Old Nov 10, 2005, 08:43 PM
Miami Mike is offline
Find More Posts by Miami Mike
Pompano Hill Flyers
Miami Mike's Avatar
Miami Lakes, Florida, USA
Joined Mar 2003
Epsilon 1.5 vs. Spyder-Sixty
I just got a new Spyder-Sixty to replace my old Epsilon 1.5.
I expected the two planes to be identical, but it turns out that there's one significant difference. Both have full-span ailerons, but while the ailerons on my Epsilon 1.5 actually meet in the middle and touch each other, my new Spyder-Sixty has a small fixed section of wing, about 1.5 inches wide, in between the ailerons and directly over the fuselage. That means that while the downward aileron deflection of the Epsilon 1.5 is limited to the point where the ailerons hit the fuselage, the downward deflection of the Spyder-Sixty ailerons is limited only by the hinges. Therefore they are capable of descending much further. That's an improvement, and I hope to take advantage of it by setting up my servo linkage for as much travel as possible.
I wonder if current Epsilon 1.5 gliders are made like my new Spyder-Sixty, or if the difference still exists. If the two planes are different, that's something for others to consider when deciding between them.
Miami Mike is offline Find More Posts by Miami Mike
Old Nov 10, 2005, 08:49 PM
Radian is offline
Find More Posts by Radian
Pompano Hill Flyers
Radian's Avatar
Coral Springs FL
Joined May 2002
Build Fast
So Mike, Will you have it flying by Saturday?
Or will it languish forever like "someone else's" we know?
Radian
www.phflyers.com
Radian is offline Find More Posts by Radian
Old Nov 10, 2005, 09:05 PM
Pompano Hill Flyers
Miami Mike's Avatar
Joined Mar 2003
The servos should arrive tomorrow. SoaringUSA has good prices and free shipping on those too. I'm getting two HS-125MG for the wings and two HS-81MG for the v-tail. The only thing I don't have yet is a Mouser phone jack to charge the battery (hint, hint).
As you probably noticed, that Epsilon 1.5 was my favorite sloper, so I don't intend to waste any time getting this replacement flying. I'll never make it by this Saturday, but I should have it for the weekend after.
Meanwhile, I'm sure my Epsilon 1.5 is still flying around up there ever since hurricane Wilma sucked open the cap on my pickup truck and carried it away.
Old Nov 10, 2005, 09:25 PM
Radian is offline
Pompano Hill Flyers
Radian's Avatar
Coral Springs FL
Joined May 2002
switchjack
I'm putting one in mmy transmitter box for you right now. Remind me Saturday.
Radian
Old Nov 10, 2005, 09:31 PM
ploof is offline
Find More Posts by ploof
what makes that thing go
ploof's Avatar
United States, WA, Clinton
Joined Sep 2005
When I got my Epsilon 1.5 late last winter it had the solid TE at the root. I think also the paint on the wing tips is different between new, and old I went with JR 241 mgs all around with all up weight at 17 1/2oz. It since day one has been a very predictable ride I think I might look into ballast a month or so ago got a carbon banana in the air, and I'm still happier with the epsilon I think I just need to grow into the banana. I always find myself tempted to get one of the bigger spyder ships then I find myself being swept off to 3m candy land.
ploof is offline Find More Posts by ploof
Old Nov 10, 2005, 11:51 PM
prplgoat is offline
Find More Posts by prplgoat
gas tires and oil
prplgoat's Avatar
malad, idaho
Joined Dec 2004
good story!!,but..did that really happen? or are you just makin it up?
marty
prplgoat is offline Find More Posts by prplgoat
Old Apr 09, 2006, 11:46 PM
MustangAce is offline
Find More Posts by MustangAce
Joined May 2005
Epsilon vs. Spyder Sixty
Is the Epsilon lighter than the Spyder??
MustangAce is offline Find More Posts by MustangAce
Old Apr 10, 2006, 12:06 AM
raptor22 is offline
Find More Posts by raptor22
Striving to Rip the Bring
raptor22's Avatar
San Diego, socal, USA, North America, Earth, Solar System, the Orion arm, Milky way, Universe
Joined Apr 2003
I'm pretty sure they are the same plane, and he was experiencing different versions.
raptor22 is offline Find More Posts by raptor22
Old Apr 10, 2006, 12:20 AM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
Epsilon 1.5 on sale
Looks like Nesail.com has the Epsilon 1.5 on sale for $199.95. Does it look like yours?
http://www.nesail.com/detail.php?productID=2939
Doubletap
Doubletap is offline Find More Posts by Doubletap
Old Apr 10, 2006, 06:26 AM
Pompano Hill Flyers
Miami Mike's Avatar
Joined Mar 2003
That's a great price, so long as Sal doesn't get it all back with inflated shipping charges. I'd call first and ask him two questions:
1. How much for shipping, and...
2. Does the wing trailing edge have the small fixed section above the fuselage that allows the ailerons to drop below, or do the ailerons meet in the middle and hit the fuselage when they go down?
It's lots more fun to have that extreme downward aileron deflection available, but it's not really necessary.
If anyone calls about it, please let us know.
Old Apr 10, 2006, 09:36 AM
doddlepots is offline
Find More Posts by doddlepots
Joined Feb 2006
Don't worry about the ailerons meeting in the middle. You just have to find yourself:
a) a round file, or a Dremel grinder
b) a piece of fine sandpaper
Then:
-You grind a semi circular piece out of the corners of the ailerons, above the fuselage (more or less the same diameter as the fus.)
-You will need to insert the sandpaper between the ends of the ailerons and open up the gap to approx 1/16th." or 0.5mm., otherwise the edges rub together, before reaching max. travel down.
No big deal at all. 15 mins. max. and you have all the down you will ever need.
Incedently, as I mentioned in another thread, if you are gpoing to use flaperons (down) anything like as much as you can with this small mod (or even without it), DO NOT FORGET TO RESET FLAPERONS TO ZERO OR NEGATIVE BEFORE DIVING! I have manged to destroy two sets of plastic pinioned servos this way and have been very lucky not to destroy sixty/toplight/mini-spider/x-race or whathaveyou in the process!
Also, really, you don't, in fact need the max. travel down, as it climbs like an atlas rocket with 2-3mm of flaperon and landing is better with max. NEGATIVE flaperon(spoileron) plus a couple of mm. elevator UP mixed in.
For fast rolls, you should have already eliminated the big down movement, with the aileron "Diferencial" which I have at approx 3:1 (up/down) and find ok.
Marvelous little plane. Have fun with it.
Cheers,
Christopher
doddlepots is offline Find More Posts by doddlepots
Old Apr 10, 2006, 10:13 PM
Joined May 2005
Epsilon
I called and Sal said he only had one left! The shipping charges were inflated but the airplane was blue and white and the ailerons didn't meet at the fuse! Can't wait to get this bird. My first real slope ship!
Old Apr 10, 2006, 10:56 PM
Doubletap's Avatar
Joined Jul 2005
What did he get you for shipping, by the way?
Old Apr 11, 2006, 12:02 AM
thumbhead is offline
Find More Posts by thumbhead
altitude adjustment
thumbhead's Avatar
USA, CA, Irvine
Joined Mar 2005
hey all,
my brother-in-law stepped on my Epsilon 1.5 (that was 2 years ago and i'm still pissed!) so i got a Spyder-Sixty to replace it. 17.5 oz. AUW?! i don't think my Spyder-Sixty can come out that light. keeping weight in mind during the entire build, my Sixty came in at 20 oz. never weighed the Epsilon. i noticed the Spyder has carbon in the servo wells and the Epsilon's servo wells had balsa exposed with no carbon. maybe the Sixty is built stronger/heavier. aside from the mentioned differeces such as the root TE and the differences in the paint, i've noticed no other differences between the 2. my Spyder-Sixty's set up with HS 125's in the wings, a single HS 85 for elevator, Electron 6 and a 720 ma ballery. SUSA had them on sale when i bought mine: $217.00 with free shipping. pretty killer deal. pretty killer plane.
thumbhead is offline Find More Posts by thumbhead
Old Apr 11, 2006, 06:57 AM
Joined May 2005
shipping
$45
NES Epsilon 1.5 pictures MDM Slope 106 Nov 12, 2011 07:01 PM
Sold for sale 1.5 Meter - Spyder-Sixty RTF $180 IMRC Aircraft - Sailplanes (FS/W) 5 Feb 22, 2007 12:03 AM
Question Cutting flaps into an Epsilon 1.5/Spider Sixty? TheJ Slope 2 Jul 12, 2006 11:48 PM
Epsilon 1.5, any one flying it ? MDM Slope 12 Jun 29, 2004 10:21 PM
Omega 1.5 Vs Mini Elispe MartinL Electric Sailplanes 6 Aug 12, 2002 02:13 AM
