Old Nov 05, 2005, 11:42 PM
Turbo442 is offline
Find More Posts by Turbo442
Turbo442's Avatar
North Plains, OR
Joined Nov 2003
60" ShockFlyer style Katana with Hacker A30-16M
Here is my new bird I have been working on. 60" wingspan Katana. Blew up a set of 3dfoamy plans although the construction is quite different. Powered by a Hacker A30-16M/TP 3 cell 2100 Prolite. I was goning to prop it to pull around 300 watts to start with then go up from there and see how the battery likes it. 4 HS 81's, Electron 6. Current weight as shown in photo is 21 ozs with the motor. (No radio, landing gear or battery yet) Target weight is 32 ozs RTF with battery...shoundt be a problem but we will see...Wing is 2pc of 6mm depron laminated together with a very thin 1/2" carbon strap on the front and rear leading edge of the wing Shocky style. Strap is glued on with contact cement and then covered with reinforced tape. Turned out very stiff and will fly fine with out bracing alough I will probably add some any way. Lower fuse half is 2 pcs of 6mm depron laminated together. From the nose to the rear of the landing gear on the lower half of the fuse I sandwitched a pc of 1/8" plywood between the 2 pcs of 6 mm depron. This ties the circular plywood motor mount to the landing gear. I was going to bend up some aluminum .065 landing gear and bolt it to the plywood. Rear elevator has one carbon strap bonded to it for stiffness. Should be able to finish her up this sunday and give a flight report.
Turbo442 is offline Find More Posts by Turbo442
Old Nov 06, 2005, 02:21 AM
Turbo442 is offline
Turbo442's Avatar
North Plains, OR
Joined Nov 2003
Just ran a few tests with a 12x3.8 APC slowfly prop. 300 watts on a not fully charged 2100 prolite. At any rate it was wanting to hover at 1/2 throttle during the brief test from my hand. I suppose if I need a little more thrust I could go with a 12X4.7 Slowfly but it really was pulling hard at WOT like it would have some pretty awesome vertical. The landing gear came out a little heavier than I thought at around 3 ozs with wheels and everything ready to mount. Oh well, looks like the all up weight will be around 34-35 ozs...still not bad for a 60" wingspan RTF weight.
Old Nov 06, 2005, 02:30 AM
Turbo442 is offline
Turbo442's Avatar
North Plains, OR
Joined Nov 2003
Next step is to stiffen up the tail by boxing in the lower section of the fuse. After that I need to hinge the rudder and paint. In this photo you can see wings are 2 pcs of 6mm depron and the aileron is 1 pc 6 mm depron. Tail is all 1 pc 6 mm depron.
Old Nov 06, 2005, 11:33 PM
Turbo442 is offline
Turbo442's Avatar
North Plains, OR
Joined Nov 2003
As promised she flew today. To sum it up in a nut shell, very familiar flying characteristics, but much much more stable even with a very reward CG. As you can notice in the video there is pretty much no wing rock visable. Very similar to the way my giant You-can-do flys during 'crow' mode. This was my second flight. Still very manuverable but she flys almost hands off like a trainer. All up weight came in at ...35 ozs... the shame! oh well, its not going to fall apart any time soon. Sorry the video work sucks, it was my girlfriends doing. But bad video is always better than no video! Havent tried anything other than the APC 12X3.8. Its interesting this prop will pull a 35 oz plane out of a hover. Obviously the bird did not yet make it to the paint shop. Couple of changes yet are in order, stiffer main gear, and thicker push rods. It was flying with the pushrod wire that shipps with the slow stick. Video is 1.8 meg not a bad download.
http://www.rob.com/matt/rc/rc_video/Katana.wmv
Old Nov 07, 2005, 12:33 AM
Larry3215 is offline
Find More Posts by Larry3215
Permanently Banned
Larry3215's Avatar
Gig Harbor, Washington, United States
Joined Sep 2003
Well done!
I've been toying with doing a larger foamy for some time. This may motivate me.
Larry
Larry3215 is offline Find More Posts by Larry3215
Old Nov 07, 2005, 12:35 AM
Permanently Banned
Larry3215's Avatar
Joined Sep 2003
LOL
I like the intheditch landing
Looks like it flys great!
Larry
Old Nov 07, 2005, 01:01 AM
Turbo442 is offline
Turbo442's Avatar
North Plains, OR
Joined Nov 2003
Yeah, im not quite sure what I was thinking on the landing? I guess I flew around a little too long at high alpha and forgot that 35 oz planes dont just float in! At any rate I have confirmed in my mind that airfoils do nothing but spoil the way an airplane flys.
Old Nov 08, 2005, 10:21 AM
Bill Martins is offline
Find More Posts by Bill Martins
I just want to FPV!
Bill Martins's Avatar
United States, OR, Eugene
Joined Jun 2004
Turbo,
Very nice.
Looks stable and really locks into a harrier. Nice rolling circles also.
Great job.
Bill
Bill Martins is offline Find More Posts by Bill Martins
Old Nov 09, 2005, 09:25 AM
Turbo442 is offline
Turbo442's Avatar
North Plains, OR
Joined Nov 2003
I think I am going to build another one but this time without laminating the wings or fuse. I am pretty sure normal shocky construction will work just fine with 6 mm depron at 60". It for sure will need bracing from the lower fuse to the mid point of the wing with carbon rod, but that adds hardly any weight. If I can shed 6-8 ozs I will be happy.
Sold Hacker A30-16M with Airboss 35 ESC. Free Shipping!! ronrandle Aircraft - Electric - Power Systems (FS/W) 4 Jun 21, 2007 09:30 AM
Sold Hacker A30 16M with X30 CHEAP BoneDoc Aircraft - Electric - Power Systems (FS/W) 3 Jun 10, 2007 03:24 PM
Sold HAcker A30-16M NIP $60 Bajora Aircraft - Electric - Power Systems (FS/W) 7 Dec 15, 2006 09:31 PM
Discussion Hacker A30/16M with Pheonix 45 issues Turbo442 Castle Creations 2 Apr 04, 2006 01:08 AM
Hacker A30-16M or AXI 2808 24? ciressarg Power Systems 6 Oct 11, 2005 09:59 PM
