Old Sep 18, 2006, 03:45 PM
gunracer is offline
Find More Posts by gunracer
diligentia vis celeritas
gunracer's Avatar
Corona, CA
Joined Feb 2006
i'm also amazed at some of the lower auw i've read on this thread...using the below components, my p40 comes in at 6.5 oz...
dx6 rx
2s 700 batt
eflite esc
stock motor
2 cox servos (elevator and ailerons)
to minimize wing flex, i reinforced the le with a pushrod bent to match the dihedral...relatively heavy, she still flys better than i ever expected her to...
gunracer is offline Find More Posts by gunracer
Old Sep 18, 2006, 05:19 PM
peterp1964 is offline
Find More Posts by peterp1964
peterp1964's Avatar
Joined Oct 2005
dx6 rx
2s 700 batt
eflite esc
stock motor
well, your components are too heavy !
I used a bluebird 4ch receiver and servos, a BP10 esc (not light!), a
polyquest 3S 300mAh, a piece of ply, a firewall mount, a 20mm cdrom,
Deans 3pin plugs for the motor/esc, 2 washers and 2 nuts for the prop, the
charge plate, z-bends inside, the cox shrinktube methodon the outside.
Foam-safe CA on everything except the motor mount where I used epoxy.
AUW 151 gr, including the decals
Peter
peterp1964 is offline Find More Posts by peterp1964
Old Sep 19, 2006, 09:41 AM
StCalvin is offline
Find More Posts by StCalvin
ooops
StCalvin's Avatar
Dekalb,Illinois
Joined Oct 2003
Due to dumb thumbs I finally had to retire my Spit and P-51. Was not a good day.
Going to build 2 more. This time will see how they work with lypos. I am concerned about balancing. With the Cox nihm's it was a real no brainer. How about with lypo's? Any issues?
StCalvin is offline Find More Posts by StCalvin
Old Sep 19, 2006, 03:52 PM
MLem is offline
Find More Posts by MLem
MLem's Avatar
USA, CA, San Francisco
Joined Jun 2003
you're gonna like the lipo. on my corsair it slips right in and gives me long flight times. sounds like a viagra ad. heheh.
MLem is offline Find More Posts by MLem
Old Sep 19, 2006, 03:53 PM
Bajora is offline
Find More Posts by Bajora
AA6JB
Bajora's Avatar
Joined Sep 2004
Hey Mlem, I just finished my Corsair too! 2S lipo with stock motor. You fly in south bay or? I am North Bay.
Bajora is offline Find More Posts by Bajora
Old Sep 19, 2006, 06:36 PM
MLem is offline
MLem's Avatar
Joined Jun 2003
barnes,
i'm over the golden gate in sf. just flew at crissy field last weekend. in sf gotta fly 1 step ahead of park rangers...
i'm working on the mig 21 for beanie right now.
we should see if we want to schedule a fly-in or furball one of these days.
mike
Old Sep 23, 2006, 11:05 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Well, I've just got my LensRC 17T Spitfire pretty much together - 136g with 2s 480, 147g with 3s 480. Even then it feels too heavy for the very limited wing area. When my second kit comes I'm going to try a Medusa 4000 - maybe I can lose another 10g-20g.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Sep 24, 2006, 09:48 AM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
Here is the internal layout. I need to determine where to cut the starboard fuselage. I want to be able to remove the forward section of it to gain access to the ESC and battery - I guess I'll use some little rare earth magnets to hold it. This portion of the aircraft, with the tail feathers, and including the motor/prop and 2s 480, is 113g - add 23g for the wing, for an AUW of 136g.
Question: I faithfully followed the alignment for the stock motor (down and right thrust), but this amount of downthrust looked a bit excessive - doesn't it???
I don't trust servo tape, so my servos are tightly fitted between little balsa strips, so they cannot move for or aft when in use.
The Rx, ESc and antenna are all held with Velcro.
Cheers, Phil
Old Sep 24, 2006, 09:59 AM
smoothb10 is offline
Find More Posts by smoothb10
United States, CO, Colorado Springs
Joined Jul 2004
thats what i was thinking when i built mine looks like alot of right and down thrust. when i hand launched the sucker it went perfectly strait and level with a gentle climb it was perfect
smoothb10 is offline Find More Posts by smoothb10
Old Sep 24, 2006, 11:07 AM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
Thanks for the vote of confidence! It's just that it doesn't look right!
Old Sep 24, 2006, 11:16 AM
Balsa Hound is offline
Find More Posts by Balsa Hound
SW Vermont
Joined May 2002
Kiwi--I think it's because the weight is so low and the overall surface areas are so small that the "extreme" right and down thrust is needed. But they do fly with zero trim if you use the built-in thrust angle.
Red61--drop me a PM.
Balsa Hound is offline Find More Posts by Balsa Hound
Old Sep 24, 2006, 02:14 PM
Joined Jul 2004
yep mine also needed no trim flew very srait from the start
Old Sep 24, 2006, 09:16 PM
peterp1964's Avatar
Joined Oct 2005
what's with the giant prop ? trying for a heli mod I have a 4.5" on my P47
and _it_ looks big !
Peter
Old Sep 25, 2006, 06:43 AM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
Peter
The only small CD ROM motor I have is this 17T - it doesn't draw more than ~3-4A with a 4"-5" prop even on 3s. - that's why I'm trying a 6x3. I do have some odd small Cox 3-blade props - to hell with the efficiency - they might be okay even on 2s. A Zagi might be okay, or 5.1x4.5 Broad-bladed APC, or an odd Graupner I have - all of those suck amps.
I really need a hotter, lighter CD ROM motor suited to 4-5" on 2s!
The opposite is true of the Medusa 4000 I want to try in a second Spitfire - it can't spin more than a 3" prop DD on 2s - and 3" looks awful small!
Old Sep 25, 2006, 07:44 AM
Red 61 is offline
Find More Posts by Red 61
Outcast outlaw
As far away from RCGroups and the AMA as possible!
Joined Aug 2004
I don't know if the BP-21 is smaller or lighter, but it's suited to 4-5" on 2s.
Red 61 is offline Find More Posts by Red 61
Mass Cox Micro Warbird sortie at SMALL steps 2006 Thomas B Parkflyers 18 Oct 11, 2006 08:08 AM
Discussion cox micro warbird, build advise and questions troyboy162 Electric Warbirds 12 Feb 13, 2006 01:38 AM
Idea Cox micro warbird assembly ham2405 Parkflyers 22 Jan 19, 2006 11:29 PM
Discussion J250 in a Cox Micro Warbird? glennhl Foamies (Kits) 5 Jan 15, 2006 10:22 PM
Sold E-Tec 2 cell 700 mAh HP Lithium Polymer LiPo Battery perfect for Cox Micro Warbird shschon Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jan 13, 2006 12:23 AM
