This thread is privately moderated by new flyer, who may elect to delete unwanted replies.
Old Apr 09, 2009, 03:22 AM
Broken wing 31 is offline
Find More Posts by Broken wing 31
Crashing aircraft since 1975
Broken wing 31's Avatar
United States, PA, Hookstown
Joined Dec 2008
BAF- bind and fly?
Broken wing 31 is offline Find More Posts by Broken wing 31
Old Apr 09, 2009, 07:41 AM
Bombay is offline
Find More Posts by Bombay
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Originally Posted by fresh meat
BAF- bind and fly?
Usually, Bind-and-Fly is BNF...at least with ParkZone.
Vapor Bind-N-Fly by ParkZone
Sukhoi Su-26m BNF
Blade CX3 MD 520N BNF
Blade mCX BNF
etc
Bombay is offline Find More Posts by Bombay
Old Apr 09, 2009, 08:03 AM
Pickle72 is offline
Find More Posts by Pickle72
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
I believe BAF is Big A$$ Foamy. Check out DW Foamies. They have some BAF's.
http://www.shop.depronwest.com/categ...?categoryId=43
Matt
Pickle72 is offline Find More Posts by Pickle72
Old Apr 09, 2009, 12:43 PM
jingjingjing is offline
Find More Posts by jingjingjing
I love my ID.
Fairfax VA
Joined Aug 2004
reciever (wrong) -> receiver (correct)
dehidral (wrong) -> dihedral (correct)
jingjingjing is offline Find More Posts by jingjingjing
Old Apr 11, 2009, 01:56 PM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
FWIW, a minor point, but to be correct, Kv is not thousands of rpms. The "K" is the scientific term for "Konstant" (constant) and what it means is that theoretically a motor will turn "K" rpm per volt. The Kv could be in tens, hundreds, or thousands, it really doesn't matter.
Azarr
Azarr is offline Find More Posts by Azarr
Old May 31, 2009, 03:02 AM
michaehay is offline
Find More Posts by michaehay
The sky ate my homework!
michaehay's Avatar
Foster City, CA
Joined Apr 2009
send you a "PM"? what is it?
michaehay is offline Find More Posts by michaehay
Old May 31, 2009, 07:45 AM
Pickle72 is offline
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
PM= Private Message.
Click on a users name to get to there blog/home page. There is an option to email or PM that user. You use it a lot when buying stuff in the classifieds section.
Matt
Old Jul 16, 2009, 08:22 PM
paul timms is offline
Find More Posts by paul timms
paul timms's Avatar
Australia, VIC, Kyneton
Joined Apr 2008
motor to esc
Question?
If a motor requires a 20 amp ESC unit is it OK to fit a 30 amp unit,or does it effect the speed control of the motor eg. the rev range. Yours Paul.
Thanks for the replies below(PICKLE 72 & AEAJR ),I was hoping this was the case.
Paul
paul timms is offline Find More Posts by paul timms
Old Jul 16, 2009, 09:23 PM
Pickle72 is offline
Matt Mabry
Pickle72's Avatar
Champaign, Il
Joined Mar 2008
Nope its perfect. Rule of thumb is to go to the next size up on the esc if you can afford it money and weight wise.
Matt
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Too big an ESC is fine, just adds cost and sometimes weight.
Too small an ESC ( not enough amp rating) is bad.
aeajr is offline Find More Posts by aeajr
Old Aug 23, 2009, 10:38 PM View Post
lilychan
A moderator felt this post violated the following rule: Excessive Advertising (Spam). It is temporarily hidden while lilychan edits it. Show it to me anyway.
Old Sep 05, 2009, 09:21 PM
botree is offline
Find More Posts by botree
botee in a tree
Montevallo, AL
Joined Aug 2009
check out the bottom of the page @ the link you gave
Originally Posted by matt90
what is a good brushless motor for 75 watts per pound = mild to moderate aerobatics, i want to upgrade the 360 nonbrushless that i have on my piper cub
It says you can go up to a speed 600 motor and 8 cell pack using the ESC that came with the plane.
botree is offline Find More Posts by botree
Old Sep 15, 2009, 01:18 PM
Ompapamowmow is offline
Find More Posts by Ompapamowmow
Certified ground locator.
Ompapamowmow's Avatar
United States, CA, Visalia
Joined Nov 2008
Hi guys. I read an explaination of Exponential Rate, i am guessing this is "expo". I understand what it does, but what i dont understand is what it is used for and what it should be set at (i fly a t-28). any help would be appreciated. Thanks
Ompapamowmow is offline Find More Posts by Ompapamowmow
Old Sep 15, 2009, 02:20 PM
HappyKillmore is offline
Find More Posts by HappyKillmore
Brunswick, OH
Joined Nov 2005
Expo makes movements on your sticks smaller (or larger). But too much can make the plane feel mushy.
If you set your expo at 50%, then when you move your sticks 50% it will only move the control surfaces 25%. But when you go to 100 it will still move the control surfaces to 100.
It's different than dual rates in that the full movement is still the same, just the middle part is different.
I started at 0% and didn't know any better. Then I found expo and changed everything to 30%... but after a while realized that everything was too mushy (too much stick movement to get the plane to move). So I've settled around 10-20% expo on elevator and ailerons on most of my planes. 0% on rudder.
Give it a try. You'll find that it makes the plane far less twitchy to small movements on your sticks. Start small or you'll find out quick that too much is bad news.
HappyKillmore is offline Find More Posts by HappyKillmore
Reply With Quote  (Disabled)
Old Sep 15, 2009, 04:03 PM
Joined Nov 2008
ok cool i get it. thanks for the explaination!!!! happy flying
