This thread is privately moderated by new flyer, who may elect to delete unwanted replies.
Old Dec 14, 2012, 09:09 AM
Pickle72 is offline
Find More Posts by Pickle72
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
Completely normal. Most rc planes require down and right thrust. It counters the torque (among other things) of the motor/prop.
Matt
Pickle72 is offline Find More Posts by Pickle72
Old Dec 14, 2012, 10:57 AM
rcdogmatix is offline
Find More Posts by rcdogmatix
Joined Dec 2012
Matt
Thanks Matt. I was guessing the same.
rcdogmatix is offline Find More Posts by rcdogmatix
Old Dec 14, 2012, 11:31 AM
Pickle72 is offline
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
I just found this pdf. Great starter guide for all you new pilots.
Old Jan 28, 2013, 01:39 AM
Ayodhya is offline
Find More Posts by Ayodhya
WRX STI V - EJ22 - 35.3 PSI
Ayodhya's Avatar
Malaysia, Selangor, Puchong
Joined Nov 2012
Hi guys,
Complete noob here, I'm teething to get into Rc planes, already into quads.. Time I pick up another craft... So I opted for planes..
Please excuse my ignorance, but can one of you gents tell me what epf, or epo or any of the other materials used for Rc planes.. I was at the hobby shop saw a "edf foam"plane.. Didn't have a clue, also what other materials are used? If this is already explained can one of you be kind enough to guide me towards it... Thank you, much appreciated.
I guess what I'm trying to get at is the best type of material that's strong for a plane. I wanna get a aircraft which is made out of a material which would help during a mild crash.. So what's the toughest builds made of.
Basically what id like to know about is the different types planes using different types of plastic/foam..
Which different plastic/foam types used in planes and what's the most durable..
Ayo
Ayodhya is offline Find More Posts by Ayodhya
Old Jan 28, 2013, 08:15 AM
Pickle72 is offline
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
I think the you are a bit confused. The epf or edf (I think this is what you mean) is Electric Ducted Fan. Or basically its an electric motor/propeller in a shroud hidden in the fuse to give you a jet like performance.
As for the foam read this thread
http://www.rcgroups.com/forums/showthread.php?t=986842
More info in there than I can give.
Good luck.
Matt
Old Feb 13, 2013, 11:42 PM
prowler101 is offline
Find More Posts by prowler101
Canada, BC, Port Alberni
Joined Jan 2013
Hi, My apologies if this has been answered. I couldnt find it. I am looking at a new DX7S and it comes with a reciever and satalite reciever. What is the satalite reciever for?
prowler101 is offline Find More Posts by prowler101
Old Feb 14, 2013, 01:36 AM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
The satellite receiver is used to provide some signal redundancy for larger planes. The idea is that bigger aircraft have bigger components (engine/motor, battery etc.) which are capable of blocking or "shadowing" the 2.4GHz signal from the transmitter to the receiver. The satellite ensures that there's always a clear path to at least one set of antennas regardless of the model's location or orientation.
The satellite is usually not needed for smaller models, though it can be used if you don't mind the extra few grams.
Piece is online now Find More Posts by Piece
Old Feb 14, 2013, 09:34 AM
Joined Jan 2013
thankyou for the explanation. so would it in effect give the plane more range?
Old Feb 19, 2013, 04:41 AM
rcplanenoob78 is offline
Find More Posts by rcplanenoob78
no catchy phrase
United States, AK, Wasilla
Joined Feb 2013
Hey all,
I am researching large foam warbirds like 1400 or bigger. I really the the F4u's and P51's. I have little experience flying niro/gas and like the idea of electric planes. Is there much difference? Should I start out with a smaller cheaper plane? I know they all crash at some point. And last but not least can you recommend a place to buy from? I haven't heard much about any places other then BH and NP. I have have to say I am sceptical about buying from both any other places? I really like the FMS planes, mostly the FMS 1.7 F4U V2. If I am posting this in the wrong place sorry but like it says I am a noob! Thanks for you help guys.
rcplanenoob78 is offline Find More Posts by rcplanenoob78
Old Feb 19, 2013, 09:27 AM
Pickle72 is offline
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
I have never had one of the "bigger" foam warbirds but from what I have heard the FMS stuff works out well. There are lots of long threads hear on RCgroups about all of them. You may need to upgrade servos or landing gear or what ever but they should get you in the air. If you are new to electric but have nitro experience keep in mind that with todays power systems you can convert just about any nitro warbird to electric. Top Flight and Hanger 9 have great convertible warbirds.
http://www.rcgroups.com/forums/showt...light=fms+p+51
http://www.rcgroups.com/forums/showthread.php?t=1366312
http://www.rcgroups.com/forums/showthread.php?t=1492265
http://www.rcgroups.com/forums/showthread.php?t=861095
http://www.horizonhobby.com/browse/p...-pale-10000967
http://www.hangar-9.com/Resources/Electric_Chart.aspx
These are just a few.
Good luck
Matt
Old Feb 19, 2013, 09:55 AM
Laneritc is offline
Find More Posts by Laneritc
1st to the scene of the crash
Laneritc's Avatar
United States, GA, Dalton
Joined Jul 2012
doesn't increase the range, only helps keep the signal constant.
Laneritc is offline Find More Posts by Laneritc
Old Feb 19, 2013, 02:16 PM
no catchy phrase
Joined Feb 2013
Good luck
Matt
Thanks for the help Matt, the gas plane I have wont be turned into elec. it is an old trainer, sturdy birdy 2 model. I like foam because it cuts out a lot of the building process. I just like to buy them and fly them……..er ah crash them???lol I figured up grades might be needed especially power plant, maybe tx?????? I guess I am just wondering how forgiving the bigger planes are. I don't want to spend that much on a plane just to wreck it on the maiden. So I would like some thing a little forgiving, I don't think I would be very aggressive with it since I would more or less be getting back into this but I don't want to spend lots of money every time I out grow a plane, and I really don't want to have to worry about bad cs every time I need to fix some thing or worry about it arriving defective.
Old Feb 19, 2013, 02:40 PM
Pickle72 is offline
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
I completely understand. Building and bashing is fun but only if you have the time. Well I hope someone else chimes in about the larger birds. But if you want something that goes together fast and help you get your wings back check out one of these
http://www.horizonhobby.com/products...an-bnf-PKZ4480
Hands down one of the best 2nd planes out there, even if this is your 10th its a great way to get into electrics.
Old Feb 19, 2013, 03:18 PM
no catchy phrase
Joined Feb 2013
Funny you should post that, I was actually considering a Trojan. I might have to keep my options open here.
Old Feb 27, 2013, 03:27 PM
Piece is online now
Piece's Avatar
Joined Aug 2009
Seeing as this is the "Beginner Dictionary" thread, it doesn't make a lot of sense to ask warbird questions here. They're absolutely not beginner models by any stretch of the imagination
