Old May 23, 2002, 11:00 PM
davidbogart is offline
Find More Posts by davidbogart
atlanta
Joined Oct 2001
guillows 24" aeronca champ rubber to electric conversion
hello guys,
..just for the hell of it i bought a guillows aeronca champ.
..am i nuts for trying to make this rc? yes- i have read about
others coverting rubber powered planes to rc- but not much
was mentioned on the aeronca. i was thinking about powering
it with a m100. again am i nuts? too high of wing loading to even bother or has anyone converted a plane with this small a wingspan (24") sucessfully?
thanks,
dave
davidbogart is offline Find More Posts by davidbogart
Old May 24, 2002, 10:58 AM
Megowcoupe is offline
Find More Posts by Megowcoupe
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
You're not nuts, but it's a bit of a challenge. First off, an M-100 is way too much motor. I'd go with an HY 50B or HY 50D instead- I flew a Piper Pacer at about 27 inches on an HY-50D and it had plenty of power using a 6 cell 110 nicad pack and a 6 inch prop. Secondly, if you haven't built stuff like this before, it may be a bit much to ask your first one to fly- plan on rudder elevator, and you will need to lighten the structure, it's overbuilt in some areas, and weak in others.
Sam
Megowcoupe is offline Find More Posts by Megowcoupe
Old May 24, 2002, 11:20 AM
atlanta
Joined Oct 2001
sam,
who makes that motor you recommend and where can i
find it?
thanks,
dave
keep the blue side up!
Old May 24, 2002, 12:55 PM
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
David
Try Cloud 9- the address is on the www.rcmicroflight.com web site.
Sam
Old May 24, 2002, 03:10 PM
atlanta
Joined Oct 2001
sam,
thanks. beginning to seriously contemplate the
expenses vs actual fun during flight. this wing is
so tiny i feel like its going to have to fly like a bat
out of hell to stay in the air. i guess we will see.
dave
Old May 24, 2002, 03:26 PM
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
David
the cost of the kit is irrelevant. It's everything else that's going to add up. Why not pick an airplane that gives you a better chance of success from the get go. Check that thread on rubber powered conversions- you might be lots happier on something like a Herr Scout. But these things are lots of fun.
Sam
Old May 24, 2002, 07:39 PM
atlanta
Joined Oct 2001
sam,
thats actually what i meant (the cost of everything else).
i think i will just make the aeronca into a decorative plane
and do like you said and go with a bigger kit. oh im sure there fun if you pick the right kit. thanks for the advice.
david
Old May 25, 2002, 09:47 PM
E-Challenged is online now
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Ziroli's Aeonca Champ
I built and flew the 36" wingspan Ziroli Champ from plans with molded windshield from about Nick two year ago This was my first small electric scale plane. It was a little to small in wing area to fly well with the recommended Titanic Airlines 3:1 280 gear drive and 8-cell 280 NiMh pack. Nick admitted that he should have designed it a little bigger. Mine flew well at a slightly higher than scale speed but would occasionaly snap roll and would not recover easily. If you have a yen to build electric scale, recommend you look at Pat's Custom Models website. He has a number of his 45-60" wingspan semi-scale models that will ROG, fly realistically and land gracefully on geared speed 400's and 8 500AR cells. You can even do a little beefing up and they'll fly nicely. When you really learn how to build light but strong enough, you will be more ready to attempt 24-30" rubber kit conversions with some hope of good flight performance and longevity. I'm anxious for really small inexpensive and efficient geared brushless power systems that get plenty of thrust on small light NiMh or LIon battery packs.
E-Challenged is online now Find More Posts by E-Challenged
Old May 27, 2002, 11:44 PM
KnifeEdge51 is online now
Find More Posts by KnifeEdge51
central AZ
Joined May 2002
Before I start, I have no knowledge on this type of stuff. However, I have a Guillows Cessna 172 36" wingspan scale plan made for control line/FF/"small R/C equipment" (to quote the instructions) that I plan to turn into electric R/C 4 channel. The kit looks good, but I'm not sure I know what I'm getting myself into I have not started building this model yet, but I plan on it, and will let you all know, if interested, how it turns out. I won't know for quite some time, though. I'm looking forward to it, though.
Nick R.
KnifeEdge51 is online now Find More Posts by KnifeEdge51
Old May 28, 2002, 07:52 AM
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
Nick R.
See my advice posted above. Actually Gerald has done this conversion- check his web site.
Sam
Guillows 24" Aeronca Champ looks like it was made by a CHIMP! nhorianopoulos Scale Kit/Scratch Built 19 Mar 21, 2015 03:46 AM
Guillows 24" span Cessna 150 , taildragger conversion simano Parkflyers 41 Dec 10, 2009 10:17 AM
Guillows 24" Cessna 150 Conversion By Magic840 Magic840 Scale Kit/Scratch Built 62 Sep 02, 2006 08:27 PM
Yippee! guillows, rubber to electric conversion? littlewing78 Scratchbuilt Indoor and Micro Models 1 Apr 09, 2005 11:31 PM
Scale 24" Aeronca Champ freeflyer is HEAVY! nhorianopoulos Scale Kit/Scratch Built 2 Aug 07, 2002 11:52 PM
