Old Nov 04, 2005, 04:43 AM
viflyer is offline
Find More Posts by viflyer
St. Croix, US Virgin Islands
Joined Oct 2003
Lipo cell internal resistance
Well, I am happy to say that this is the one area in RC Groups that really makes my brain smoke! Could this be why I took college physics all those years ago???
Anyway, is there some way to calculate the internal resistance for packs from individual cells? There doesn't seem to be any data from TP, PQ etc. on the specs. of their packs, or cells for that matter.
I was thinking about the internal resistance for use with the motor calc. programs like MotoCalc and Ecalc.
Norm
viflyer is offline Find More Posts by viflyer
Old Nov 04, 2005, 05:38 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
For practical use you can just measure the voltage at a couple of different current loads and calculate the effective resistance from that e.g. if you have a pack which gives 11.5V at 5A and goes down to 11V at 10A the resistance is
11.5 - 11 / 10 - 5 = 0.5/5 = 0.1 ohms
Since that will be a 3S lipo the resistance/cell will be 0.033
All the calc programs need is a value per cell to work out the reduction in voltage under a particular load.
Steve
slipstick is offline Find More Posts by slipstick
Old Nov 04, 2005, 06:25 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
More than you ever wanted to know about battery testing.
http://www.mpoweruk.com/testing.htm
hoppy is offline Find More Posts by hoppy
Old Nov 05, 2005, 12:31 AM
Larry3215 is offline
Find More Posts by Larry3215
Permanently Banned
Larry3215's Avatar
Gig Harbor, Washington, United States
Joined Sep 2003
http://www.rcgroups.com/forums/showp...4&postcount=39
Some published specs for Kokams.
I did some Ir testing a while back and consistantly came up with numbers higher than I expected. The Ir also varies depending on the load your applying. So testing at very lite loads gives different readings from testing at heavy loads. State of charge is a factor also as well as temps.
Its a moving target.
Larry
Larry3215 is offline Find More Posts by Larry3215
Old Nov 05, 2005, 12:33 AM
Permanently Banned
Larry3215's Avatar
Joined Sep 2003
Oh yea - do a Google search on "measure battery internal resistance" you will get dozens of pages.
Larry
Old Nov 05, 2005, 03:51 AM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
For Motocalc I simply take cell voltage at the mid-point of the discharge curve, subtract it from the nominal cell voltage, and divide by the discharge current to get internal resistance.
In reality resistance is somewhat non-linear, reducing as current increases. However, if the measurement is taken at a high current draw (ie. close to the cell's maximum continuous rating) error is minimised for most applications. Of more concern is that internal resistance is highly temperature dependent. Since Motocalc does not simulate this, the only way to account for it is to have separate entries for different temperatures.
I get measurements from manufacturers' graphs (if available) or independant tests. One site that has a lot of useful discharge graphs is Elektromodellflug.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Nov 06, 2005, 09:03 AM
epkoncept is offline
Find More Posts by epkoncept
San Diego Lindberg, California, United States
Joined Jan 2002
do a search with the phrase battery impedance
I a different Ezone thread, there was a construction article on a dynamic battery impedance tester, originally from EDN magazine. I just finished mine last week. I have yet to start cataloging me cells. I modified the circuit so I could test both a A and 10 Amp pulses Seems to give reasonable results
EP
epkoncept is offline Find More Posts by epkoncept
Old Nov 06, 2005, 12:55 PM
IA-Flyer is offline
Find More Posts by IA-Flyer
IA-Flyer's Avatar
Joined Nov 2003
That brought up a few hundred hits, how about a direct link?
TIA
Jim
IA-Flyer is offline Find More Posts by IA-Flyer
Old Nov 07, 2005, 10:58 AM
Joined Jan 2002
here's the link
http://www.rcgroups.com/forums/showt...ery+impedance+
I think that there is a simple error in the schematic.
I had to wire the op amp as a unit gain to make it work.
EP
Old Nov 13, 2005, 09:01 AM
Joined Jan 2002
huh, everyone's wrists broke ?
update:
I had a large pile of poorly performing LiIon packs.
I disassembled about 5 packs. Due to the PTC's low current limit in the LiIon cells, I have to use them at about 2C, so the packs are big. 3S4P of US18650 sized cells. I found that the good cells are around 0.13ohms, where as the trashed cells are anywhere up to about 0.3ohms. When cold the PTC's could be around 0.02~0.04 ohms or so, when I pulse the current at 1 amp, I should not see the impedance rise too much due to the PTC. However when I use the 10 amp pulsing, I can see the measured impedance rise within a couple seconds. The duty cycle of the pulsing is 50%. Now I have to rebuild the packs using just the good cells.
EP
PS technical comment. Don't worry about getting a low impedance fet. The op-amp control in the schematic doesn't take advantage of it, all the power drained out of the cell under test is just turned to heat. I used a surplus CPU heatsink for the FET's (2 of them) I also heatsunk the schottkey reverse voltage protection diode.
Old May 27, 2014, 12:50 PM
Experimentalist is offline
Find More Posts by Experimentalist
Joined Apr 2013
I found this thread whilst searching for advice on measuring battery IR. I also found this site (http://batteryuniversity.com/) and have found it to be an invaluable resource for just about anything you wish to know about batteries so I am posting it for others who happen upon this thread :0)
Experimentalist is offline Find More Posts by Experimentalist
Old May 27, 2014, 12:59 PM
tntpoof is offline
Find More Posts by tntpoof
Joined Aug 2012
OHM's Law.. I E R .. build a known load get a watt meter and do the calculations yourself from one cell to how ever many you need just build it to handle whatever voltage you put in it..all known IR meters on the market to test IR in lipos say They do a estimate value not a true value..
what I described is a true value way to find out.. and dividing the total ohms by cell count dont tell you anything One cell could have 90% of the ohms you are reading MY WAY will test and your math can figure out True OHMs.. No guess work or estimated values..Yes the Truth hurts so .LOL
tntpoof is offline Find More Posts by tntpoof
Reply With Quote  (Disabled)
Old May 28, 2014, 09:01 AM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
"Alls I know" is that cell IR values go up with pack use/abuse. When a pack is near it's end of full useful life, values will be up and quite uneven per cell.
E-Challenged is offline Find More Posts by E-Challenged
Old Jun 15, 2014, 01:13 PM
steelgtr is offline
Find More Posts by steelgtr
San Jose, Ca.
Joined Jan 2005
Is there a tester available or chargers that can accurately test this?
bob
steelgtr is offline Find More Posts by steelgtr
Old Jun 15, 2014, 01:22 PM
CerealKiller159 is offline
Find More Posts by CerealKiller159
United States, FL, Orlando
Joined Oct 2013
bob
Most mid-high end chargers have an IR measurement feature. iChargers and Powerlabs do for sure. There is also the Wayne Giles dedicated ir meter if you really want a dedicated device.
CerealKiller159 is offline Find More Posts by CerealKiller159
Kokam lipo pack internal resistance edthedoc Batteries and Chargers 1 Jan 18, 2005 08:33 AM
KAN 650 cell internal resistance Smokin' Beaver Batteries and Chargers 2 May 31, 2004 04:12 AM
Tp Li-po Cell Internal Resistance hall woo Batteries and Chargers 2 Apr 09, 2004 06:53 PM
Internal Resistance of LiPo Cells? FlyingW Batteries and Chargers 0 Jul 30, 2003 08:35 AM
