Old Nov 16, 2005, 10:30 AM
bill II is offline
Find More Posts by bill II
Joined Nov 2005
Building a Flower
Hi All,
Static Boat Model Builder doing a Scale RC Boat.
I have a Mabuchi Motor (measures 1-1/2" X 1" Dia.), and plan to run it w/ 7.2V Battery Packs in parallel, or a 6V Battery...not sure which is best for long run time, easy charging, etc...Hum, I have more questions.
So which ESC w/ Reverse do I use?
I don't want to fry the ESC or Motor.
Thanks for the Help,
bill II
bill II is offline Find More Posts by bill II
Old Nov 16, 2005, 11:15 AM
Old 8140 is offline
Find More Posts by Old 8140
"Old 8140"
Old 8140's Avatar
Arizona Via NH
Joined Mar 2005
I have used the Futaba - 20+ turns with sucess.
http://www2.towerhobbies.com/cgi-bin...?&I=LXUY13&P=0
Jim
Old 8140 is offline Find More Posts by Old 8140
Old Nov 16, 2005, 11:27 AM
bill II is offline
Joined Nov 2005
Jim
Hi Jim,
Thanks for posting.
I was looking at Tower...lots of choices there.
Futaba MC230CR ESC w/Reverse 20+T
Operates motors that are 20 turns up to 27 turns (Stock Motors).
Wonder how many turns my little Mabuchi motor is?
Regards,
bill II
Old Nov 16, 2005, 11:32 AM
martin richards is online now
Find More Posts by martin richards
Useful Idiot
Asturias, Spain
Joined Mar 2001
Unless it's got some macho name labelled on the can and has exposed brushes' it's unlikely to be outside your range. It's probably a bog standard 540.
martin richards is online now Find More Posts by martin richards
Old Nov 16, 2005, 11:53 AM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Take a look at the Hitec EZX-R at Tower... less $$, works fine. You want to avoid race car ESC's that have odd reverse action- many require a stab of the "brake" (reverse), then release, then reverse again before ESC's reverse actuates.
Others actually time out reverse after a few seconds to protect hot "timed" motors. EZX-R has plenty of amp capacity, simple reverse, and it's cheap.
Pat M
patmat2350 is offline Find More Posts by patmat2350
Old Nov 16, 2005, 11:58 AM
bill II is offline
Joined Nov 2005
Hi Martin,
Thanks for Posting.
My Mabuchi motor measures 1-1/2" X 1" Diameter.
I have a Mabuchi 540S in box (which is why I know what that one is- lol)...it measures 2" X 1-3/8" Diameter...lots bigger and heavier.
It's much more Motor than I need for scale speeds on my model.
I'd like to use the little Mabuchi, matched w/ appropriate ESC w/ reverse.
These are older motors...back a few years, as I understand, they were popular motors, perhaps no longer so.
Cheers,
bill II
Old Nov 16, 2005, 12:11 PM
bill II is offline
Joined Nov 2005
Pat M
Hi Pat,
Thanks for the Reply.
I like the price.
What does Motor Limit: 23 Turn mean?...Motor has to be 23 turns are greater...no top limit on the turns it can have?
I take it my little motor has a lot of turns?
Cheers,
bill II
Old Nov 16, 2005, 01:13 PM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
Motor power (and current draw) are governed by how many turns of wire go around each armature pole... fewer turns of fatter wire offers lower resistance, thus more amps flow, generating more torque. Many turns of finer wire do the opposite. You can have two identically sized motors with entirely different characteristics, depending on design.
And it makes a big difference going from, say, 27 turns of 20 gage wire to 25 turns of 18 gage.
Pat M
Old Nov 16, 2005, 03:24 PM
bill II is offline
Joined Nov 2005
Pat M
Hi Pat,
Well ok, now we're getting somewhere.
My little motor has 3 sets of "fine" wire turned around each...not sure how many turns though.
High resistance-low amp flow-low torque motor here.
So, is the Hitec EZX-R is safe to use w/ this puppy?
bill II
Old Nov 16, 2005, 03:46 PM
Useful Idiot
Asturias, Spain
Joined Mar 2001
Woops sorry, 1 1/2" x 1 1/8" is a 400 size but triple wound sounds very strange (it lowers resistance even more than using 1 strand of wire 3 times the section) however, the number of turns relates to the number of times the wire(s) are wound round each pole of the armature.
Anyway from your description it looks like http://www.mabuchi-motor.co.jp/cgi-b...AT_ID=rk_370sd or many other similar types of the same dimaensions.
Old Nov 16, 2005, 05:37 PM
bill II is offline
Joined Nov 2005
Hi Martin,
Thanks...I think you're in the ballpark...I leaning towards an old 380.
Small Print says Mabuchi...so a least that's right.
The wire end is black plastic w/ 8 wagon wheel like spokes.
At anyrate...I'm just trying to get an idea of what's a safe ESC to put w/ it.
Cheers,
bill II
Old Nov 16, 2005, 08:51 PM
tim slocum is offline
Find More Posts by tim slocum
tim slocum's Avatar
Central Missouri,USA Along the banks of the Missouri River
Joined Jun 2005
Hi Bill II
I suppose your the Bill II from Steel Navy forum?Hello there.Predreadnoughts rule!!!What kind of ship/boat are you trying to power?What size/scale is it?I just recently purchased a Proboat Classic Runabout,which is a 29in.boat.Well it has a 550 or 540 size motor and I use a 1700mah 7.2v battery.The boat came with a speed control that was forward only, so I swapped it with a Proboat esc. with reverse.It is waterproof and has been very reliable so far.I cant remember the model number though.Bye.
Tim
tim slocum is offline Find More Posts by tim slocum
Old Nov 16, 2005, 10:39 PM
bill II is offline
Joined Nov 2005
Hi Tim,
So this is where you went...when you gonna start back building warships again?
It's a 1/72 Matchbox Corvette, something quick & easy...all my other projects are taking to long...I need to get something in the water, before I go into withdrawls...you know.
It's hard not tweaking it out...it won't be pretty built out of the box, but hey, it'll float!
For my ESC, I think I'll go w/ the Hitec EZX-R.
My motor already has capacitors on it, so think I'm OK.
Guess I better get started on it.
Pre-dreads rule my friend!
All the Best,
bill II
(Dream Model- 1/100 Good Hope)
Old Nov 17, 2005, 03:58 AM
Bobslr is offline
Find More Posts by Bobslr
Kitchener Ontario Canada
Joined Jan 2005
Hi
Sound's like you've got a 380 motor.
As to the ESC check out this web page it has exactly the info your looking for.
http://members.shaw.ca/modelflags/tips/flower.html
Bob
Bobslr is offline Find More Posts by Bobslr
Old Nov 17, 2005, 09:20 AM
bill II is offline
Joined Nov 2005
Originally Posted by Bobslr
Hi
Bob
Hi Bob,
Thanks for posting
I've got it already...great article.
Prob is, I can't find the Hitec/RCD SP-610RF mentioned in the article.
Hoping the Hitec EZX-R is the newer improved version.
I think it's worth a try.
I'll let everyone know if my boat blows up.
Cheers,
bill II
Motor / PCM Recvr / 32 AMP ESC - Do I need Capacitors? ShellDude Sport Planes 7 Nov 19, 2002 04:52 PM
Which mods do I need? Bajazz Parkflyers 0 Sep 03, 2002 08:46 AM
Which mods do I need? Bajazz Foamies (Kits) 0 Sep 03, 2002 03:17 AM
Which ESC do you like the best? cloudhopper Electric Plane Talk 6 May 25, 2002 11:39 PM
Which Radio do I need? Pork Tornado Parkflyers 6 Aug 08, 2001 04:51 AM
