
. Haven't measured the head speed, but in theory it should be a little above 2600, so it's probably 24-2500 in practice. Pitch is -10 to +10, I always fly in Idle Up to get used to it, and only use normal mode to spin up and down on the ground.
Wind makes for great fun as long as the heli is strong and
controlable enough. I had my 2nd flight with my shogun in good 15mph winds. Was gonna rain and I couldnt wait to get a flight in. Took it out and took off, got alot of bobbing up and down and found myself constantly on the collective. Flew straight into the wind most the time for a more easy simple flight. Im still new and have yet to get used to nose in flight. I dunno though. Ive always looked forward to some wind as long as I dont break anything. When learning inside my uncles body shop I used to fly against the fans with my Eco Piccolo with a Astro 10 and 3-1 board. Funs stuff but all comes down to the helis control authority against the wind imo. Be carefull guys, A Mayday is the last thing ya need.
| Thread Tools | |
| Where do you fly your micro heli? | TheX | Micro Helis | 37 | Sep 09, 2007 04:20 PM |
| what reciver do you trust in your micro heli | heliguy1232 | Micro Helis | 7 | Jan 27, 2005 05:07 PM |
| How much does your micro heli weigh? | zman12000 | Micro Helis | 8 | Jan 15, 2005 10:20 AM |
| Cool How well acn you fly in the wind? | Starguard | Fuel Plane Talk | 20 | Sep 21, 2004 05:06 AM |
| How warm do your 2/3 A 1000 Nimh's get ? | Al P | Electric Plane Talk | 1 | Oct 02, 2001 09:31 AM |
