This thread is privately moderated by new flyer, who may elect to delete unwanted replies.
Old Mar 26, 2008, 08:49 PM
Bing44 is offline
Find More Posts by Bing44
Bing44's Avatar
United States, OR, Independence
Joined Feb 2008
Originally Posted by new flyer
if any newbies don't understand a term used on rcg or in any flight situation post the term here and i will find and post what it is or how it works
snip
Explain 3D and how it applies to helis.
Bing44 is offline Find More Posts by Bing44
Old Mar 29, 2008, 02:43 PM
new flyer is offline
Find More Posts by new flyer
go flyin or die tryin
new flyer's Avatar
grafton, West Virginia, United States
Joined Jun 2004
3d is a broad term really all it means(to me at least) is being able to fly in about any considarable direction. for instense, foamies are 3d becaose they can fly upside down right side up knife edge hover. if you can think it they can pretty much do it with a heli i would say cp not fixed blade for high manuverability and then you could also go inverted. so if a heli has good power to weight ratio and collective pitch it would in my books be called 3d.
new flyer is offline Find More Posts by new flyer
Old Mar 29, 2008, 06:56 PM
No Limits is offline
Find More Posts by No Limits
Airforce Nut
No Limits's Avatar
Littlestown, Pennsylvania
Joined Sep 2007
I'm not really new but what does OBO mean in the sales forums?
-CJ
No Limits is offline Find More Posts by No Limits
Old Mar 29, 2008, 07:06 PM
Laggard is offline
Find More Posts by Laggard
Wind blows
Laggard's Avatar
Minneapolis
Joined Jan 2007
or best offer
Laggard is offline Find More Posts by Laggard
Old Mar 29, 2008, 07:58 PM
Airforce Nut
No Limits's Avatar
Joined Sep 2007
duh, I should've figured that out on my own
-CJ
Old Apr 07, 2008, 10:27 AM
pumpthejam is offline
Find More Posts by pumpthejam
Joined Apr 2008
What do you use pull-pull systems for?
Here's a link to one: http://www.allerc.com/product_info.p...roducts_id=216
pumpthejam is offline Find More Posts by pumpthejam
Old Apr 07, 2008, 02:11 PM
Airforce Nut
No Limits's Avatar
Joined Sep 2007
IMO it gives more power behind the rudder by "pulling and pushing"-given pull pull
they're usually used for your larger scale 3D planes but some people use them on other sizes and types, it's pretty much personal prefrence
-CJ
Old Apr 08, 2008, 07:35 AM
Pickle72 is offline
Find More Posts by Pickle72
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
Great thread! You guys answered a ton of ? I have one more in relation to wings. What is wash out?
Pickle72 is offline Find More Posts by Pickle72
Old Apr 08, 2008, 05:22 PM
Airforce Nut
No Limits's Avatar
Joined Sep 2007
hmmmm, I cant answer that one
-CJ
Old Apr 08, 2008, 05:47 PM
Joined Apr 2008
Thanks CJ.
Old Apr 08, 2008, 05:51 PM
Airforce Nut
No Limits's Avatar
Joined Sep 2007
no problem
-CJ
Old Apr 08, 2008, 06:31 PM
TGC is offline
TGC
Find More Posts by TGC
TGC
AMA1940
TGC's Avatar
Indian Lake, Ohio
Joined Apr 2004
WASHOUT : To reduce the tendency of the wing to stall suddenly as the stalling angle is approached, designers incorporate in wing design a feature known as washout. The wing is twisted so that the angle of incidence at the wing tip is less than that at the root of the wing. As a result, the wing has better stall characteristics, in that the section towards the root will stall before the outer section of the wing. The ailerons, located towards the wing tips, are still effective even though part of the wing has stalled.
Practical Application: Twisting the LE of the wing at the tip downward while twisting the TE upward can produce positive washout that is useful in preventing a stall.
TE= trailing edge; LE= leading edge; Root= that area of the wing next to the fuse; fuse= fuselage
TGC is offline Find More Posts by TGC
Old Apr 08, 2008, 06:47 PM
TGC is offline
TGC
TGC
AMA1940
TGC's Avatar
Indian Lake, Ohio
Joined Apr 2004
COG can also be used same as CG = Center of Gravity
AOA = ATTACK, also = AOI = ANGLE OF INCIDENCE
The angle of incidence is the angle at which the wing is permanently inclined to the airplane’s longitudinal axis.
Planform refers to the shape of the wing as seen from directly above. Wings may be rectangular or elliptical or delta shaped. Some wings taper from wing root to wing tip, with the taper along the leading edge or along the trailing edge or, in some cases, with a taper along both edges.
Aspect Ratio of a wing is the relationship between the length or span of the wing and its width or chord. It is computed by dividing the span by the average chord. A wing with a high aspect ratio will generate more lift and less induced drag than a wing with a low aspect ratio.
ROW = Rise Off Water
Old Apr 08, 2008, 06:53 PM
TGC is offline
TGC
TGC
AMA1940
TGC's Avatar
Indian Lake, Ohio
Joined Apr 2004
Controls:
R = Rudder
E = Elevator
A = Aileron
T = Throttle
R/E, R/E/T, R/E/A/T
Old Apr 08, 2008, 06:58 PM
TGC is offline
TGC
TGC
AMA1940
TGC's Avatar
Indian Lake, Ohio
Joined Apr 2004
AMA = Academy of Model Aeronautics
http://www.modelaircraft.org/
