Go Back   RC Groups > Aircraft - Electric - Airplanes > Beginner Training Area (Aircraft-Electric)
Old Nov 04, 2005, 09:30 AM   #1
Aileron servos
I've seen pictures of some planes on various RC groups that seem
to have one servo for each aileron (the particular plane I'm thinking
of has no rudder but does have an elevator on the tail). I'm not
sure how I would get my radio to control something like this.
I assumed that an aileron system is usually controlled by a single servo
on channel 1 (elevator on channel 2). Can anyone enlighten me?
This isn't a V-tail or Elevon mixing situation as far as I can tell.
The particular plane I've ordered that looks like this is the
www.instantrc.com A10.
Jon
jumpinj is offline Find More Posts by jumpinj   Reply With Quote
Old Nov 04, 2005, 10:08 AM   #2
To use dual servos with my Hitec Flash 5 radio, one servo gets plugged into channel 1 on the receiver, the second servo gets plugged into channel 5. Just have to be sure to set the radio to the correct mode.
I believe you may also be able to use a Y-harness to use two servos with only plugging them into one channel.
-jg
jgallone1801 is offline Find More Posts by jgallone1801   Reply With Quote
Old Nov 04, 2005, 10:09 AM   #3
Master of 1 point landing
Jon
One servo for each aileron is typically called flaperons - can be programed by radio to act as flaps (also as airbrakes) as well as ailerons. It is typically called flaperons mixing, or if your radio has custom mixing, you can do that. Most decent 6 channel computer radios support this (IMHO, the Optic 6 is the best bang for the buck radio you can get for beginner/intermediate flying).
That being said, flaperons on a small (<40") wingspan plans are really not needed - a one servo setup with std hookup, bell crank, or aileron link works as well, saves weight, and easier to hookup. For your A10, I would only use one servo for ailerons as you really dont need flaps or an airbrake.
I would add ailerons, not subsitute them for a rudder. The rudder allows for coordinated turns, tigher turns, control on rolls, and some other neat arobatics that you would lose with just ailerons.
If you really want two servos, and your radio doesnt support flaperons, you could use a mixer off the RX, but they are sort of a PITA to set up.
ImaBiggles is offline Find More Posts by ImaBiggles   Reply With Quote
Old Nov 04, 2005, 11:34 AM   #4
Ascended Master
Sparky Paul's Avatar
Use a Y-connector for two aileron servos..
The receiver end plugs into channel 1.
You won't have flaperons, but you don't need those.
  • Name: ServoY-connectors-02.jpg
Description: Two aileron servo hookups
Y-connector and T-connector Two aileron servo hookups Y-connector and T-connector 115.9 KB · Views: 120
Sparky Paul is offline Find More Posts by Sparky Paul   Reply With Quote
Old Nov 04, 2005, 02:28 PM   #5
Holy crapski! Did you just make that scan for this thread? If so, way to go the extra mile!
Old Nov 04, 2005, 02:47 PM   #6
In addition to flaperons, there's another common reason to use two aileron servos/channels - aileron differential: basically, the downward movement of ailerons is reduced, which helps lower the induced drag associated with a lot of aileron. When rolling left, for example, the right wing aileron won't move as far down as the left wing aileron moves up (and vice versa when rolling left). The main effect of this is that the plane won't yaw away from the turns so much. Aileron differential can be very effective on high performance planes where precision is necessary, as well as on slow flying planes where induced drag effects are exagerated.
There are other, clever ways to set up aileron differential, but the vast majority of times it's done with two servos and a computer radio.
If you haven't heard of aileron differential or flaperons before, chances are you don't need them on your model and one aileron servo will do.
deSelby is offline Find More Posts by deSelby   Reply With Quote
Old Nov 04, 2005, 03:02 PM   #7
Ascended Master
The wonders of digital photography!
Sometimes a picture forestalls a 1000 words..
Nikon Coolpix 7600, 7.2M image, resized to fit here.
Aileron Servos DaleM Electric Sailplanes 2 Sep 17, 2001 11:16 AM
Mounting Aileron Servos MMGM Electric Plane Talk 2 Sep 11, 2001 10:21 AM
GWS Pico Pack 4ch Rx w/2 aileron servos? cenman Electric Plane Talk 2 Sep 11, 2001 05:31 AM
How to wire dual aileron servos smithrl Power Systems 2 Jul 18, 2001 06:12 PM
I want to use two aileron servos in my Vortex CC Joe Elston Electric Plane Talk 1 May 30, 2001 08:26 AM
Congratulations SimpleM!
