This thread is privately moderated by new flyer, who may elect to delete unwanted replies.
Old Nov 26, 2009, 07:35 AM
HappyKillmore is offline
Find More Posts by HappyKillmore
Brunswick, OH
Joined Nov 2005
Originally Posted by jejton View Post
Whats 3D flying?
Getting your plane to "hover." It means you're able to hang the plane on the prop. You're not really moveing forward through the air, you have enough thrust to make the plane just hover.
Example of 3D (go to 3:30):
http://www.youtube.com/watch?v=RBm3Q4obAQg
If you can make the plane stop in mid air and go backwards that's called 4D (and requires a variable pitch prop).
Example of 4D:
RC 4D Amazing Flying (2 min 10 sec)
HappyKillmore is offline Find More Posts by HappyKillmore
Reply With Quote  (Disabled)
Old Nov 26, 2009, 11:32 AM
Pickle72 is offline
Find More Posts by Pickle72
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
Whats 3D flying?
What Happy said. Plus any time you are flying (in control of the aircraft) when the wings are stalled is 3D flying.
You need greater than 1:1 thrust to weight ratio and lots of control throw and large control surfaces.
Matt
Pickle72 is offline Find More Posts by Pickle72
Old Nov 26, 2009, 05:46 PM
microflitedude is offline
Find More Posts by microflitedude
RCG -Minus Member
microflitedude's Avatar
United States, SC, West Columbia
Joined Oct 2009
Example of 4D:
http://www.youtube.com/watch?v=OQfz5LttoQQ
wow! that 4d pilot is amazing!
microflitedude is offline Find More Posts by microflitedude
Old Nov 27, 2009, 02:32 AM
imflying is offline
Find More Posts by imflying
Joined Nov 2009
so great!
imflying is offline Find More Posts by imflying
Old Jan 14, 2010, 12:27 PM
Scarface26 is offline
Find More Posts by Scarface26
Colorado Springs, CO.
Joined Mar 2009
Where can I find a good definition of "Park Flyer"?
What does "Sloper" mean?
Scarface26 is offline Find More Posts by Scarface26
Old Jan 14, 2010, 12:33 PM
RCG -Minus Member
Joined Oct 2009
A park flyer is a smaller plane usually under 2 pounds, and can be flown in a relatively small park. A sloper is a big glider usually thrown off a big slope, and motorless.
Old Jan 14, 2010, 02:01 PM
Joined Mar 2009
Thanx for your help!
Old Jan 14, 2010, 02:41 PM
RCG -Minus Member
Joined Oct 2009
No problem!
Old Jan 23, 2010, 07:30 PM
woodsy is offline
Find More Posts by woodsy
Woodsy
Drouin, Australia
Joined Sep 2003
Originally Posted by microflitedude View Post
Snip> A sloper is a big glider usually thrown off a big slope, and motorless.
It's a bit broarder than that,
a slope plane is a NON powered plane (glider) that uses wind updraft from a land formation (cliff, buildings, hills) to gain lift, as oposed to a "thermal" plane which is a glider that uses updrafts from metralogical conditions to gain lift.
'generaly' a slope plane will have a geater wing loading than a thermal plane.
then within slope planes there are MANY diferent sorts, you can use a thermal plane, PSS, DS, etc, etc
http://www.shallowsky.com/planes/weasel/slopetips.html
woodsy is offline Find More Posts by woodsy
Old Jan 23, 2010, 08:06 PM
RCG -Minus Member
Joined Oct 2009
ok smarty pants. who cares about pss ds thermal metralogical bla bla. let's keep it simple.
Old Jan 26, 2010, 05:33 PM
philba is offline
Find More Posts by philba
Prop Buster Extraordinaire
philba's Avatar
Seattle
Joined Aug 2009
I think slope and sloper are also applied to variants of ARFs that don't have power or landing gear. At least, that's how GWS does it. They have several different SKUs (er, variations) of a given plane: RTF, NPS (no power but LG), Slope (NPS minus LG). They might be getting away from the slope variant.
philba is offline Find More Posts by philba
Old Jan 29, 2010, 03:13 PM
grubbyjeans is offline
Find More Posts by grubbyjeans
The Low-wing Super Cub
grubbyjeans's Avatar
Houston, TX
Joined Sep 2007
BEC vs UBEC
http://www.facebook.com/note.php?note_id=69720977400
7. What is a BEC?
BEC stands for Battery Elimination Circuit. This is often a built in feature of the ESC which eliminates the need for a separate battery to power the receiver and servos. The BEC takes power from the main battery pack and reduces it to about 5 volts, and then sends it on to the receiver via the red wire of the ESC receiver plug. A BEC will commonly have a maximum amp rating of 1 to 3 amps, and this is usually stated somewhere on the ESC, or on the ESC instruction sheet.
8. What is a UBEC?
UBEC stands for Universal Battery Elimination Circuit. The UBEC is a small electronic device that is used to power the receivers/servos of a model if the ESC being used does not have a built in BEC, or if the BEC of the ESC is inadequate to power the number of servos being used. The UBEC is connected directly to the main battery pack of an electric model, the same as the ESC. In fact, the power input wires of the UBEC are often spliced into the power input wires of the ESC. The power output wires of the UBEC have a receiver connector on them, and this is usually plugged into any open channel of the receiver. If the ESC being used has a built in BEC, that BEC must be disabled when using a UBEC. To disable the BEC of an ESC, simply disconnect the red wire on the receiver plug of the ESC.
grubbyjeans is offline Find More Posts by grubbyjeans
Old Feb 03, 2010, 07:37 AM
bpin is offline
Find More Posts by bpin
Old Toolmaker
Angola,Indiana
Joined Jan 2010
how about a page on glues. GG,PU,foam safe ?
bpin is offline Find More Posts by bpin
Old Feb 03, 2010, 03:31 PM
Aeroplanecolt is offline
Find More Posts by Aeroplanecolt
United States, FL, Lakeland
Joined Oct 2009
Need info on foam safe adhesives.. asap>>???
Aeroplanecolt is offline Find More Posts by Aeroplanecolt
Old Feb 03, 2010, 03:36 PM
RCG -Minus Member
Joined Oct 2009
what do you mean?
