This thread is privately moderated by new flyer, who may elect to delete unwanted replies.
Old Feb 03, 2010, 04:00 PM
grubbyjeans is offline
Find More Posts by grubbyjeans
The Low-wing Super Cub
grubbyjeans's Avatar
Houston, TX
Joined Sep 2007
Originally Posted by bpin View Post
how about a page on glues. GG,PU,foam safe ?
Check this thread or this one.
grubbyjeans is offline Find More Posts by grubbyjeans
Old Feb 25, 2010, 03:26 PM
Bombay is online now
Find More Posts by Bombay
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Reflex
Can anyone speak more on aileron "reflex" and how it is used on planes other than sailplanes?
Bombay is online now Find More Posts by Bombay
Old Feb 25, 2010, 03:36 PM
Pickle72 is online now
Find More Posts by Pickle72
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
Well, I don't think its used much on planes other on sailplanes. I have tried it on my 3D planes to try to take some wing rock out of harriers but other than that I don't know why you would want it.
BTW reflex is when you program your ailerons to both point up a small degree. Its the reverse of flaperons where both ailerons point down a small degree.
Anyone else have more insight?
Matt M
Pickle72 is online now Find More Posts by Pickle72
Old Mar 15, 2010, 01:50 PM
mahi007 is offline
Find More Posts by mahi007
Joined Oct 2009
good
mahi007 is offline Find More Posts by mahi007
Old Mar 15, 2010, 03:21 PM
JMeyers is offline
Find More Posts by JMeyers
Newpaltz, NY
Joined Dec 2009
That 4D is a little too unrealistic for me
JMeyers is offline Find More Posts by JMeyers
Old Mar 15, 2010, 05:59 PM
woodsy is offline
Find More Posts by woodsy
Woodsy
Drouin, Australia
Joined Sep 2003
it can be used to trim out a plane when the wing incidence is NQR.
Here is an article on Reflex.
http://www.angelfire.com/on/dragonfl...reflexing.html
woodsy is offline Find More Posts by woodsy
Old May 06, 2010, 01:03 AM
jfacky is offline
Find More Posts by jfacky
What goes up must come down
jfacky's Avatar
USA, GA, Snellville
Joined Oct 2005
AC=Alternate...not quite true
Originally Posted by BD Flyer View Post
DC = Direct Current (This type of charger receives it's power by plugging it into a seperate power supply such as a car battery, ect.)
AC = Alternate Current (This type of charger receives it's power by plugging it into a wall outlet.)
Fast charger = Usually charges batteries in increments of 15 minutes.
Balancer = Balances each cell in LiPo (Lithium Polymer) batteries to an equal number of volts.
Deans = A type of connector that is commonly used on batteries and ESC's.
Bananna plug = Another type of connector that is commonly used on DC chargers.
AC= alternating current. With DC current, electrons move from negative to positive in a straight line...hence the name direct current. Now with AC current, electrons move from 0 charge to + charge back to 0 charge then from 0 charge to -(negative) charge and back to 0 charge to complete one cycle. then the cycle starts over. example. your wall receptical has 120 volts ac coming to it. if you map the sign wave of the current it will go from 0 volts to 120volts positive charge back to 0 volts then to 120 volts negitive charge back to 0 volts. 0 volts being nutral
In the US it does this 60 times a second in Europe 50 times a second or 60Hz/50 Hz.
HTH
Jim
Hope this helps
jfacky is offline Find More Posts by jfacky
Old May 14, 2010, 09:17 PM
flashy30 is offline
Find More Posts by flashy30
flashy30
Fayetteville, NC
Joined Jul 2005
Could someone please post the hook up sequence of the battery and esc and rec and motor. What hooks up to what. Thanks
flashy30 is offline Find More Posts by flashy30
Old May 14, 2010, 10:29 PM
Houston, TX
Joined Sep 2007
Here ya go. One note regarding this drawing, it demonstrates the use of bullet connectors and that the 'male' connector is attached to the + battery terminal. I recommend reversing that setup by putting the female connector on the + connection, which allows it to be completely covered with shrink-wrap insulation. Protecting the + wire prevents accidental shorting contact with another object.
Old Jun 01, 2010, 10:31 PM
duo is offline
duo
Find More Posts by duo
duo
duo's Avatar
Joined May 2010
oh,my god ~~
duo is offline Find More Posts by duo
Old Jun 05, 2010, 12:14 AM
jazz53 is offline
Find More Posts by jazz53
Joined Jun 2010
How about the differences between plane types IE;
Parkflyer
Foamy
EP
3D
Micro
Small
40 size 50 size
I no, a few have been mentioned, but a complete list would be nice.
jazz53 is offline Find More Posts by jazz53
Old Jun 05, 2010, 06:42 AM
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
Parkflyer
Foamy
EP
3D
Micro
Small
40 size 50 size
1. For Parkflyer read pfd. But generally a small(under 2lbs) electric airplane.
2. EP=Electric powered
3. An airplane made out of foam, either Depron(a light brittle foam) or EPP(a light spongy foam).
4. An airplane that is capable of flying 3D manuveres. 3D is defined as flying post stall, or flying using the prop as the main lifting force and not the wings.
5. Micro is smaller than small
6. Small is larger than micro
7. When you see a plane refered to 40 or 50 size (or any other number, .15, 20, etc.) it is referencing that planes nitro size motor. The manufacturer is giving modelers a reference point of how big the model is compared to a nitro powered plane.
Hope this helps a little
Matt
Old Jun 05, 2010, 06:46 AM
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
Also...
ARF = Almost Ready to Fly
RR = Receiver Ready
EDF = Electric Ducted Fan
DLG = Discus Launch Glider
AUW = All Up Weight = weight a plane will fly at.
There are about a hundred more but I need some coffee first
Matt M
Old Jun 05, 2010, 07:48 AM
Houston, TX
Joined Sep 2007
Originally Posted by duo View Post
oh,my god ~~
Old Jun 05, 2010, 09:19 AM
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
Originally Posted by grubbyjeans View Post
Got me? Perfectly reasonable question and answer.
