Old Nov 12, 2005, 09:09 PM
Jimmy James is offline
Find More Posts by Jimmy James
Thoughts Become Things
Jimmy James's Avatar
United States, OR, Portland
Joined Jan 2005
Anyone convert an Oly II or similar 100" to electric?Could you post your power setup?
Hello,
I am trying to find some examples of power systems that have been installed in large gliders with a wingspan around 100", mine is a 100" Oly II. If anyone has examples of this configuration could you please post it here?
Thanks, Jim
Jimmy James is offline Find More Posts by Jimmy James
Old Nov 12, 2005, 09:37 PM
No Step is offline
Find More Posts by No Step
My hangar is,... "almost" full
No Step's Avatar
United States, WA, Marysville
Joined May 2003
I have,.... https://home.comcast.net/~guilfoyle72 I don't have alot of pictures on the page but all the info I think you'll need is there on the Olly 2 page. Lately I've noticed it's not as hot a climber as it used to be. I haven't investigated the matter but it still is an excellent performer. Also see my Paragon page. Fred
No Step is offline Find More Posts by No Step
Old Nov 12, 2005, 09:47 PM
sierra-gold is offline
Find More Posts by sierra-gold
Joined Sep 2002
What will your Oly II weigh? That is the real important factor in picking a motor, along with your climbing performance expectation.
I fly an Aspire 2M which weighs 38 oz. AUW with a Hacker B20 L18, 4:1 GB, and a 3S Lipo. The performance is quite good... MotrCalc says 700 ft./min. I don't think I would be happy with much less climbing capability. Others could tolerate less.
I am converting a BOT 118" ARF to EP and will use an AF 05 with 4.4:1 GB on a 3S2P Lipo. Climbing performance, on what I estimate will be a 62 oz. AUW glider, should be similar to the Aspire 2M.
SG
sierra-gold is offline Find More Posts by sierra-gold
Old Nov 12, 2005, 09:59 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
I did that mod many years ago..(Looking for photos.. 15 years ago!!!!!)... it would be obsolete today.
Instead of an Astro O5 and nicads I'd use a brushless and Lipos.
The weight savings would have a very positive effect on the climb, which was modest with the O5.
Sparky Paul is offline Find More Posts by Sparky Paul
Joined Sep 2002
Hey Fred,
Really nice looking Paragon. I have a Paragon I started building in 1990. I moved the bones with me when I retired in 1991 and I dug them out just a few months ago. I built it as a 100" as the "Standard TD class back then" was limited to 100". If you flew the 118" you were in with the Windsongs, etc. in Open Class TD.
I have already purchased the AXI 2820-10 I plan to use, so I was happy to see you were pleased with yours.
I had estimated my AUW would be around 50 oz. Boy that stock fuse with all that plywood is heavy... I may have to build me a lighter fuse.
Thanks for sharing your Web site, I'm going back in a few minutes to explore some more.
SG
Old Nov 12, 2005, 10:08 PM
Joined Jan 2005
Fred,
Thank You very much for the link to your site. You have some nice birds there, I especially like your Fournier RF4, that is a hard plane to find and you did a wonderful job on it, inspirational!
I like the Oly II setup, I was thinking of going with the AXI, I've heard great things about AXI motors. I am also planning on using 8 cell Nimh batteries so your setup fits my situation even better.
I do have a question for you. I am new to this so you will have to forgive my lack of knowledge, but I noticed that you used the same setup for the Paragon that you used with the Oly II, why does the Paragon draw less amps then the Oly II when you are using the same setup? Is it because the Paragon has a higher lift or larger span? Just curious.
Thanks, Jimmy
Old Nov 12, 2005, 10:18 PM
Joined Jan 2005
Sparky,
I have admired your web site for a long time. You have created some awsome planes! Did you fit a mono wheel to your Olly II? I sort of borrowed the idea from you (I hope you don't mind ) after I saw a picture from your web site. Do you have any pictures of your mono wheel mount?
Also, didn't you use your Olly II wing on a different fuselage? I am planning on doing that at some point.
Thanks for the picture, like I said, I am an admirer of your work.
Jimmy
Old Nov 13, 2005, 12:33 AM
John Gallagher is offline
Find More Posts by John Gallagher
John Gallagher's Avatar
Lindenwold, NJ, USA
Joined Dec 2000
Sparky,
Always noticed how colorful your planes are... almost as colorful as those shorts.
John Gallagher is offline Find More Posts by John Gallagher
Old Nov 13, 2005, 11:10 AM
No Step is offline
No Step's Avatar
Joined May 2003
Jimmy, it probably has to do with the actual moment I measured the current draw. Hot off the charger, the motor/batt. package probably was drawing over 40 amps (it's a big prop for that motor), that drops down and eventually stabilizes to a certain degree. The difference between current measurements (only 6 amps) has to do with when I actually noted the current draw. The Olly measurement was probably taken sooner than the Paragon measurement. I probably didn't wait for it to stabilze as much as I did with the Paragon. Bottom line, I probably noted current draw before 15 seconds. That "15 second" point in time has always bothered me because many times it still hasn't stopped dropping. I need to replace it with "stabilzed", and then actually measure it when stabilzed. I'll go back and remeasure one of these days.
Old Nov 13, 2005, 11:36 AM
neonbutterfly is offline
Find More Posts by neonbutterfly
LSF186
neonbutterfly's Avatar
Wayne, NJ
Joined Jan 2003
this may help......
axi 2820/10
castle 45 map speed control
1700mah nimh 8 cell pack
12/6 graupner folding prop
bob
neonbutterfly is offline Find More Posts by neonbutterfly
Old Nov 13, 2005, 12:56 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
Jimmy, the Oly is long gone.. but the wheel on my first Paragon looks like this;
1/8" music wire, soft wheel... which wears out rapidly!
Old Nov 13, 2005, 03:24 PM
Joined Jan 2005
Thanks Sparky for the picture.
Bob,
That's the setup, I'm looking at prices on those exact items right now. It's great when things get narrowed down after a bit of research, and lots of help! Thanks to you guys
Jimmy
Old Nov 13, 2005, 06:12 PM
ken troxell is offline
Find More Posts by ken troxell
rockville maryland
Joined Aug 2000
i am flying a skybench big bird...100"...weighs 61oz. i use a hacker b40 with a 4.4:1 gb,a 14x9.5 prop,a GP2200,8cell pack.
with this setup you won't be disappointed...ken
ken troxell is offline Find More Posts by ken troxell
Old Nov 13, 2005, 08:18 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
Originally Posted by neonbutterfly
this may help......
axi 2820/10
bob
I'm using that setup.. 2820/10. but with a 9x5 Cam prop, 3C2000 Lipo, 40 Amp ESC on a 2M. It goes nearly vertical very nicely.
I think I'd chose a 2826/12 or /14 for a plane the size of an Oly II.
Poll Skybench OLY II, NES Kestrel 100" or MM Tech Marauder??? FrogChief Thermal 49 May 17, 2008 10:51 AM
Discussion Anyone have an old CCD or CMOS Cam?? qualcity Aerial Photography 0 Apr 03, 2006 02:06 AM
Question Anyone built an Offshore Vampire or P80? thomanie Electric Ducted Fan Jet Talk 4 Jan 07, 2006 10:44 PM
Anyone flying an acme Cyclone or Mongrel? Joe Ford High Performance 5 Aug 07, 2004 02:13 AM
Has anyone flown a Robbe Easy Go or similar? Alverca Parkflyers 3 Nov 05, 2002 06:21 PM
