Nov 27, 2005, 03:03 PM
USA, TX, Diana
Joined Aug 2005
Contender Build - Continued
Got shorted 2 48" pcs. of basswood for wing, so I elected to go on with fuselage. This is what I've done in about the last 4 - 5 hrs. Also, began
gluing up the wing tips. I am going to use the optional upswept tips.
I assembled the motor to a Sullivan rubber isolated motor mount and
checked hole alignment on the yet uninstalled firewall. I plan to turn the engine 90 degrees to the right which will put the muffler running at the right lower corner of the fuselage. Exhaust will be between the main gear.
It appears that I will have to lower engine approximately 1/8" from pre marked holes. I will be using a OS .61 FX which is within the specs of this kit. I am hoping I can do this. My only concern is: will it affect the thrust line? I
believe I will be able to mount the tank inline with the spray bar, ok. Once
I get the wing built and I can assy. the wing, fuselage and gear to the plane I will make the final decision.
I did add some tri-angle stock behind each former for strength. That modification and the modification to the rudder is all that I have changed
so far. I do intend to stretch out the aleirons another 1/2" which will
require that I stretch the wing tips an equal amount. No Big thing.
Attached are 2 pics. of progress, today.
Anyone have any tips, suggestions or comments, they would be
appreciated by this novice.
Jim Vines
AMA 821369
