Go Back   RC Groups > Aircraft - Electric - Airplanes > Beginner Training Area (Aircraft-Electric)
This thread is privately moderated by new flyer, who may elect to delete unwanted replies.
Old Dec 19, 2006, 07:07 AM   #46
Originally Posted by Heli X
What does "pylon" mean in reference to the plane. Here's the link ...http://www.rcgroups.com/forums/showp...3&postcount=70
Rather than having the wing mount directly to the fuselage, it is mounted on a stalk, or pylon to hold it above the wing. This provides or a cleaner air flow over the wing.
aeajr is online now Find More Posts by aeajr   Reply With Quote
Old Dec 19, 2006, 08:35 AM   #47
South Eastern Virginia
After looking at the pics again, I noticed that the area of the fuse where the wing is mounted looked like he had trimed it down some, so I figures that was probably what he was refering to. I've always known a pylon to be a structural support or something vertical (pole, bouy, cone, etc.) that is raced around. If it would have been like a free flight glider where the wing is mounted above the fuse using "stand offs" (pylons) I would have know exactly what he was refering to. Thanks for the clearification.
Oh yeah what about incidense....nevermind. I had the right idea.
Heli X is offline Find More Posts by Heli X   Reply With Quote
Old Dec 19, 2006, 08:38 AM   #48
Incidence, angle of attack-
copied and pasted from dictionary.com
Aviation
Another common usage is in aviation, where it refers to the angle between the wing's chord and the longitudinal axis of an aircraft (a fixed value). Fig. 2 shows a side view of part of an aeroplane. The wing (dotted blue line) makes an angle a with the fuselage (solid blue line). The wings are typically mounted at a small positive angle of incidence, to allow the fuselage to be "flat" to the airflow in normal cruising flight. Angles of incidence of about 6° are common on most general aviation designs.
Another term for angle of incidence in this context is rigging angle. It should not be confused with the angle of attack, which is the angle the wing chord presents to the airflow in flight. Note that some ambiguity in this terminology exists, as some engineering texts that focus solely on the study of airfoils and their medium may use either term when referring to angle of attack. The use of the term "angle of incidence" to refer to the angle of attack occurs chiefly in British usage.
Old Dec 25, 2006, 05:54 PM   #49
BD Flyer's Avatar
I'm very, very, very embarassed to ask this question..........
What is a pushrod
Well, I am going to start building my first ARF and I am not sure what that is.
Bill
BD Flyer is offline Find More Posts by BD Flyer   Reply With Quote
Old Dec 25, 2006, 09:08 PM   #50
A push rod, or control rod, is the connecting rod between the servo and the control surface, such as the rudder or elevator.
Old Dec 25, 2006, 09:14 PM   #51
BD Flyer's Avatar
Oh, thank you! I am building up my ARF knowledge
Old Jan 13, 2007, 07:28 AM   #52
i keep seeing the word crystal written.
what is it referring to?
thanks
wild_man is offline Find More Posts by wild_man   Reply With Quote
Old Jan 13, 2007, 07:52 AM   #53
Our Goal:To Promote the Hobby
Murocflyer's Avatar
thanks
It's one of these. It goes in your receiver. Of course there are ones that go in your transmitter also, same but different.
  • Name: hrcl01.jpg
Description: Rx Crystal Dual Conversion Rx Crystal Dual Conversion 7.3 KB · Views: 560
Murocflyer is offline Find More Posts by Murocflyer   Reply With Quote
Old Jan 13, 2007, 10:23 AM   #54
The crystal determines what channel your receiver will listen to so that it can communicate with your transmitter.
You may find these threads useful as well.
What you need to know about receivers
http://forums.flyesl.com/topic.asp?TOPIC_ID=258
Radio information resources for new flyers
http://www.rcgroups.com/forums/showthread.php?t=520811
Old Jan 13, 2007, 10:29 AM   #55
ahh thanks. i remember now.......
what about a prop saver?
are these ready to purchase or do you make them yourself etc.??
thanks for the replys. as a newbie i find it difficult to search on here and find what you're looking for.
Old Jan 13, 2007, 08:38 PM   #56
Hello wildman,
A propsaver is just that. Take a look at this link. I hope it works so you can see it.
Bruce
www.hobbypeople.net/gallery/942042.asp
Airhead9 is offline Find More Posts by Airhead9   Reply With Quote
Old Jan 13, 2007, 08:47 PM   #57
I have a question..
ESC? I have been going over the beginners training stuff on electronics (which I really seem to have a challenge understanding) and I don't recall reading an explanation for that term.
I'm trying to remember back to rudder only models that I read about in Flying Models magazine that there was an escapement (something with a rubber band wound up to give power for each flight? This is not like that is it?
Thanks ahead of time,
Bruce
Old Jan 14, 2007, 11:54 PM   #58
Three Bones Air Force
Great discussion. I learned alot just by reading, and hope to learn more and in the process be of value to others..Yo take care
Abraham Algadi is offline Find More Posts by Abraham Algadi   Reply With Quote
Old Jan 25, 2007, 10:29 AM   #59
kit
ESC = Electronic Speed Control
Used to control the speed of the motor.
kit is offline Find More Posts by kit   Reply With Quote
Old Jan 29, 2007, 05:02 PM   #60
Wind blows
Laggard's Avatar
ARC = Almost Ready to Crash
So what are the pros and cons of brush and brushless motors?
Laggard is offline Find More Posts by Laggard   Reply With Quote
Bored? Want to fight?
Join the RCGroups clan!
