Attached here are:
1. Comparison table of various motor and gear ratio combinations (only the best diameter/pitch combinations have been kept for each motor). 2. Table of diameter/pitch combinations for the Medusa 028-040 1200 3. In flight analysis report by MotoCalc for the Medusa 028-040 1200 and 17x13 propellor. The tabs for the text files are aligned at 8 spaces. The results I gave earlier from memory for 18x16 vs 17x13 @ 1200RPM/Volt were a bit off. The 18x16 has better climb rate, but the prop stalls at airspeeds < 10mph, whereas the 17x13 stalls at airspeeds < 5mph. I don't really know what airspeed a 3M ship has after a hand toss, but 5mph seems to be reasonable. I hope I don't have to rig up a short bungee launcher for this config. Note to other newbs who may be reading this post: These results are for MY airframe! Your results may vary. Grab MotoCalc and do your own computations.
Bump.
I would greatly appreciate it if an experienced EP guy can confirm that my reasoning here is valid. Anyone? I'm itching to finalize this so I can assemble my glider before it gets too cold outside. We just had our first snowfall today ![]() It worries me that I end up with such a large prop (17x13) and low kv (1200), compared to what others say they use in their setup. EDIT: I just reread all of my mumbo-jumbo above, and I'm not surprised no one answered. I think I write too tersely.
I tried to read it and could not follow your logic/reasoning. There are too many misconceptions/assumptions in your thesis above for me to sit here and respond to every point. Methods for choosing a particular power system for a model have been covered here many times, also in a 6-part series posted by the site owner Jim Bourke back in 1998:
http://www.rcgroups.com/links/index.php?id=3385 http://www.rcgroups.com/links/index.php?id=3389 http://www.rcgroups.com/links/index.php?id=3393 http://www.rcgroups.com/links/index.php?id=3398 http://www.rcgroups.com/links/index.php?id=3402 http://www.rcgroups.com/links/index.php?id=3597 Finally if you're itching to get a model set up but unsure of a particular system, post here and others will pitch in with what they've used in this or a similar model (it helps to post specs on the model - I've never heard of a "Laser Arts Majestic" sailplane). I'd give you 10 points for effort though! ![]() ..a |
I think the entire thing is good for a mental exercise and learning setups. But the best way to pick motors/batteries/props and to get as many as possible and fly them. The next best way is to ask someone who has flown the model. In a word experience is the best way to learn.
Example I had two 16 cell setups recommended to me. Hacker b50-9s (in motocalc and pretty accurate) and Lehner 19308d (not in motocalc). Lehner was more expensive, than the hacker, and I questioned the value. But once I flew it there was no question the lehner was worth the premium. There are no numbers collected about the lehner system, it just works. Jay |
Thanks! The feedback is greatly appreciated. That tuturial is exactly what I needed.
Sorry for not giving the specs for the glider. They can be found here (click on the specifications tab). http://www.laserarts.com/product_inf...roducts_id=175 I did not have EP in mind when I purchased that glider. The idea of EP only came up when I realized my histart would be useless in the cold (this is my first season as an RC flyer -- can you tell? ).
I've finished reading the tutorial... really well written and easy to understand. It was helpful to see the prop power equation to understand the relationship of the prop with the rest of the power train. It also made me aware that motors have a torque limit -- I didn't check for that while I was compiling my comparison table.
Andy, I can't see what "misconceptions" I had in my reasoning. All I basically did was throw a bunch of setup combinations in MotoCalc, and prefered the ones that gave me the best total climb per charge. You understand what I mean by total climb per charge, eh?total climb = rate of climb x flight time Where flight time is the amount of time I get from the battery pack at full throttle. I don't care how fast the glider zips up to thermal hunting altitude -- as long as it's reasonable (I don't do competitions). I just want to get the most "launches" per single battery charge. That number of launches is calculated by:# lauches = total climb / launch height The only misconceptions that I see I might have, is believing that the motor parameters are accurate and that MotoCalc is accurate. ![]() I have admitted that my procedure, as written, was too terse and hard to read, but I can't accept that I had "misconceptions" without any justification on your part. If you believe I had misconceptions, you therefore must've been able to follow me up to a certain point. ![]() As for relying on what works for others... I don't know. In general, it seems that people are more interested in climbing fast rather than getting the most launches out of single charge. That's what motivated me to use MotoCalc.I now understand why my methodology ends up favoring small kv motors. It's because I arbitrarily decided to use a 3 cell lipo. I'll crunch the numbers again using a 2S2P lipo -- I bet the larger kv motors will end up being in favor. |
Here's a comparison table using my procedure when I impose a 2S2P lipo. As I suspected, motors with higher kv tend to be favored with this battery configuration.
I forgot to add the motor amps in my comparison tables, so some of the motors might be drawing too much current. I also was a bit sloppy when factoring in the weight of the gearbox. I'm going to recompile my comparison tables this weekend when I have fresher eyes. Once I validate my MotoCalc selection with the real motor, I'll clean up my spreadsheet and put in some macros to avoid the tedious import, copy, paste, and sort that I have to do for each static analysis files MotoCalc spits out. I can then post the spreadsheet, if anyone is interested. |
Sigh.. you're determined to put us thru this exercise, aren't you..
Motor selection: Quote:
Prop stall speed: Quote:
.. Disclaimer - I am not trying to dampen your enthusiasm.. ![]() ..a |
| Thread Tools | |
| how's this idea for a second plane | MrPropJet | Fuel Plane Talk | 32 | Jan 25, 2005 03:00 PM |
| How's this for stupid? | turbojoe | Parkflyers | 19 | Jan 13, 2003 08:55 AM |
| How would this be for a airplane motor? | Mike Hall | Power Systems | 7 | Jul 25, 2002 03:20 PM |
| How's this for a great e-RC plane: a 7' RC Falcon -- as in the BIRD! | J Cubed | Electric Plane Talk | 2 | May 08, 2002 03:26 PM |
