Old Nov 06, 2005, 02:13 AM
Brian T is offline
Find More Posts by Brian T
Brian T's Avatar
Langley B.C Canada
Joined Feb 2003
How do you avoid bubbles with solite?
Is this the right forum?
I don't have too much experience with this stuff so I'm finding that when I go to put some solite over solite I get some bubbles??? I've even tried turning down the heat, but still I'm getting them. they are little hard to see in the pics
Brian T
Brian T is offline Find More Posts by Brian T
Old Nov 06, 2005, 03:59 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
No way to avoid em.
prick with pin and use heat gun..
Old Nov 06, 2005, 11:37 AM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
Must disagree with Vintage1. Wet surface using water & small (1-2 drops) liquid detergent mix. Apply second layer of Solite and slide it around till you like it. With iron on ~175-180degF squeegee the water toward the edges and out from under. It will take several passes and as the water disappears the adhesive will start to activate.
2nd method - I have not done this but others report it works great. Lay out covering on glass and work bubbles out while cool. Then use lo heat to stick covering to itself. Peel off glass and apply to model as one piece.
feathermerchant is offline Find More Posts by feathermerchant
Question How do you mount a motor with planetary to a GWS plane? scurrier GWS (Grand Wing Servo) 5 May 05, 2004 02:32 AM
Paint bleed under tape - How do you avoid edkoz Scale Fuel Planes 9 Apr 11, 2004 05:24 PM
How do you avoid paint bleeding under tape?? edkoz Parkflyers 16 Mar 21, 2004 12:27 AM
How do you make decals with a computer? Andy W Scale Kit/Scratch Built 50 May 24, 2003 09:12 PM
How do you balance a PicoJet with NIMHs?? Dunc Foamies (Kits) 7 May 17, 2003 09:34 AM
