Espritmodel.com Heli Air
Old Nov 06, 2005, 12:05 PM
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
8'' Micro EDF (L-39 Albatros)
Hi guys,
This is going to be my new L-39. The bird will not be designed for indoor, but is definitely small enough for the micro forum. 8'' (20cm) wingspan, 3 gram minidisc motor 30mm fan, actuators... Can't wait to get started. What do you think?? I will also discuss this project in the micro forum, but more (the only) knowledge about edf is clearly found here. I will need input from all sides, thats for sure
Cheers,
Chris
Chris T is offline Find More Posts by Chris T
Old Nov 06, 2005, 12:16 PM
Gordon's Avatar
Braunton, North Devon, England
Joined Aug 2000
Originally Posted by Chris T
3 gram minidisc motor 30mm fan, actuators <snip> I will need input from all sides, thats for sure
Hi Chris
I'd expect that more than a few of us who've never visited the micro forum would need some input from you on the characteristics of the motors and the actuators (magnetic?) you plan to use
Does the 30mm fan exist commercially, or will you have to make it from scratch?
Cheers
Gordon
Gordon is offline Find More Posts by Gordon
Old Nov 06, 2005, 12:43 PM
Joined Sep 2003
Chris,
did you decide to make your 30" L39 plans available??? 8" is too much, my eyesight can't take it!!! lol.. looking forward to this build!
gearup is offline Find More Posts by gearup
Old Nov 06, 2005, 01:49 PM
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Gearup, my L-39 (see avatar) is 16'' span, not 30'' and I think it is quite big Unfortunately, there were no plans used, just the 3view. The rest happened in my head. This time I will try to make templates! I hope, somebody will build along so it is worth it.
About your eyesight, here is my theory. If you half dimensions of any plane and reduce weight enough so speed is halved as well, visibility will reain the same, since you fly within half the distance at equivalent relative speed. I am not afraid of scaling down. The good thing is, the smaller you build the more stable the stuff gets (I think).
Gordon, the 30mm fan is a cutdown GWS edf 50, so a modified commercial product. Easy to do... It might be harder to find a mini disc motor
Check http://www.rcgroups.com/forums/showt...4&page=5&pp=15
Chris
Old Nov 06, 2005, 02:31 PM
London,England,UK
Joined Jan 2001
Hi Chris t
Just discovered this post on the off chance doing a search - I have quite the opposite L-39 model , one of my favourite jet shapes. I am building th Savex EDF version as I do not the courage for the turbine version . I was searching for suitable retracts
The reason for my post here is that I am a distributor of a range of jet planes ( see www.robotbirds.com) and on my last trip to Czech we were designing a EPP L-29 and have yet to decide on the size - The pusher version is already made and is 22" span - I would like to get a 14-16" EDF version made but there are many production difficulties in keeping to scale proportions. I will return to your posts with great interest.
Andy
[IMG]www.robotbirds.com/catalog/images/l-39.jpg L-39 pusher[/IMG]
andyUK is offline Find More Posts by andyUK
Old Nov 06, 2005, 03:18 PM
London,England,UK
Joined Jan 2001
sorry this one
http://www.robotbirds.com/catalog/images/l-39.jpg
Old Nov 07, 2005, 05:23 PM
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
First Facts
Weight of wing: about 3g
Chris
Old Nov 08, 2005, 05:51 AM
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Want Templates??
Anybody got the courage to go real micro along with me?
Sign up now, if you want to build a micro L-39 as well!!!
At least, the raw material is cheap since you need almost nothing
A perfect area ruled duct will be modeled into the fuselage. Inlet area 100% FSA (slightly off scale but worth it). BTW, I am using balsa carbon and glass, no foam at all! Wing: 3mm balsa sheet, sanded to shape, elevator 2mm balsa. I selected the lightest balsa I could get with a precision scale.
Chris
Old Nov 09, 2005, 04:28 AM
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Motor and Fan
This is the minidisc bl motor and 30mm fan. Total weight of motor + fan without fan-stator and shroud: 4.4g
Current winding scheme: 18 x .3mm wire, star connection, 8 pole stock magnet, N50 3 x 3 x 0.5mm magnets are on the way...
Chris
Old Nov 09, 2005, 06:31 AM
Beware of the cabbage
MeGrimm's Avatar
London, England
Joined Jun 2005
Chris. Although I was very interested in your last L-39, I'm ecstatic about this one! I really am not the only one who's fascinated by miniaturising things!
It's just occurred to me just how tiny this model is going to be. 8" wingspan! Wow!
I'm following with very close interest...
MeGrimm is offline Find More Posts by MeGrimm
Old Nov 09, 2005, 07:31 AM
MeGrimm's Avatar
London, England
Joined Jun 2005
I'm sure you must have seen this?
http://www.rcgroups.com/forums/showthread.php?t=266333
Old Nov 10, 2005, 08:53 AM
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Thanks MeGrimm,
yes I have seen this one. Very nice indeed. That is kind of what I am aiming for, just with ductwork, bl motor and a little more power. I like that tiny little fan. Incredible! I would like to have one too.
I am still working on the plan for the micro. Will be done soon. I have a clue now how to do the actuator mount. Targeted weight is now 1 ounce...
Regards,
Chris
Old Nov 16, 2005, 08:00 AM
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Duct Design
Hi guys,
I just wanted to have this confirmed:
I am designing the inlets as Winmodel suggests: 100%FSA highlight area (measuring from the center of the intake lip, see air flow with diffusion). This means, the throat area will be below 100% (about 80%). This is due to a 3mm thick lip. For the 30mm fan with 15mm hub, this is 26mm highlight diameter and 23mm throat diameter. For the outlet I was thinking of 90%FSA.
You should consider, that this model will have plenty of power for its size and is designed to be a fast flyer. These usually have rather small inlets to reduce drag. At speed, sufficient air is still provided.
Does this sound ok?
I don't want to have too small inlets this time, but these numbers are already way larger than scale on this model...
Thanks for your feedback
Chris
Old Nov 16, 2005, 01:19 PM
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
... where are you experts?
Old Nov 17, 2005, 05:30 PM
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Status of the drawings
...I will start building very soon. I still wonder if the inlet lip is not too thick. I could trade it for some more "throat" area...
Chris
Build Log 8'' Micro Jet (L-39 Albatros, MiniDisc, 30mm EDF) Chris T Indoor and Micro Models 333 Nov 22, 2012 04:01 AM
Article Great Planes L-39 Albatros Jet EDF ARF Review Bajora Foamy EDFs 571 May 03, 2011 11:20 PM
Video 16'' L-39 Albatros EDF in Action Chris T Electric Plane Talk 3 Aug 03, 2008 09:51 AM
K&A Models L-39 Albatros GlasairAllen Electric Ducted Fan Jet Talk 20 Nov 28, 2001 11:04 PM
K & A L-39 Albatros J Bergsmith Electric Ducted Fan Jet Talk 1 May 30, 2001 09:40 PM
