Old Nov 17, 2005, 08:22 AM
davereap is offline
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
Two brushless motors with one ESC is this possible
Ive seen the jinx video, but always thought that two motors with one controller wouldnt work, how does this one work and does anyone else have any experience with this kind of setup. Please post your thoughts and links here
davereap is offline Find More Posts by davereap
Old Nov 18, 2005, 01:27 AM
Iain is offline
Find More Posts by Iain
Amateur Helicopter Goader
Iain's Avatar
Kirkland, WA
Joined Jul 2002
Yes - but only if the motors and controllers are identical. The controller uses feedback from the de-energized winding of the motor's coil to sense where it is - so you can imagine how confusing having TWO motors providing feedback, possibly at different times might be! On my 2 brushless camera ship, I chose the 2 ESC route
HTH
-Iain
Iain is offline Find More Posts by Iain
Old Nov 18, 2005, 01:56 AM
Larry3215 is offline
Find More Posts by Larry3215
Permanently Banned
Larry3215's Avatar
Gig Harbor, Washington, United States
Joined Sep 2003
There have been many reports of succesfull use of two brushless motors on one esc.
There have been many reports of it NOT working too.
Obviously the Jinx folks are getting it to work.
The ESC makers will tell you NOT to do it.
The risk is if one motor fails to start you will get very hi currents thru the esc. Its a big possibility you could let the smoke out
I prefer one esc for each motor.
Larry
Larry3215 is offline Find More Posts by Larry3215
Old Nov 18, 2005, 02:10 AM
Albert_Moto is offline
Find More Posts by Albert_Moto
Aerofever.net
Albert_Moto's Avatar
Hong Kong Intl, Hong Kong
Joined Aug 2004
http://www.rcgroups.com/forums/showthread.php?t=420577
Albert_Moto is offline Find More Posts by Albert_Moto
Old Nov 18, 2005, 02:49 PM
radfordc is offline
Find More Posts by radfordc
radfordc's Avatar
United States, KS, Lansing
Joined Jan 2002
Here is a picture of two motors running on one esc. The motors are kit built Komodo Hobby CDR motors and the esc is a CC P-25. I was careful to build the motors exactly alike and connect them to the esc identically. The motor start reliably and run in perfect synch. They have been flown in the bomber model many times.
radfordc is offline Find More Posts by radfordc
Old Nov 18, 2005, 03:19 PM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
Clearly some people have put together combos that work, but others have had problems with this. The most common problem seems to be that one motor starts and the other doesn't -sometimes- on startup. If it's a plane that will always fly under throttle then this may not be an issue for you, if both motors don't start you just throttle off and back on until they do, then take off. But if you might be shutting the throttle off and on while flying, it could get ugly if only one motor starts. Luckily BL ESCs are really coming down in price, so using 2 isn't such a big outlay of cash these days.
Tres Wright is offline Find More Posts by Tres Wright
Old Nov 18, 2005, 03:47 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
If you want to shut your motors down in flight, just have some height... then if it's getting picky about starting, point the nose down, get the props windmilling... and then put some throttle on. I'm sure this would start them. Was done back in the good old days of aviation when motors weren't all that reliable.
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Nov 18, 2005, 05:17 PM
radfordc is offline
radfordc's Avatar
Joined Jan 2002
Actually, I found the opposite to be true. When I first tried flying my motors I had the esc set to "soft brake". When I shut down the motors they kept windmilling and for some reason they would not restart in the air. They restarted fine on the ground.
I reset the esc to "hard brake" so that the props would stop in the air and they have restarted OK ever since.
Charlie
2 brushless motors with one ESC? Danny Troy Power Systems 20 May 08, 2011 03:08 PM
Two brushless motors off one ESC? Justin Felce Power Systems 4 Dec 19, 2005 01:09 AM
Two Brushless Motors on one ESC Chrisbee Power Systems 1 Sep 21, 2005 07:59 PM
Twin brushless motors with ONE ESC is it possible for MY E-STARTER TWIN ? agapornis Power Systems 3 Jun 05, 2005 11:45 AM
Question two( ore more) brusless motors with one esc? sigve Power Systems 9 Nov 04, 2004 07:03 AM
