Old Nov 12, 2005, 09:46 AM
Sled Driver is offline
Find More Posts by Sled Driver
Knowledge increases life's FOV
Sled Driver's Avatar
Third Stone from the Sun
Joined Nov 2003
How did you build your hot box?
Got an industrial heater system with temperature control assembled and working yesterday. Now I need to build a new hot box to put it in and I am looking for more ideas...
Sled Driver is offline Find More Posts by Sled Driver
Old Nov 12, 2005, 09:56 AM
Batmanwpg is online now
Find More Posts by Batmanwpg
Boar? I'm a Thermal Pig!
Batmanwpg's Avatar
Winnipeg, Canada
Joined Aug 2004
hot box
I need ideas also. The one I have to build needs to get up to 250° F. Is this possible using 100 w light bulbs?
Bear
Batmanwpg is online now Find More Posts by Batmanwpg
Old Nov 12, 2005, 11:17 AM
davidfee is offline
Find More Posts by davidfee
davidfee's Avatar
San Diego, CA, USA
Joined Mar 2001
My box is just made from plastic-coated expanded-bead polystyrene foam. If you need more than say 120°F, it would be better to use wood or metal for the box and insulate with fiberglass.
Sure, 250°F is possible with 100W bulbs, depending on the size of the box and the number of bulbs.
-David
davidfee is offline Find More Posts by davidfee
Old Nov 12, 2005, 01:19 PM
im-sad is offline
Find More Posts by im-sad
Or am I...
Bournemouth, Dorset, UK
Joined Jan 2005
Sorry but whats a Hot box?? A box to dry paint in??
im-sad is offline Find More Posts by im-sad
Old Nov 12, 2005, 04:13 PM
thermaled is offline
Find More Posts by thermaled
built flown + crashed it
Pewsey, Great Britain (UK)
i bought a small oil filled radiator with a thermostat for the heat source. My room is limited so i build up a box after bagging, 3 sheets of 8ft x 2ft foam and two end bits 2 x 2ft held on with a bit of tape and leave it all alone for 24 hrs. I experimented with the tempature setting until it stabalized where i wanted it, and put a sharpe pen mark on the dial. Works great for me, bag the wing, go to bed, go to work, wing is done. Workbench is free again. Keep the foam on a high shelf out of the way.
Just thinking about it a little, you could make it much more durable by linning the sheets with hardboard or thin ply, and then screw on some catches so it all clips together, hmmm i better get some ply.
Basically the same concept as phil barnes uses on his dvd.
thermaled is offline Find More Posts by thermaled
Old Nov 12, 2005, 05:17 PM
davidfee is offline
davidfee's Avatar
San Diego, CA, USA
Joined Mar 2001
Paint, yes... but more typically to speed up the cure of epoxy. If you make it hot enough, you can also post-cure your parts.
Old Nov 12, 2005, 06:24 PM
GaryO is offline
Find More Posts by GaryO
United States, AZ, Arizona City
Joined Sep 2001
Mine is 1" foam, aluminum faced, from Home Depot. I use a 2" piece of Foamular 250 for a removeable lid (heat goes up, right?)
A indoor/outdoor thermometer is used to monitor temperature. The original plan was to use a 110v dimmer to control temp, but hasn't proved to be necessary.
Heat is with either 1 or 2 light bulbs, wattage varied as needed. One 100 watt bulb will get to 90 to 100 degrees, depending on outside temp. Two 100 watt bulbs raise it another 20 to 30 degrees.
A piece of aluminum foil is on the underside of the lid to protect the foam. Two layers of 1" alum backed foam could be used, and this wouldn't be needed.
Gary
GaryO is offline Find More Posts by GaryO
Old Nov 14, 2005, 04:39 PM
RC Powered is offline
Find More Posts by RC Powered
St Augustine, FL
Joined Jan 2005
Hotbox
Just about to finish mine. Has 0.5 inch MDF with 3/4 inch foam insulation with aluminum on both sides. Putting a high temp duct fan in it for heat circulation and using up to 6 100 watt lamps (not in photo but you can see the channel it will be put in) in it controlled with a automatic temperature controller. Put the fan in there so that I can stack a couple of wings on top of each other at the same time and hopefully get the same temp everywhere in the oven.
RC Powered is offline Find More Posts by RC Powered
Old Nov 15, 2005, 09:17 AM
DLD is offline
DLD
Find More Posts by DLD
DLD
David Layne
Tracy, Ca
Joined Jun 2004
Hot box
Hollow doors make a good hot box. The air inside makes a good insulator. I used three doors with mdf floor and ceiling, then hinged the fourth door. Two heat lamps were attached to the floor of the box, and I hung fuselage molds from hooks, nose down. The heat lamps will get the box to 120-130 degrees. It's cheap, easy and effective.
David Layne
DLD is offline Find More Posts by DLD
Old Nov 15, 2005, 02:23 PM
I'm Rick James is offline
Find More Posts by I'm Rick James
Nucking Futs
I'm Rick James's Avatar
Southern Killafornia
Joined Jan 2005
I rolled up the windows in my car and lit up!!!!
Just kidding man, good luck with your project.
IRJ
I'm Rick James is offline Find More Posts by I'm Rick James
Old Nov 15, 2005, 03:04 PM
Joined Nov 2003
IRJ
Was wondering whether someone with a misspent youth, or adulthood, would offer that solution...
Old Nov 15, 2005, 07:45 PM
THend is offline
Find More Posts by THend
The End
THend's Avatar
AREA-52, Oceanside Southern Killafornia
Joined Dec 2003
Seriously, is a hot box a requirement? I plan on making fuselages, so if I need one, I'll build one. Were do you get the specs to know how hot and for how long?
Hate to be dumb, but what are the benefits?
THend is offline Find More Posts by THend
Old Nov 15, 2005, 08:33 PM
St Augustine, FL
Joined Jan 2005
curing temp
Speeds up the curing time.
Raises Tg of the epoxy.
Tg, or the “glass transition temperature,” is the temperature “range” at which the cured epoxy will begin to significantly compromise its physical properties of consistency, hardness, shear strength, tension strength, compression strength, flexural strength, etc. Epoxies cured at room temperature have a maximum Tg of 60-65oC regardless of their hardener ratios, or up to 90oC with a post-cure at 60oC heat for 2 hours. To get an epoxy to develop a Tg over 90oC it needs to be cured for hours in a specially built high-heat oven. This will increase the Tg when cured, and make the resin structure stronger.
Benefits for polyester resin are not that big (if your are planning on using that for your fuse).
Old Nov 15, 2005, 11:32 PM
Nucking Futs
Joined Jan 2005
for what you want to do Terry, you don't need it IMHO.
IRJ
Old Nov 16, 2005, 02:57 PM
Joined Nov 2003
Two questions...
David Layne
Will a wood box work for 150-160 degrees F cure temperatures?
Would you recommend that major axis (longest lenth) be vertical or horizontal for curring bagged wings?
AMTJIM (How did you make your Wally bomber?? mike93 Foamies (Kits) 2 Feb 28, 2002 01:08 AM
So how did you get your username? Foxtrot Life, The Universe, and Politics 50 Jul 20, 2001 04:11 AM
how did you find your lost plane? Richard Electric Plane Talk 17 Jul 16, 2001 09:47 AM
How did you make your T-52 bat compartment? Mike C Foamies (Kits) 3 Jun 20, 2001 02:38 PM
How did you get your Indoor Flying Site??? OCModels Parkflyers 1 May 25, 2001 02:28 AM
