Old Nov 09, 2005, 06:16 PM
ib456 is offline
Find More Posts by ib456
Joined Sep 2005
Making wings from EPP, is it possible?
Hi,
I just got a few sheets of EPP foam (6mm & 8mm) and looking at it, it is far weaker than depron. Is it possible to use it for the wings?
I wish we could get bluecor down here, would make it so much easier...
Stuart
ib456 is offline Find More Posts by ib456
Old Nov 09, 2005, 08:01 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
Lots of 3D flyers are 6 and 9 mm epp. They cut a slot in the middle and glue a carbonfiber rod or tube in to stiffen it up. I have epoxied 2 6mm layers, with a spar in the middle and shaped it into a airfoil. Worked quite well. I do the same for the fuselage. Butch
Butch777 is offline Find More Posts by Butch777
Old Nov 09, 2005, 09:50 PM
Uttam1 is offline
Find More Posts by Uttam1
Micro Brushless crazy
Uttam1's Avatar
India, Bangalore
Joined Jul 2002
Stuart, EPP is a lot more Durable than any other Foam out there. Yes, it's possible to build wings from the sheets you have. You could build one like Butch suggests, a flat wing with a Cf spar, just like on the Flat foamie 3D planes out there. You could also build a built up, and sheeted wing, like done with Depron. Everything in the wing will be EPP, including the spar which is reinforced with some CF. But the thinner EPP is better for this.
-Uttam
Uttam1 is offline Find More Posts by Uttam1
Old Nov 09, 2005, 10:40 PM
ib456 is offline
Joined Sep 2005
Can it be moulded with heat like depron? as I only want to make a simple wing for the STC from it. For this it needs to hold it's shape.... I love the fact you can bend it just bounces back, but makes it hard for forming wings..... other than flat ones that is.. perfect for my IPS Zero which i cant fly, the depron one lasted about 2 lunches before it snaped....
Old Nov 09, 2005, 11:00 PM
Uttam1 is offline
Uttam1's Avatar
India, Bangalore
Joined Jul 2002
Not sure about moulding it. From my experience EPP has a pretty low "softening" point, if you can call it that. When I tried forming once, even a little heat started to "change" the surface, I'm not sure how to describe this. I think it should be possible to form the wing on a pipe or something. You could then use a couple of ribs and a CF spar. Try it!
Old Nov 09, 2005, 11:14 PM
ib456 is offline
Joined Sep 2005
Thanks, i was thinking about the ribs to hold the shape, just wasnt sure if that was how to do it... or if it would even work... wonder what it would cost to ship two packets of bluecor to New Zealand?... almost worth looking into.
Old Dec 06, 2005, 10:33 PM
Beach Buck is offline
Find More Posts by Beach Buck
Encinitas, Ca
Joined Sep 2002
these are all made of epp. Buck
Beach Buck is offline Find More Posts by Beach Buck
Discussion Making Wings from FFF RTHawk Foamies (Scratchbuilt) 7 Jan 16, 2007 05:09 PM
Making Wings from cores Keith R. Flying Wings 3 Jun 29, 2005 09:35 AM
Discussion Building EPP flying wings from scratch DennisRB Slope 39 Nov 10, 2004 12:09 AM
What the...? 2 new EPP wings from Oz flyonline Slope 47 Jul 12, 2004 10:56 PM
Playing with making a Power Pod from EPP blivsey Electric Sailplanes 45 Nov 20, 2003 07:38 AM
