This thread is privately moderated by new flyer, who may elect to delete unwanted replies.
Old Apr 26, 2012, 09:19 PM
gaffrig is offline
Find More Posts by gaffrig
Fly it or Fix it
Greenville, NC USA
Joined Sep 2009
Beeping Question
Thanks balsa or carbon,
I'll give that a try. All help is appreciated.
Don
gaffrig is offline Find More Posts by gaffrig
Old Apr 27, 2012, 11:08 AM
gaffrig is offline
Fly it or Fix it
Greenville, NC USA
Joined Sep 2009
Beeping Question
YEA! Problem solved. I love it when I learn something, even if it is as simple as throtle position. Thank you balsa or carbon.
Don
Old Apr 28, 2012, 12:43 AM
balsa or carbon is offline
Find More Posts by balsa or carbon
Hot glue held together by foam
balsa or carbon's Avatar
United States, OR, Portland
Joined Aug 2010
Don
You're welcome!
Al
balsa or carbon is offline Find More Posts by balsa or carbon
Old Jun 20, 2012, 01:52 PM
TedD60 is offline
Find More Posts by TedD60
Joined May 2012
OK ... what is RET?
TedD60 is offline Find More Posts by TedD60
Old Jun 20, 2012, 01:55 PM
phil alvirez is offline
Find More Posts by phil alvirez
Windsor, Canada, near Detroit
Joined Jul 2007
Originally Posted by oddshot View Post
OK ... what is RET?
rudder/elevator/throttle
used on basic trainers and electric sailplanes
phil alvirez is offline Find More Posts by phil alvirez
Old Jun 20, 2012, 05:26 PM
TedD60 is offline
Joined May 2012
Thanks ...
Old Jul 26, 2012, 09:41 PM
haxawsnavy is offline
Find More Posts by haxawsnavy
Po' boys does w/ Po'boys ways
haxawsnavy's Avatar
United States, NC, Charlotte
Joined Feb 2011
Stall Dive/$ Glider???s
Hello all,I've been wanting to do this for some time.I've been working on a $ store "Foamie" glider that I think I can make somewhat funtional,with added details such as filling mold marks,reshapeing wings,tail, n fuse (eventually add static) wing mounted engines,etc...Question is ,as I make changes ,I test "glide" it. IT ALWAYS, from a horazontal launch,..with/into/no breaze, curves upward, stalls n dives. is nose/tail to heavy? How to check C.O.G.and where it SHOULD be on any future type glider's I've seen I'd like to "experiment" with to be R.C.ed .I'm brand new to planes,but I KNOW the answers are here on RCG.forum..thx Tim
haxawsnavy is offline Find More Posts by haxawsnavy
Old Jul 26, 2012, 10:57 PM
Pickle72 is offline
Find More Posts by Pickle72
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
http://adamone.rchomepage.com/cg_calc.htm
Try that. Its more than you need but its cool.
Basically a good place to start is 25% of cord. So take how wide the wing is at the root and figure out what 25% is and measure back from the leading edge. Of course if there are a ton of other things to consider but that is a starting point.
This is a good read too.
http://www.rcpowers.com/community/th...ch-build.6220/
Lots more out there. Do a google search for "finding CG on scratch built RC model" or something similar.
Hope this helps
Matt
Pickle72 is offline Find More Posts by Pickle72
Old Jul 26, 2012, 11:33 PM
haxawsnavy's Avatar
Joined Feb 2011
aircraft Calcuator
Hey ,Thankyou Pickle, I'll learn to use it well. I have something like this for scale converstions.Don't worry about "overloading' me, The more I GET the more I LEARN thats why I'm here on R.C.G.....Tim..P.S( I can always ask )
Old Jul 26, 2012, 11:42 PM
haxawsnavy's Avatar
Joined Feb 2011
aircraft calculator
Also thx for the PDQ! reply .All will be tested...Tim
Old Aug 16, 2012, 07:59 PM
Chuckf2000 is offline
Find More Posts by Chuckf2000
Chuckf2000's Avatar
Joined May 2012
What do they mean when they say 'park flyer' and, say, 'a 40 size aircraft?'
Chuckf2000 is offline Find More Posts by Chuckf2000
Old Aug 18, 2012, 09:04 PM
matiac is offline
Find More Posts by matiac
AMA 994002
matiac's Avatar
United States, RI, Westerly
Joined May 2012
What is "expo" and "rate"? And why are they important to know??
matiac is offline Find More Posts by matiac
Old Aug 21, 2012, 09:28 AM
Pickle72 is offline
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
A parkflyer is any small electric RC aircraft that can be safely flown at a small park/soccer field. Any ultra micro electric airplane/heli would more than fit into this category(also fits into the gym/indoor flying category). Small electric's of about 48" wingspan or lower with low to medium speed would also fit. Basically if it is too big and too fast and too loud to not be able to stay in a soccer field or two than its not a park flyer.
When someone is referring to an aircraft as a 40 size or 60 size etc., they are referring to the size of the nitro motor on it. A 40/60 size nitro plane is a good size 50-60" wingspan airplane and should probably be flown at a local club field.
Expo is referring to the amount of deadband around center you program into your transmitter. The more expo the less twitchy the aircraft is when you move the sticks just a little past center, but responds the same as the stick are moved. Its a non-linear movement done in the transmitter.
Rate is referring to dual rates on the transmitter. You can have dual and triple rates on some transmitters. If the manufacture recommends that the elevator only moves 1" up or down you can have low rates be half of that. So if you go full throw on the elevator it only moves 1/2" so the model is less responsive to pitch. But at a flick of a switch it will be in high rates and you will get the full 1" in throw.
I hope this helps a bit.
Some great links that explain all this better than I can.
http://www.rcpowers.com/community/th...rates-do.9657/
Transmitter Dual Rate and Expo Theory, Part 1 of 2 (8 min 28 sec)
http://en.wikipedia.org/wiki/Park_flyer
http://www.rc-airplane-world.com/
Old Sep 07, 2012, 01:14 AM
Redmerlot is offline
Find More Posts by Redmerlot
Joined Sep 2012
Very helpful for this noobie
Redmerlot is offline Find More Posts by Redmerlot
Old Sep 10, 2012, 08:29 AM
poziovahim is offline
Find More Posts by poziovahim
poziovahim's Avatar
United States, NM, Espanola
Joined Nov 2011
battery
Hey All,
what is the significance of the C-rating of batteries? What would a 4S 2200mah 20C battery do compared to the exact same battery but a 40C instead?
Many Thanks,
Dan
poziovahim is offline Find More Posts by poziovahim
