Old Nov 15, 2005, 03:39 AM
Armchair Bronco is offline
Find More Posts by Armchair Bronco
In EPP I Trust...
Armchair Bronco's Avatar
Issaquah, Washington, United States
Joined Jan 2004
Need part # for Hitec Flash 5 replacement trainer switch
Does anyone know what the part # is for the Hitect Flash 5 trainer switch? I'm going to be placing an order with Mouser.com for some components to make a switchcraft charging plug for my next project, so if someone can tell me the Mouser product #, I can order it at the same time.
I was recently out flying my bungee launched 1-meter sloper when my daughter accidentally stumbled over my Hitec Flash 5 TX (which I had foolishly set on the ground while retrieving the sloper from some tall grass). My daughter stepped on the trainer jack switch (2nd from the left along the top of the TX) and completely bent it to the side.
The switch looks pretty bad and now it flops around in its housing (but it doesn't seem to have any other mechanical or electrical problems). Still, I'd prefer replacing it with a new trainer switch just to play things safe.
Armchair Bronco is offline Find More Posts by Armchair Bronco
Old Nov 17, 2005, 01:55 AM
In EPP I Trust...
Joined Jan 2004
Bumping up. Any ideas?
Old Nov 17, 2005, 08:50 AM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
I'm not sure whether mouser will carry such a thing as a spring loaded switch as it's quite uncommon. You can either desolder one of the wires and insulate it thus disabling the switch or call Hitec USA (858-748-8440) and get the switch from them.
ivanc is offline Find More Posts by ivanc
Old Nov 17, 2005, 09:48 AM
rutat is offline
Find More Posts by rutat
Joined Mar 2004
You want a "momentary contact toggle switch". They come in all sorts of sizes. Alco is one brand that mouser sells but you'll have to check the dimensions. I think the idea of getting the replacement from Hitec is the best idea.
BTW - RatShack sells the parts to make that switchjack - might save you some shipping.
rutat is offline Find More Posts by rutat
Help! interface for hitec flash 5 x system pulhny1616 Simulators 1 Aug 05, 2006 02:40 PM
Need advice with Hitec Flash 5 doublesixes Radios 4 Oct 27, 2004 02:01 PM
Question Buddy box questions for Hitec Flash 5? Which functions are transfered? duganderson Radios 2 May 19, 2003 02:31 AM
Need Advice on Connecting Hitec Flash to PC Using Trainer Interface webguyjv Electric Plane Talk 3 Jan 28, 2002 12:34 AM
