Old Nov 16, 2005, 07:04 PM
Joined Nov 2005
Problem, Problem, Problem
I am very new to electric park flyers but I built my plane, bought a Futaba 6 channel skyport, battery, engine, esc, servo, receiver, and when I put it all together......nothing. I can not get my Feigao 4 channel receiver and Futaba transmitter to talk. I have checked all connections and the esc lights up, but nothing. Ready to throw in trash and find a new hobby. Any help is appreciated.
tomytomy is offline Find More Posts by tomytomy
Old Nov 16, 2005, 07:17 PM
Auburn Ga.
Joined Feb 2004
To many things it could be
Find out for sure that the Feigao RX and the transmitter are on the same band,
Do you have a club or group that fly close to you that can help you check it out.Most will be happy to help
Milton
Milton is offline Find More Posts by Milton
Old Nov 16, 2005, 07:20 PM
aeropal's Avatar
Joined Jan 2003
Is there any servo response at all when the receiver is energized . . even just a momentary servo "twitch"?
aeropal is offline Find More Posts by aeropal
Old Nov 16, 2005, 07:35 PM
Maineiac63's Avatar
Blissfield, Michigan
Joined Apr 2005
DON"T give up now over such a trifle. This is to great a fun hobby to quit so easy!! Use the reciever that came with the Skysport and all should be right
Maineiac63 is offline Find More Posts by Maineiac63
Naturally altered
Joined Feb 2005
Could be a number of things, but a faulty rx crystal comes to mind.
Cubber is offline Find More Posts by Cubber
Old Nov 16, 2005, 07:37 PM
Twist n' Shout!
Matt Dziubinski's Avatar
Joined Nov 2004
same shift? RX needs to be on the negative shift to be compatible with the futaba skyport you have.
Unless its the feiago model that auto detects shift
Matt Dziubinski is offline Find More Posts by Matt Dziubinski
Old Nov 16, 2005, 10:07 PM
Joined Apr 2004
I would be it is ashift problem too. You need and "F" type receiver
WolfeWind is offline Find More Posts by WolfeWind
Old Nov 17, 2005, 12:15 PM
Oldie but goodie
Popsflyer's Avatar
At the Flying field
Joined Jun 2003
Receiver "Shift" must be compatible with the TX.
Receivers and crystals also come in "single conversion" or "dual conversion" depending on the manufacturer (Hitec is one), they must also match.
Obviously the crystals must be on the same frequency. The crystal must also be of the brand and type recommended by the receiver manufacturer.
Lastly if you've changed the crystal in the Transmitter to a different channel, it may not function at all (experienced this before).
Popsflyer is offline Find More Posts by Popsflyer
Old Nov 18, 2005, 04:36 AM
smurf's Avatar
Texas
Joined Jan 2005
If all else fails and you don't have a club close by, take everything to your local rc hobby shop and they should be able to help you.
smurf is offline Find More Posts by smurf
Discussion Blade CX yaw problem (old problem), blacken motors? bambino Coaxial Helicopters 30 Feb 05, 2008 12:38 AM
Help! please help with my "problem after problem" problem chopperdudes Micro Helis 2 Apr 12, 2007 05:32 PM
motor problem? esc problem? strat919 Electric Plane Talk 7 Apr 11, 2005 05:08 PM
Gy401....problem......weird problem.... :- ( thazy2 Electric Heli Talk 3 Oct 15, 2002 01:21 PM
JETI ESC questions; motor cut-off problem jbrundt Electric Plane Talk 12 Apr 25, 2001 12:29 AM
