Old Nov 09, 2005, 07:29 PM
JThiessen is offline
Find More Posts by JThiessen
Joined Jun 2005
Help!
Help with pull start! Hard to pull....
I just purchased a used HPI RS4 with a .15 motor. First couple pulls with the pull start resulted in nothing abnormal. Then it fired, next time the chord stuck in the out position. I used the flywheel to get it to retract. Now, its really hard to pull....its jerky, and just didnt feel right. I pulled the glow plug, and it pulls just fine. Checked the pipe for obstructions, and its fine.
JThiessen is offline Find More Posts by JThiessen
Old Nov 10, 2005, 12:39 PM
Futterama is offline
Find More Posts by Futterama
Denmark
Joined Nov 2005
You've probably flooded the engine. Does fuel splash up from the glowplug hole when you pull the chord without the glowplug attached?
Futterama is offline Find More Posts by Futterama
Old Nov 10, 2005, 08:39 PM
RCNUT2515 is offline
Find More Posts by RCNUT2515
RCNUT2515's Avatar
RI
Joined Jun 2005
yeh it sounds like its def flooded since when you take the plug out it is fine. try only priming the engne till fuel enters the carb and then start it up.
RCNUT2515 is offline Find More Posts by RCNUT2515
need help with pull pull rudder setup neonbutterfly Scale Sailplanes 10 Jan 24, 2004 08:19 PM
