Benoit Paysant Le-Roux Edge 540T
I just wanted to share some pictures of a project I finished for the JR Inoor Meet. This is a pretty neat model and flies extremely well, and best of all, it looks like a baby Edge! It has a built-up depron fuselage and is very light.
For equipment, I chose an Electrifly Rimfire and Electrifly 8-amp esc, Futaba 3108's all around (4 total), and a Futaba 6-channel PCM receiver. I've logged many hours of flight-time on this airplane and have had a blast each flight! I can practice mini-IMAC routines and it excels at 3D maneuvers. You will find that this model is a good cross between a foamy and a glow-powered airpane in flight characteristics. It has very neutral flight characteristics, and when rolled into knife-edge flight, it needs only a few percent of rudder-to-elevator mix. I built it completely stock and only changed the hardware. I used hardware from Ikarus (a link is available on my other Thread entitled "ETOC..."). I also reinforced where all of the control horns mount to the control surfaces using pieces of a CA-Hinge. I cut the hinge in half and glued it to the foam using odorless CA. Then, I drilled the two holes needed for the Ikarus horn to be mounted to the surface. This really strengthens the foam in critical areas like this. Enjoy! Best Regards, JPG
If you look at the picture that has my Edge's bottom view, you'll see a black velcro strip right in front of the landing gear mount (the CF landing gear rods secure onto the wing, and my battery mounts on the wing right in front of the landing gear). I'm not sure wear the instructions say to mount it, but it will differ from model to model (depending on the battery pack size, etc). If you play with the battery pack height and placement within the fuselage, you can minimize "pitch" in knife-edge for any model. First just try a spot where your model balances, then fly it. The great thing with foamies is that you can experiment and "fine-tune" your airplane in a flight...and some extra velcro ![]() I will post a picture in the near future of the "mods" I did to mine. The changes I did (only two) were to: 1. Increase rudder authority 2. Add drag to the airframe (since it is a monoplane) Best Regards, JPG |
Joined Jan 2004
thanks john,that is real slick with the rudder,i would have never thought about that. !!!!!!! i cant wait to try that one. will that work on any mono wing ? will that mod slow down any plane that does not have a slow flight in knife? cool, thanks raul, oh and what is that little tee looking thing in front of the rudder on the top of the fuse ??
The little "booster" on the top of the rear turtle-deck adds rudder authority to the model. I did not want to change the looks of the model drastically, and doing this did the trick on my airplane. Now, rudder authority is greater than it was without it. This has caught on in Europe and Asia on pattern models, mainly with Christophe Paysant Le-Roux using it on his F3A model. You'll have a lot of fun with this airplane. Regards, JPG |
Joined Jan 2004
wow john , your just as bad as me !! your on this site every second of the day. the booster looks cool , but how does it work ? it doesnt move does it?i just cant understand how that helps the rudder? were can i see it on those paysant planes?? those europeans always beat us to everything. smart dudes.
The "booster" increases side area of the fuselage (slightly) and also directs airflow to the rudder (this increases the rudder authority). As far as Christophe's airplanes, check out www.znline.com Regards, JPG |
Joined Jan 2004
christophe has some nice planes, the little rudder booster looks nice on his plane and it looks like he just won another championship. must be nice. thanks for the help john, im waiting for my order from hobby lobby, its on back order but at least i got it on special.good luck with your flying, se ya raul, have you flown one of these, real good flyer
Hi Raul,
Sorry it took me awhile to get back to you; I was pretty occupied with school as I had semester exams last week. I have not had the chance to fly one of the Inferno's from Hobby Lobby. I have heard many good things about the airplane. From the video on the HL website, it looks like a great F3A-I model. Feel free to post your set-up for others to see. Your model looks great! Happy Holidays, JPG |
| Thread Tools | |
| Help! Christophe Paysant-Le Roux | bird of wonder | Fuel Plane Talk | 0 | May 06, 2008 02:10 AM |
| Cool xtra 300 benoit pasant le roux plans! | zibobman | 3D Flying | 4 | Feb 26, 2004 11:53 AM |
| EDGE 540T Electric conversion | Dave Wenzlick / Slickraft | Sport Planes | 3 | Mar 07, 2002 11:38 AM |
